jbbugs Samba Member
Joined: September 16, 2002 Posts: 2152 Location: Behind the wheel
Posted: Tue May 11, 2021 7:16 am Post subject: Re: Remote Oil Cooler In A Beetle: Pics, Please |
croSSeduP wrote: |
IT BOLTS TO THE AXLE TUBE?! Damn. I like it. |
No. That's the torsion housing. _________________ Drag bus! http://www.youtube.com/watch?v=s2MOVmKdhX4
69 OG paint Transporter
73' Super Beetle Champcar Endurance Roadracer
Patina my ass, that's a Rust Bucket! |
GARRICK.CLARK Samba Member
Joined: June 30, 2012 Posts: 1267 Location: Lancashire UK
Posted: Tue May 11, 2021 7:44 am Post subject: Re: Remote Oil Cooler In A Beetle: Pics, Please |
Esde. We're did you get that bell housing mount from. Mine is a like yours but it's got flat steel so won't accept rubber mounts. |
esde Samba Member
Joined: October 20, 2007 Posts: 5966 Location: central rust belt
Posted: Tue May 11, 2021 8:16 am Post subject: Re: Remote Oil Cooler In A Beetle: Pics, Please |
GARRICK.CLARK wrote: |
It's part of an old Bugpack padded strap kit. I tossed the straps 20 years ago but the rear mount is way stronger than the stock one. I've got the mount tabs for the rear truss bar welded to it also. _________________ modok wrote:
Posted: Tue May 11, 2021 10:11 am Post subject: Re: Remote Oil Cooler In A Beetle: Pics, Please |
Cool. Good idea to use that mount. The VW ones are rubbish. The copy version of the original are cheap weak metal |
croSSeduP Samba Member
Joined: June 13, 2004 Posts: 1106 Location: Western Washington State
sled Samba Member
Posted: Sat May 15, 2021 5:55 am Post subject: Re: Remote Oil Cooler In A Beetle: Pics, Please |
since you're having cooling issues, you really should be running "industrial" tins to deflect some of the exhaust heat and keep the waste cooling air directed out the back like its supposed to be. Also, oil coolers are supposed to be rubber isolated.
_________________ drive your split. |
Posted: Sat May 15, 2021 1:22 pm Post subject: Re: Remote Oil Cooler In A Beetle: Pics, Please |
Where did you get those "extra" deflectors? The "sleds" are in place, but I had to grind them a bit to clear the 1 3/4" pipes. And, yeah the pipes are right under the heads and in stop and go traffic a lot of that heat will be going up into the heads/cylinders.
Why rubber mounted? Just for noise issues? I did that with my electric fuel pump because of noise. _________________ Please check my '67 sedan project progress!
http://www.thesamba.com/vw/forum/viewtopic.php?t=502253&highlight= |
74 Thing Samba Member
txoval Samba Member
Joined: January 23, 2004 Posts: 3552 Location: The Woodlands, TX
Posted: Sat May 15, 2021 4:29 pm Post subject: Re: Remote Oil Cooler In A Beetle: Pics, Please |
I’m not saying that rubber mounts aren’t better, but I ran mine with solid mounts from 2004-2020 (see first picture posted) |
Posted: Fri May 28, 2021 10:09 pm Post subject: Re: Remote Oil Cooler In A Beetle: Pics, Please |
I’m on a long road trip from where I live in Tacoma to Sacramento for Bugorama. So far oil temps haven’t gotten above 210, and head temps are around 260. I’m headed even further south after the meet, and temps in the Sacto area are supposed to be 105. Should be interesting to see what happens! _________________ Please check my '67 sedan project progress!
Pooter Samba Member
Posted: Fri Jun 04, 2021 2:14 pm Post subject: Re: Remote Oil Cooler In A Beetle: Pics, Please |
Front mount using "RX7" aftermarket oil cooler.
Big oil pump & Good Tstat with 1/2" hard lines front to back.
Cusser Samba Member
Joined: October 02, 2006 Posts: 31361 Location: Hot Arizona
Posted: Fri Jun 04, 2021 2:30 pm Post subject: Re: Remote Oil Cooler In A Beetle: Pics, Please |
Whatever you choose, don't use a shroud-mounted oil cooler. Engine won't last, especially with "thin wall" 92mm cylinders, and in Arizona heat. Except in my instance. So don't do what I do, just has worked for me since the 1970s....
Replace the oil hoses every 30 years, because mine started seeping a little at the ends at 31 years. And I used the dealer-added AC with this until about 1993. Engine lid standoffs are used.
_________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
King_vw61 Samba Member
Joined: February 03, 2018 Posts: 1383 Location: Southern California
Posted: Fri Jun 04, 2021 6:40 pm Post subject: Re: Remote Oil Cooler In A Beetle: Pics, Please |
croSSeduP wrote: |
I’m on a long road trip from where I live in Tacoma to Sacramento for Bugorama. So far oil temps haven’t gotten above 210, and head temps are around 260. I’m headed even further south after the meet, and temps in the Sacto area are supposed to be 105. Should be interesting to see what happens! |
South? how far? Prado show? _________________ 1961 Ragtop, Autocraft 2783cc for street/strip 10k miles and counting...230.84 HP to the wheels thru Muffler 13.4 to 1 on E85
https://www.instagram.com/king_vw61/?hl=en |
