lsilverman11 Samba Member
Posted: Sat May 08, 2021 12:00 pm Post subject: Oil Temp Gauge Worth Having? |
Hello,
Rewiring the whole bus (1970 Transporter). Main harnesses are all done, and now I'm getting ready for the add-ons. Previous owner installed an oil temperature gauge, but I'm wondering if this is worth having, or if there's a more useful gauge I could/should put there. Sending unit for this gauge is currently screwed into the oil drain plate.
Thanks,
Larry |
jakokombi Samba Member
Joined: August 15, 2010 Posts: 777 Location: Milwaukee
Posted: Sat May 08, 2021 12:04 pm Post subject: Re: Oil Temp Gauge Worth Having? |
Since I installed a cylinder head temp gauge I rarely look at the oil temp.
I won't say it's useless, but if I had just one, it would be CHT. _________________ 70 Sunroof Kombi
69 Tin Top
73 Thing
72 Baja |
k@rlos Samba Member
Joined: October 04, 2012 Posts: 485 Location: Suffolk, England
Posted: Sat May 08, 2021 12:24 pm Post subject: Re: Oil Temp Gauge Worth Having? |
I personally think VW should have fitted an oil temp gauge as standard and it would have saved a lot of engines. All watercooled cars have a temp gauge and strictly speaking vw’s are oil cooled.
I have them on my stock 1200 bug and the 2110 stroker in my bus, occasionally glance at them like I do the fuel gauge. Just my opinion, I accept others may well disagree. |
babysnakes Samba Member
Posted: Sat May 08, 2021 12:35 pm Post subject: Re: Oil Temp Gauge Worth Having? |
I have a tach, oil pressure,oil temp, and CHT. Some folks will chime in and say "you will be paranoid and watch them all the time". Not so with me. I glance at them like I glance at my mirrors. |
Randy in Maine Samba Member
Posted: Sat May 08, 2021 1:31 pm Post subject: Re: Oil Temp Gauge Worth Having? |
Depends on just where the sender is located. Personally (and assuming that all of your tinwork is good) on a Type 1 engine I would prefer to have an oil pressure gauge. |
HoboBus Samba Member
Joined: December 29, 2016 Posts: 347 Location: Massachusetts
Posted: Sat May 08, 2021 2:31 pm Post subject: Re: Oil Temp Gauge Worth Having? |
I'm in the "Gauges are good" camp.
Oil temp is a good one to have.
To me the goal should be: Tach, oil pressure, oil temp, cyl head temp.
. _________________ Salt air it ain't thin, it'll stick right to your skin,
it'll make you feel fine. Makes you feel fine.
And I wanna be there. -- Jimmy Buffett
Just a beach-oriented camping Hobo with a bus. |
aeromech Samba Member
Joined: January 24, 2006 Posts: 16961 Location: San Diego, California
Posted: Sat May 08, 2021 7:31 pm Post subject: Re: Oil Temp Gauge Worth Having? |
I have oil pressure, oil temp, voltage, and a tach. That’s just 3 wires to run front to back. The voltmeter can just use a wire from the front. Oil pressure should be high on the list. _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
Posted: Sun May 09, 2021 9:51 am Post subject: Re: Oil Temp Gauge Worth Having? |
aeromech wrote: |
I have oil pressure, oil temp, voltage, and a tach. That’s just 3 wires to run front to back. The voltmeter can just use a wire from the front. Oil pressure should be high on the list. |
Quite handy to just buy a 20' trailer light wiring harness and use those 4 wires to run to the front of the bus in a 3/8" wiring loom. |
Posted: Sun May 09, 2021 10:10 am Post subject: Re: Oil Temp Gauge Worth Having? |
Great idea on the trailer wiring. I used to own boats though and can tell you that some of that ribbon is poor quality and the insulation went to hell on me quickly so buy the good stuff _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
NASkeet Samba Member
Joined: April 29, 2006 Posts: 2958 Location: South Benfleet, Essex, UK
Posted: Sun May 09, 2021 10:33 am Post subject: Re: Oil Temp Gauge Worth Having? |
lsilverman11 wrote: |
Hello,
Thanks,
Larry |
I would definately say keep the oil-temperature gauge and add a few others for company. The following was what I had in the early-1990s, but I have some more to complement these in a revised dashboard layout.
'How To' & 'Handy Hints' > Retro-fitting supplementary gauges
http://forums.kombiclub.com/showthread.php?t=19396
_________________ Regards.
Nigel A. Skeet
http://www.vwt2oc.net |
raygreenwood Samba Member
Joined: November 24, 2008 Posts: 21513 Location: Oklahoma City
Posted: Sun May 09, 2021 11:25 am Post subject: Re: Oil Temp Gauge Worth Having? |
I think oil temp is a very good gauge to have.
However you need to understand what the "NORMAL" oil temperature range is....in order to not have paranoia issues.
With conventional oil....anything under 212* is a little too cool to keep moisture out of the oil. Over 275* for any length of time does damage to the ability of the oil to lubricate and keep film strength. So in a heavily loaded, highway driving vehicle in hot weather....225*F to 250*F....is normal.....and this is conventional oil. YOu can add about 25*F to those temps with synthetic.
There will be low spots and high spots with wind and hills. A lot of web info says 260* peak is fine...but bear in mind you may have temp gauge accuracy issues.
Driving long distance in an ACVW at 50 to 70 mph...and quick glance at the oil temp gauge as long as its below 250....should not cause a second thought.
It is also stated that oil temp gauges are only good for "trending". Thats true too! If every 5-7 minutes on a long highway trip....you sweep your eys over the gauge and its between 225 and 250...no big deal. If the last to times its been pegged at 250.....still no big deal. If one of these times on flat level ground its now at 260.....well...thats a trend. Oil temp is not dropping its rising. Slow down a little....and take a look more often.
The other issue....is where the oil temp gauge is reading the temp. Where should it be placed? Where should you read it?
I have my own opinion. I think the oil temp should be read right out of the oil cooler where it enters main gallery to feed bearings. However reading it there is difficult.
The next best is the pickup tube. the pickup tube. In my personal opinion....no other locations are important whatsoever.
Either you want to know what the oil temp is at the bearings after the cooler....or...barring that... the next best thing is to know what its temp is as its sucked into the pump...keeping in mind that the pump will add a few degrees of temperature and oil cooler will remove about 15 degrees on average.
If the oil you are reading at the intake pipe is over the max running temp of 250.....and probably much over 240.....you know you have a problem...because teh pump will add to it and the cooler can only remove so much heat.
Looking for that difference is the only thing the oil temp gauge is for....and why I think its good to have. Ray |
Posted: Sun May 09, 2021 12:16 pm Post subject: Re: Oil Temp Gauge Worth Having? |
Yes, the bearing in temp is exactly what’s important. Reading that isn’t practical in a wet sump engine. Dry sumps like turbine engines have can be read easily because you have external pipes running all over the place
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
Posted: Sun May 09, 2021 7:49 pm Post subject: Re: Oil Temp Gauge Worth Having? |
aeromech wrote: |
Well....there is a way to read the temp coming out of the oil cooler if one were of the mind to do something a little different.
It would entail cutting a small...maybe 1/2" hole in the sheet metal to access one of the two NPT pipe plugs that plug the in and out galleries on the oil cooler mount.
It would be nothing to make a bulkhead style fitting for a 6" long, bendable thermocouple probe...out of a bolt. The tip can protrude just enough to touch the oil coming out of the cooler port and not block anything. The rest of the 4" of probe can be bent out of the way and screwed or strapped down.
A 6" long J type one with a 1/8" diameter probe made of stainless steel is $23.78 from Mcmaster carr. Ray |
Posted: Sun May 09, 2021 8:00 pm Post subject: Re: Oil Temp Gauge Worth Having? |
Like most things regarding mods, anything is possible given enough time and money. Want to install a 500 hp V8 into a bus? I’ve seen it done. _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
Slip356 Samba Member
Posted: Mon May 10, 2021 5:47 am Post subject: Re: Oil Temp Gauge Worth Having? |
There’s a reason early Porsches 356 & others included an oil temp gauge.
I’ve added one on my 78 Westy along with oil pressure. Helps me determine correct oil viscosity for various seasons in No WI. 10 psi per 1000 rpm minimum. Thinking of adding cylinder head temp as well, it’s on the list. |
Jeff Geisen Samba Chaplain
Joined: December 21, 2004 Posts: 1881 Location: N.W. Georgia
Posted: Mon May 10, 2021 6:37 am Post subject: Re: Oil Temp Gauge Worth Having? |
To pick up oil temp at the cooler I use a T3 oil cooler, it has a threaded bung in the base for your temp sensor. _________________ I Corinthians 4: 1 thru 5
‘63 ragtop - ‘68 single cab |
Posted: Mon May 10, 2021 10:18 am Post subject: Re: Oil Temp Gauge Worth Having? |
Jeff Geisen wrote: |
To pick up oil temp at the cooler I use a T3 oil cooler, it has a threaded bung in the base for your temp sensor. |
Thats probabpy a good solution for the 1970 he has. It should be type 1 based.
Just so no one mistakes my earlier commet....my solution was for a,type 4. The type 3 cooler solution will not work for that. Sorry to muddy the waters.
But if you wanted.....you could probably do it the same way on a type 1 based engine if you have to. Ray |
k@rlos Samba Member
Posted: Mon May 10, 2021 10:27 am Post subject: Re: Oil Temp Gauge Worth Having? |
I always put the sender in a fitting on the outlet from a full flow pump cover where possible |
richparker Samba Member
Joined: November 24, 2011 Posts: 6982 Location: Durango, CO
Posted: Mon May 10, 2021 1:07 pm Post subject: Re: Oil Temp Gauge Worth Having? |
raygreenwood wrote: |
Great info not Ray! Is this a rule of thumb for all ACVW, T1 and T4, or just T4? _________________ __________
’71 Westy build
Adventure thread
’65 Deluxe Build
’63 Deluxe Build |
Joined: January 01, 2007 Posts: 16865 Location: sticksville, ct.
Posted: Mon May 10, 2021 2:36 pm Post subject: Re: Oil Temp Gauge Worth Having? |
whatever you do don't but VDO gauges. they are the most inaccurate fucking junk out there anymore. _________________
gprudenciop wrote: |
Jake Raby wrote: |
Brian wrote: |
