Dudewheresmyvan Samba Member
Posted: Thu May 06, 2021 9:08 pm Post subject: Wipers & power mirrors. |
I have an 89 vanagon and recently my power mirrors and front and rear wipes stopped working. I’ve changed the ignition switch, the fuses are all good and the wiring harness for the wipers looks like everything is were it should be. What am I missing here? |
kevinm Samba Member
Joined: September 08, 2008 Posts: 117 Location: Minneapolis, MN
Posted: Thu May 06, 2021 9:40 pm Post subject: Re: Wipers & power mirrors. |
Have you checked the ground tree near the fuse box? I think the ground connections for the wipers and mirrors use that ground. |
SCM Samba Member
Joined: January 26, 2011 Posts: 3118 Location: Bozeman MT
Posted: Fri May 07, 2021 7:52 am Post subject: Re: Wipers & power mirrors. |
I can't help with the wipers but you should take a look at the power mirror switch and maybe hose it down with contact cleaner.
My mirrors didn't work when I first bought my van but after enough drives with a fidgety hand constantly messing with the switch they one day just started working. I assume the contacts were corroded and using the switch eventually wore through the crud. _________________ '91 Westfalia GL Automatic (GTA "Turbo" Rebuild w/Peloquin) and 2.3L GoWesty Engine |
campism Samba Member
Joined: September 07, 2007 Posts: 4492 Location: Richmond VA
Posted: Sat May 08, 2021 5:16 am Post subject: Re: Wipers & power mirrors. |
For the power mirrors check the wiring bundle where it passes from the driver's door to the body. Wires can break from the flexing that occurs there and I had to repair mine. _________________ '87 Westy in Wolfram Grey Metallic |
DuncanS Samba Member
Posted: Sat May 08, 2021 8:08 am Post subject: Re: Wipers & power mirrors. |
Mirrors and wipers. There is no electrical correspondence between these two items, ground or hot so it has to be a coincidence. Unless something melted up under the dash and happened to fry both separate wires. Start with Bentley and your VOM and work from hot to ground until readings collapse. I often take a sewing pin and shove it through the insulation to check at various points. This is gonna take some time and cuss words to solve. But before you try too much, take a hot lead and touch it to the wires closest to the motors so see if they still move. Yes, door boot wires often fail, but the wipers? That could be a stalk issue. |
Posted: Sat May 08, 2021 11:55 am Post subject: Re: Wipers & power mirrors. |
Ok. I figured it out. Turns out it’s a failed fuse box so I’ve got one on order. By passed the panel for now so at least I have front wipers. Thx for all the comments. ✌️ |
