steveo9007 Samba Member
Joined: April 22, 2021 Posts: 31 Location: Cornwall, UK
Posted: Sat May 08, 2021 8:51 am Post subject: Front disc brakes: What options are out there? |
What options are there to replace the front disc brakes, without having to mill or change too much, i have an early type stub axle so have the Girling twin pot calipers on at the moment.
I dont have spacers on my setup as my alloys bolt straight on so i dont want to be altering too much. _________________ 85 Autosleeper KY Engine, ALD Box |
Steve M. Samba Member
Joined: July 30, 2013 Posts: 6829 Location: Fort Lauderdale, Fl.
Posted: Sat May 08, 2021 9:11 am Post subject: Re: Front disc brakes, what options are out there |
oh man...you're not a Sambanista until you use the force!
https://www.thesamba.com/vw/search.php?q=vanagon%20front%20dusc%20brake%20mods
...and welcome to the Forum! _________________ This free advice is worth exactly what you paid for it.
Posted: Sat May 08, 2021 9:21 am Post subject: Re: Front disc brakes, what options are out there |
yeah cheers for that, i am aware how this stuff works, searching is a nightmare on these forums sometimes so its easier and more to the point of getting an answer back. instead of trawling through millions of unwarranted threads _________________ 85 Autosleeper KY Engine, ALD Box |
Franklinstower Samba Member
Posted: Sat May 08, 2021 9:23 am Post subject: Re: Front disc brakes, what options are out there |
your lucky, your in the UK so you can purchase from Epytec:
https://epytec.de/en/FilterResult/index/value/mark...ult/247227
TUV approved systems.
Paul _________________ '89 Westy - EJ25/22 Frank 4.44 5mt
'75 Miami Blue Sunroof FI Standard Bug |
Posted: Sat May 08, 2021 9:26 am Post subject: Re: Front disc brakes, what options are out there |
yeah i used them for my rear disc conversion i done, good company. Im just wondering if i can change the caliper only but keep the original disc in place. _________________ 85 Autosleeper KY Engine, ALD Box |
danfromsyr Samba Member
Joined: March 01, 2004 Posts: 15143 Location: Syracuse, NY
as far as I know, there aren't any upgrades for the early front that doesn't involve altering alot of the parts..
I run the BMW calipers w/ mercedes vented rotor arrangement
which required the services of a machinist. they're not any larger in diam, so you can use the 14in wheels. they only add ventilation to the van. which I find should have been done from the factory as stock minimal.
but someone else may chime in.. I'd be curious to know as well.
steveo9007 wrote: |
I dont have spacers on my setup as my alloys bolt straight on so i dont want to be altering too much. |
Abscate wrote: |
Posted: Sat May 08, 2021 9:29 am Post subject: Re: Front disc brakes, what options are out there |
danfromsyr wrote: |
steveo9007 wrote: |
yeah its a bit of an issue with my brick, as its an in between year so i have a late radius rod setup but with an early stub axle, i have seen some have machined the caliper mating surface down to accommodate other caliper carrier adapters to fit but im looking for a simple option. dunno why VW did this cos it causes me a headache when ordering parts for it as early and late parts have been fitted. _________________ 85 Autosleeper KY Engine, ALD Box |
Posted: Sat May 08, 2021 9:46 am Post subject: Re: Front disc brakes, what options are out there |
Looking further it looks like an option is to fit a hub conversion kit like what Gowesty do, then no more replacing the bearings when fitting new discs, but still have to overcome the caliper fitting. _________________ 85 Autosleeper KY Engine, ALD Box |
valvecovergasket Samba Member
Posted: Sat May 08, 2021 10:02 am Post subject: Re: Front disc brakes, what options are out there |
steveo9007 wrote: |
yeah cheers for that, i am aware how this stuff works, searching is a nightmare on these forums sometimes so its easier and more to the point of getting an answer back. instead of trawling through millions of unwarranted threads |
You can use Google to search the samba domain directly, lots easier than using the search on here _________________ MegaSquirt resource - SpitfireEFI.com
gone, but not forgotten: '83 tdi westy - swap thread |
MarkWard Samba Member
Joined: February 09, 2005 Posts: 17110 Location: Retired South Florida
Posted: Sat May 08, 2021 10:51 am Post subject: Re: Front disc brakes, what options are out there |
If I understand your question you have early calipers which are fixed and a piston on each side of the caliper? _________________ ☮️ |
Posted: Sat May 08, 2021 12:10 pm Post subject: Re: Front disc brakes, what options are out there |
MarkWard wrote: |
If I understand your question you have early calipers which are fixed and a piston on each side of the caliper? |
yes this is correct. these are them split in half when i refurbed them a couple years ago, and my stub axle is an early one, LCA and Radius rod are late though.
Posted: Sat May 08, 2021 12:37 pm Post subject: Re: Front disc brakes, what options are out there |
My experience is that the early caliper design is better than the later floater design. I would not be so quick to toss them if the only change desired is different calipers.
This caliper can be modified for a vented rotor by adding a spacer between the halves. Porsche 911's used this caliper for quite a few years. _________________ ☮️ |
Posted: Sat May 08, 2021 12:52 pm Post subject: Re: Front disc brakes, what options are out there |
MarkWard wrote: |
This caliper can be modified for a vented rotor by adding a spacer between the halves. Porsche 911's used this caliper for quite a few years. |
That’s interesting to know, any where I can read up on that if this is the case ?? _________________ 85 Autosleeper KY Engine, ALD Box |
Posted: Sat May 08, 2021 1:11 pm Post subject: Re: Front disc brakes, what options are out there |
If you could find a period correct 911 calipers you'd have all you needed. Basically it's just a flat plate with bolt holes through it and a place for the O rings to seat.
I looked at adding vented rotors to our 82, but the steering knuckle is right up against the disc already, so the only way to add a vented disc is for it to be on the out board side which might make it difficult to center the caliper on the wider disc using the stock mounting. _________________ ☮️ |
Posted: Sat May 08, 2021 1:15 pm Post subject: Re: Front disc brakes, what options are out there |
MarkWard wrote: |
I looked at adding vented rotors to our 82, but the steering knuckle is right up against the disc already, so the only way to add a vented disc is for it to be on the out board side which might make it difficult to center the caliper on the wider disc using the stock mounting. |
thanks for the info i will have a search. _________________ 85 Autosleeper KY Engine, ALD Box |
Posted: Sat May 08, 2021 1:23 pm Post subject: Re: Front disc brakes, what options are out there |
steveo9007 wrote: |
MarkWard wrote: |
thanks for the info i will have a search. |
i see what you mean now
Merian Samba Member
Posted: Sat May 08, 2021 1:24 pm Post subject: Re: Front disc brakes, what options are out there |
what braking problems are you having? _________________ .... |
Posted: Sat May 08, 2021 1:29 pm Post subject: Re: Front disc brakes, what options are out there |
indeed how hilly is the UK?
I didn't need updated brakes will I went to the Mountains.. real Mountains..
where before I'd have to engine brake and still have fade.. yes I flush brake fluids and replace pads before they're old/glazed..
so I went with the BMW 7 series caliper and Mercedes 300 rotor option.
https://www.thesamba.com/vw/forum/viewtopic.php?t=381146 _________________
Abscate wrote: |
Posted: Sat May 08, 2021 1:34 pm Post subject: Re: Front disc brakes, what options are out there |
Merian wrote: |
what braking problems are you having? |
not having braking problems they are good, im just looking at options that's all, i have rear disc converted my van now so they are good all round. _________________ 85 Autosleeper KY Engine, ALD Box |
Posted: Sat May 08, 2021 2:10 pm Post subject: Re: Front disc brakes, what options are out there |
[quote="valvecovergasket"]
steveo9007 wrote: |
You can use Google to search the samba domain directly, lots easier than using the search on here |
That was the Google search in the upper right of the forum index page! _________________ This free advice is worth exactly what you paid for it.
