herbie1200 Samba Member
Joined: April 27, 2006 Posts: 833 Location: Rome - Italy
Posted: Fri May 07, 2021 1:29 pm Post subject: Steering box and rubber coupler torque recommendation |
I'm going to replace my steering box with a reconditioned one, and the coupler with a new one from Mecatechnic.
Please, are there torque recommendation to secure the steering box nuts and the bolts on the coupler?
I did not find these values on this board.
Thank you, SIMONE |
mukluk Samba Member
Posted: Fri May 07, 2021 4:04 pm Post subject: Re: Steering box and rubber coupler torque recommendation |
Never seen a torque spec listed for the steering coupler hardware, I just snug them down then line up the keyway in the castellated nut so you install the cotter key.
The steering box mount bolts are torqued to 18-22ftlb / 2.5-3.0mkg. _________________ 1960 Ragtop w/Semaphores "Inga" |
Posted: Tue May 11, 2021 5:03 am Post subject: Re: Steering box and rubber coupler torque recommendation |
@Mukluk, Thanks a lot. |
finster Samba Member
Joined: May 26, 2012 Posts: 7951 Location: north o' the border
Posted: Tue May 11, 2021 5:19 am Post subject: Re: Steering box and rubber coupler torque recommendation |
my bently has this
steering gearbox to front axle - 18 to 22 ft.lb (2.5 - 3 mkg)
coupling flange to disc/column to coupling flange - 11 ft.lb (1.5 mkg) _________________ "we're here on Earth to fart around" kurt vonnegut
nothing lasts, nothing is finished, and nothing is perfect... |
mukluk Samba Member
Posted: Tue May 11, 2021 10:09 am Post subject: Re: Steering box and rubber coupler torque recommendation |
@finster
Which Bentley? _________________ 1960 Ragtop w/Semaphores "Inga" |
Posted: Tue May 11, 2021 11:55 am Post subject: Re: Steering box and rubber coupler torque recommendation |
bentley beetle and kg for 66,67,68 and 69 page 48 of the front axle chapter _________________ "we're here on Earth to fart around" kurt vonnegut
mukluk Samba Member
Posted: Tue May 11, 2021 4:21 pm Post subject: Re: Steering box and rubber coupler torque recommendation |
Appreciate it, I couldn't find it in any of my sources including the '61-'65 Bentley. _________________ 1960 Ragtop w/Semaphores "Inga" |
