gschwell Samba Member
Joined: August 19, 2010 Posts: 25 Location: South Hadley, MA
Posted: Tue May 04, 2021 10:30 am Post subject: 99 EVC Exhaust Down Pipe (front pipe, flex pipe) Replacement |
I need to replace the Down Pipe (also called the front pipe and flex pipe) on my 99 EVC. I have a replacement on the way (which is the only one I could find in the US.)
Has anyone done this with the van up on ramps?
I'm wondering if I'll be able to pull it off in the driveway, or if I should have a professional do it. From what I've read you can get at the bolts from the bottom with a long extension, but I've read conflicting accounts of snaking the pipes out and back in.
Will I have to remove any other parts (steering, etc) to get it removed?
Thanks for any input.
-Garth |
dazey77 Samba Member
Joined: May 11, 2020 Posts: 163 Location: Other side of the pond.
Posted: Tue May 04, 2021 11:31 am Post subject: Re: 99 EVC Exhaust Down Pipe (front pipe, flex pipe) Replacement |
Possibly a language thing but I am not sure exactly which bit you are talking about. Sounds to me like the headers (the 4:1 bit that comes off the engine and links to the first section of pipe that probably has the cat)
My (generic) morcel of advice. Be prepared to deal with very stuck and rusty bolts when dealing with exhausts. the heat cycling and the location means they get very stuck and rusty. If you don't have at your disposal things like impact wrench, blow torch/other heat source, grinder then I would get a pro to do it and save yourself some pain.
Not to say I havent gone through the pain myself many times .. . Drilling snapped studs out of a head is about the worst.
You can always have a go of course but don't round off bolts amd make things worse! _________________ My van modification blog:
www.dazedproductions.co.uk/Vanity |
Posted: Wed May 05, 2021 5:12 am Post subject: Re: 99 EVC Exhaust Down Pipe (front pipe, flex pipe) Replacement |
Sage advice. I always curse myself when I work on exhaust, but don't seem to learn my lesson. |
Abscate Samba Member
Joined: October 05, 2014 Posts: 22648 Location: NYC/Upstate/ROW
Posted: Wed May 05, 2021 8:25 am Post subject: Re: 99 EVC Exhaust Down Pipe (front pipe, flex pipe) Replacement |
Dremel tool with the reinforced wheels will be your best friend if 60 seconds of heat doesnt ease those manifold bolts.
Ive got oxy-MAPP over in Albany if you get stuck. _________________ .ssS! |
