tobloyd Samba Member
Joined: May 28, 2018 Posts: 184 Location: Fountain Hills, AZ
Posted: Tue May 04, 2021 5:16 pm Post subject: Where does this thing go? |
My food truck adventure is over, and I’m putting the original Westfalia stovetop back in. I found this vent plate that I assume goes behind the counter somehow, but I can’t figure it out. Can someone please post a picture of it installed on their Westfalia?
Mahalo
S4VAGE Samba Member
Posted: Tue May 04, 2021 5:28 pm Post subject: Re: Where does this thing go? |
it fills the gap between your stove cover and that driver's side inner body panel. So you aren't just looking down at cords and gas lines. |
Yellow Rabbit Samba Member
Posted: Tue May 04, 2021 5:32 pm Post subject: Re: Where does this thing go? |
It’s not super easy to photograph. Hopefully this helps.
fxr Samba Member
Joined: December 07, 2014 Posts: 2323 Location: Bay area CA
The centre hole on that strip is pop-rivetted to the stovetop. From that you'll be able to see how it fits in. _________________ Jim Crowther
Vespa GTS 300 |
cmayna Samba Member
Joined: August 18, 2014 Posts: 1147 Location: SF Bay area, CA
Yes, behind the stove/fridge cabinet at the top. _________________ '90 Westy / automatic.
If I'm not working on the camper or my '50 Chebbie truck, I'm either fishing with the wife or smoking Salmon.
Craig |
Posted: Tue May 04, 2021 7:21 pm Post subject: Re: Where does this thing go? |
Yellow Rabbit wrote: |
Thanks so much everyone, I get it now! |
Posted: Tue May 04, 2021 7:24 pm Post subject: Re: Where does this thing go? |
Did you put wallpaper over the metal frame below the window?
If so, can I see photos of how you did the whole interior? How well does the adhesive hold up to the heat? |
Posted: Tue May 04, 2021 8:04 pm Post subject: Re: Where does this thing go? |
That’s just the factory installed fabric/vinyl. |
Posted: Wed May 05, 2021 10:21 am Post subject: Re: Where does this thing go? |
Is that specific to the year, or did they all come that way. Mine (1982) has exposed painted steel there and everywhere else between panels. I wonder if I could add it to mine to cover a few ugly areas |
Posted: Wed May 05, 2021 10:36 am Post subject: Re: Where does this thing go? |
Maybe it’s a thing on GL vans. It’s the same material as the headliner. On my van the areas surrounding the windows are covered except on the doors and hatch. |
Posted: Wed May 05, 2021 1:22 pm Post subject: Re: Where does this thing go? |
Wow, nice. I wonder if it would be a practical aftermarket mod |
Alaskaberrys Samba Member
Joined: June 19, 2016 Posts: 1001 Location: SE Alaska
Posted: Wed May 05, 2021 11:49 pm Post subject: Re: Where does this thing go? |
tobloyd wrote: |
Spendy, but I see BusOk in the Netherlands has successfully duplicated it.
https://www.thesamba.com/vw/classifieds/detail.php?id=2407356 _________________ '91 Westfalia, Bordeaux Red Pearl 2.1L 2wd Auto
'91 T3 Syncro Doka, Escorial Green 1.9L TD AAZ “Gremian” (to provoke, irritate, exasperate, vex...) |
