Basilbomb Samba Member
Posted: Tue May 04, 2021 7:27 pm Post subject: clutch hose details? |
My clutch hose to the slave cylinder is shot and nobody nearby even lists it. I noticed that the front brake hose looks very similar but a bit longer. Are the fitting sizes different? Seems to me I read that the clutch line is different diameter than brake lines? Can I use a brake hose instead of clutch hose for that purpose?
82 diesel van |
syncro surf Samba Member
Posted: Mon May 10, 2021 2:53 pm Post subject: Re: clutch hose details? |
GoWesty has a braided line from the slave cylinder to the hard line (I bought the syncro version):
https://www.gowesty.com/product/clutch-flywheel/25531/braided-clutch-slave-cylinder-hose-2wd-?v=
I'm hoping that someone chimes in about the steel section as I have that question too. It does look a bit bigger than brake line. I need to replace mine but I haven't really investigated it yet. It may be that bulk line, ends and a bubble flare tool are the only way to get it done. |
Posted: Mon May 10, 2021 3:08 pm Post subject: Re: clutch hose details? |
Local dealer had a flex line that does away with the steel section. Why they opted for a non standard line for that section is a mystery, considering the rest of the line is standard, or looks to me like it is. |
Posted: Mon May 10, 2021 3:28 pm Post subject: Re: clutch hose details? |
It was a VW dealer that had the flex line - or auto parts dealer? |
zoti Samba Member
Joined: December 26, 2007 Posts: 2061 Location: Plano, TX USA
Posted: Mon May 10, 2021 5:03 pm Post subject: Re: clutch hose details? |
Watch the connection from the hard line go the flex (clear) line. Mine was rusted frozen and I ended up having to cut it. |
