Jetfxr69 Samba Member
Joined: December 28, 2018 Posts: 1293 Location: White mtns nh
Posted: Wed May 05, 2021 5:01 am Post subject: Optimistic farm find |
Headed to Georgia to see an old friend and try to squeeze this split away from him.
Its doubtful that he will give it up, but before i even ask, i need to look it over better. The engine inside the cab is the og one. Since ive only worked with bays over the years, not sure what the tripping hazards are with the earlier models. Im not interested in fetching this strickly for its value. Im only interested in it as a restoration project.
I fully understand the time and cost of busses in general, as I have several bays, and one in restoration work now. Just wondering what particular items are devastating to a split job. What items are almost unobtainable nowadays? Beams, wheel hubs, torsion bars, etc?
Not even sure of the year, but I believe its a 13 window deluxe due to the trim lines and jailbars. Would that be about a 66? _________________ You can't be a real country unless you have a beer and an airline. It helps if you have some kind of a football team, or some nuclear weapons, but at the very least you need a beer. Zappa
77 westy Seamus
76 tintop Crusher
77 westy The Judge
72 tintop bastard westy Hudson |
widehatch Samba Member
Joined: May 27, 2007 Posts: 775 Location: Memphis, TN aka The Armpit of the South
Posted: Wed May 05, 2021 5:59 am Post subject: Re: Optimistic farm find |
everything you need to restore that bus is either available as an aftermarket item or on this site in the classifieds. in todays market all you really need to build a split is a title and vin number. you can build an entire bus with aftermarket parts and panels. _________________ Missouri Micros |
peecee69 Samba Member
Joined: January 27, 2005 Posts: 1572 Location: Annapolis, MD/Bloomfield Hills, MI
Posted: Wed May 05, 2021 6:33 am Post subject: Re: Optimistic farm find |
peecee69 wrote: |
A wide hatch deluxe walk through. Very cool. Good luck. |
Wide hatch? Is that a different option or just the size that this year model would have had? I should be down there on monday and can report the actual year and vin. Gonna wait till wed to ask for it. _________________ You can't be a real country unless you have a beer and an airline. It helps if you have some kind of a football team, or some nuclear weapons, but at the very least you need a beer. Zappa
77 westy Seamus
76 tintop Crusher
77 westy The Judge
Posted: Wed May 05, 2021 6:43 am Post subject: Re: Optimistic farm find |
Jetfxr69 wrote: |
peecee69 wrote: |
Wide hatch? Is that a different option or just the size that this year model would have had? I should be down there on monday and can report the actual year and vin. Gonna wait till wed to ask for it. |
That's just indicative of the year. Narrow hatches are generally up through the '63 model year (according to Eccles) and wide hatches started on Monday, August 5, 1963 ('64 model year). The wider hatch eliminated corner windows.
I've seen a few buses from as early as '61 where the window was a different size (deluxes were larger), but the metal part of the hatch is the same. _________________ 1973 Standard Beetle - running maintenance thread - https://www.thesamba.com/vw/forum/viewtopic.php?t=675712&highlight=
1966 Doublecab - Starting resto - https://www.thesamba.com/vw/forum/viewtopic.php?t=668518&highlight= |
Lind Samba Member
Joined: November 06, 2000 Posts: 9905 Location: idaho
Posted: Wed May 05, 2021 7:22 am Post subject: Re: Optimistic farm find |
definitely a '66.
the hard thing to find is rust-free bodies. Everything else is easy, and everything is expensive. _________________ .
Wanted:
Braukuche Samba Member
Posted: Wed May 05, 2021 7:49 am Post subject: Re: Optimistic farm find |
Lind wrote: |
definitely a '66.
the hard thing to find is rust-free bodies. Everything else is easy, and everything is expensive. |
Seats are expensive, interiors are expensive, labor is expensive. If you can weld and do bodywork the repair panels are plentiful and cheap if you shop around compared to the other three items. In the end youll have something that exceeds the value of most bay windows which have fewer available panels, are more expensive and more difficult to repair. _________________ Go Reds! Smash state!
Retirement is here!
1956 Ghia
1959 SO-23 Westfalia
1960 double cab
1960 Baja Bug
1963 stretched double cab
1962 Golde sunroof Ghia
1963 356 B coupe
1963 Notchback
1967 21 window less rusty now
1973 Ghia convertible |
WildIdea Samba Member
Joined: September 17, 2016 Posts: 927 Location: Black Hills, South Dakota
Posted: Wed May 05, 2021 8:35 am Post subject: Re: Optimistic farm find |
Jetfxr69
Swoop it up and get it home! You are more than capable of going through this rig. Once you start cleaning, youll be through it in no time faster than you might think, several years, haha. These have a way of captivating interest and motivating one to complete. _________________ 1977 Sage Green Westy
https://www.thesamba.com/vw/forum/viewtopic.php?t=691987
1965 SWR Walk-Through Standard
1960 211 Panel American Camper Conversion |
AS350driver Samba Member
Posted: Wed May 05, 2021 9:24 am Post subject: Re: Optimistic farm find |
At least its got the front seats. Got to the split bus classifieds and look at seat prices. Dragged out of the weeds and pressure washed, I bet it looks awesome. Seems to have most of the glass so maybe not much rain got in to rot out the floors. |
Posted: Wed May 05, 2021 9:36 am Post subject: Re: Optimistic farm find |
I see a rear bottom maybe a back above it in the heap? _________________ 1977 Sage Green Westy
Posted: Wed May 05, 2021 10:19 am Post subject: Re: Optimistic farm find |
Again, this is not mine for the taking, but im gonna ask. He is a great friend of 30 years, albeit, apart for the last 20 on and off, and may have a soft spot for me to be the one he gives it to. His thoughts are that the monetary value means nothing to him ( his words to me one day a couple years ago), and that if he let it go, then it wouldnt be here for him to look at anymore.
Thats frustrating for all of us im sure, but its his stuff, and he is entitled to take it to the grave.
I was thinking 66 as well based on the pictures. I only know its an og engine from what he told me last time i visited. Too much shit inside to gauge the floors, but its the best looking, most complete split he has. The rest are really bad subjects.
I will be doing the work myself, following lots of tips and guidance from here of course. Im trying to build a retirement project list. I dont do well with idle time. Cheers. _________________ You can't be a real country unless you have a beer and an airline. It helps if you have some kind of a football team, or some nuclear weapons, but at the very least you need a beer. Zappa
77 westy Seamus
76 tintop Crusher
77 westy The Judge
PDX db Samba Member
Posted: Wed May 05, 2021 10:33 am Post subject: Re: Optimistic farm find |
66- white dash knobs with front doors that had pulls on the inside. (The pulls are not on the doors, but the mounting location can be seen) |
Posted: Wed May 05, 2021 12:06 pm Post subject: Re: Optimistic farm find |
Jetfxr69 wrote: |
I will be doing the work myself, following lots of tips and guidance from here of course. Im trying to build a retirement project list. I dont do well with idle time. Cheers. |
I hear you. Decide on what you like and buy now, stuff isnt getting cheaper or easier to find. Soon as I retired on went on a Ghia project buying spree, glad I bought when I did. _________________ Go Reds! Smash state!
Retirement is here!
1956 Ghia
1960 double cab
1960 Baja Bug
1963 356 B coupe
1963 Notchback
FarmerBill Samba Member
Joined: July 25, 2017 Posts: 761 Location: New England
Posted: Wed May 05, 2021 12:54 pm Post subject: Re: Optimistic farm find |
That engine, or at least the shroud and thermostat ring are 1964 or earlier. Looks like it might have a fat cap distributor too? Guessing that engine is a 40hp. |
Posted: Wed May 05, 2021 1:15 pm Post subject: Re: Optimistic farm find |
FarmerBill wrote: |
Copy, thanks. I guess as far as he knew it was og. More details to investigate. Will look up what letter code was og and verify off engine. _________________ You can't be a real country unless you have a beer and an airline. It helps if you have some kind of a football team, or some nuclear weapons, but at the very least you need a beer. Zappa
77 westy Seamus
76 tintop Crusher
77 westy The Judge
tisius Samba Member
Joined: July 11, 2011 Posts: 1570 Location: Rotterdam,NL (+Chicago,IL)
Posted: Wed May 05, 2021 1:33 pm Post subject: Re: Optimistic farm find |
Braukuche wrote: |
Decide on what you like and buy now, stuff isnt getting cheaper or easier to find. |
so true! _________________ drive it like you just robbed the bank
.... if it ain't dutch, it ain't much! |
1970PAKombi Samba Member
Joined: July 10, 2019 Posts: 264 Location: Denver, PA
Posted: Wed May 05, 2021 1:56 pm Post subject: Re: Optimistic farm find |
Certainly a cool piece, in whatever shape you can get it in, if it's possible, go for it. It will take a while to finish, but, as someone said before you'll have a nicer asset in terms of money and value later on. |
BonTonRoulet Samba Member
Joined: September 29, 2020 Posts: 356 Location: Mississippi
Posted: Wed May 05, 2021 2:56 pm Post subject: Re: Optimistic farm find |
PDX db wrote: |
Silver Beige......please.
It's fun guessing what year model these old busses are based on limited photos. I would have guessed 64-66 due to the radio hole in the dash, the fuel filler door, couldn't really see the one year only 66 hazard flasher knob, but I did pick up on the door pull spots.....and....if it has the original front doors even you guys recently schooled me on the hole in the door that matches the window frame between the vertical bolts that you can put a punch in the door to pull the frame down in place when installing it.
For me, I think the cut rear wheel arches would be hard to get past. But if it can be saved and go down the road again in it's lifetime, that's a blessing. Perhaps your friend was blessed to have you as his friend. |
Posted: Wed May 05, 2021 6:17 pm Post subject: Re: Optimistic farm find |
Damn! Didnt even notice the wheel arches. I wouldnt want those like that. Thats the kind of heads up i was hoping for. Thanks _________________ You can't be a real country unless you have a beer and an airline. It helps if you have some kind of a football team, or some nuclear weapons, but at the very least you need a beer. Zappa
77 westy Seamus
76 tintop Crusher
77 westy The Judge
