markeaton Samba Member
Joined: July 09, 2013 Posts: 686 Location: Seacoast NH
Posted: Sat May 08, 2021 3:23 pm Post subject: Seat belt question (photos included) |
All-
I should know this, yet I can't seem to find it. My deluxe has the front seat bolt locations in the first photo.
But I screwed up by putting in the walk-through rubber along the other side of the seats completely forgetting where the hole was. I am trying to "feel" it and I might have the location. Any pics of a 66-67 location?
Also, do you know what the bolt sizes are and are they the same for all holes?
Thank you
-Mark
BonTonRoulet Samba Member
Joined: September 29, 2020 Posts: 360 Location: Mississippi
Posted: Sat May 08, 2021 5:01 pm Post subject: Re: Seat belt question (photos included) |
620 x 130
The center of the holes for the seat belt mounting bolt on the sides of my walk through 66 model are 620 mm back from the leading edge of the metal trim on the front edge of the walk through, and 130 mm above the floor at that 620 point. The 620 mm is a horizontal distance, not the distance along your walk through floor. In other words, I gave you the 2 dimensions of a right triangle. Pythagoras leaves it to the student to figure out the dimension along the floor, not that you need that. |
JonL Samba Member
Joined: March 07, 2002 Posts: 308 Location: Highlands Ranch, Colorado
Posted: Sat May 08, 2021 6:18 pm Post subject: Re: Seat belt question (photos included) |
Mines a 65, maybe this will help?
_________________ 65 Notchback
65 21 Window |
JonL Samba Member
Posted: Sat May 08, 2021 6:28 pm Post subject: Re: Seat belt question (photos included) |
Here is the walk through one-
Keep in mind I have everything installed, so the measurement is not from bare metal. I hooked the tape on the front to get the 24".
I also found this, but do not have measurements at this point, but may give an idea-
65 21 Window |
hitest Samba Member
Joined: September 30, 2008 Posts: 10296 Location: Prime Meridian, ID
Posted: Sat May 08, 2021 8:34 pm Post subject: Re: Seat belt question (photos included) |
It is either accessed on the back side through the seat pedestal or from underneath the bus. From either spot- poke a thumbtack in from the backside. _________________
EverettB wrote: |
FU#5 |
EverettB Administrator
Joined: April 11, 2000 Posts: 69813 Location: Phoenix Metro
Posted: Sat May 08, 2021 9:52 pm Post subject: Re: Seat belt question (photos included) |
hitest wrote: |
It is either accessed on the back side through the seat pedestal or from underneath the bus. From either spot- poke a thumbtack in from the backside. |
Yes, the mount by the doors have a huge plate underneath.
My '63:
_________________ How to Post Photos
Posted: Sun May 09, 2021 3:53 am Post subject: Re: Seat belt question (photos included) |
Thank you all. |
Posted: Sun May 09, 2021 3:56 am Post subject: Re: Seat belt question (photos included) |
Oh, does anyone know the bolt size? Seems like a M10, but I'm not finding correct size... and I wondered if it changes with bus years? |
Posted: Sun May 09, 2021 7:57 am Post subject: Re: Seat belt question (photos included) |
JonL... the measurement pics worked spot on... thank you...
Do you know the bolt size? I tried M10x1.50 and M12x1.25 and neither fits. |
Posted: Sun May 09, 2021 8:00 am Post subject: Re: Seat belt question (photos included) |
Just found that 11mmX1.25 is the bolt size. I've never heard a M11 before... |
John Ghia Samba Member
Posted: Sun May 09, 2021 3:55 pm Post subject: Re: Seat belt question (photos included) |
I believe all seatbelt bolts are 7/16 - 20 also know as 7/16 UNF. Google seat belt bolts _________________ BUS BOYZ |
Posted: Sun May 09, 2021 6:40 pm Post subject: Re: Seat belt question (photos included) |
John Ghia wrote: |
I believe all seatbelt bolts are 7/16 - 20 also know as 7/16 UNF. Google seat belt bolts |
Yes, it's weird but they are American sizing
My Bus above has the somewhat-normal converter pieces to convert the huge hole to a standard-size mounting bolt
The alterative which I have seen a bunch of times is this large mounting "ring":
Note: This is not my Bus although it looks like it - This is a '64 Turkis Bus _________________ How to Post Photos
Posted: Mon May 10, 2021 4:19 am Post subject: Re: Seat belt question (photos included) |
Thanks you all and yes that is strange that is a SAE size and not metric.
I shall buy bolts today. |
Posted: Tue May 11, 2021 10:44 am Post subject: Re: Seat belt question (photos included) |
Well, I did pick up the 7/16 - 20. No go.
Now, they were fine thread. I wonder if there is/I should get coarse thread if that make a difference?
Hard to really know if the PO did something else to it. Worse case I tap a close size to fit. |
Posted: Tue May 11, 2021 12:45 pm Post subject: Re: Seat belt question (photos included) |
The seat belt anchor "plugs" and bolts are only $7.50 a pair. You'll need two pairs to do both seats. For that kind of coin, I wouldn't futz around with a tap and different bolts. It's not like these are what anchors your seat belt system that you might need in a crash....
https://www.westcoastmetric.com/i-22964339-111-700.html |
Posted: Tue May 11, 2021 12:52 pm Post subject: Re: Seat belt question (photos included) |
Thanks bontonroulet |
BarryL Samba Member
Joined: November 01, 2004 Posts: 14258 Location: Casa de Oro, California
Posted: Tue May 11, 2021 6:35 pm Post subject: Re: Seat belt question (photos included) |
What all is no? |
Posted: Wed May 12, 2021 4:33 am Post subject: Re: Seat belt question (photos included) |
Barry... the "no" is that the 7/16-20 did not screw in there. I stopped by Fastenal on my way home from work and grabbed both the 14 and 20 (coarse and fine) to make sure and neither fit.
Now, I didn't have time last night (wife duties called) and since the bus was painted, I want to properly clean out the threaded area of paint and try to see if that might be holding back, what should be, and easy screwing in of the bolt.
I will post what I end up doing. |
ToolBox Samba Member
Joined: January 27, 2004 Posts: 3439 Location: Detroit, where they don't jack parts off my ride in the parking lot of the 7-11
Posted: Thu May 13, 2021 8:47 am Post subject: Re: Seat belt question (photos included) |
markeaton wrote: |
Barry... the "no" is that the 7/16-20 did not screw in there. |
7\16 20 is what it should be. Who knows what has happened in 54 years of being jacked with. |
Posted: Thu May 13, 2021 8:50 am Post subject: Re: Seat belt question (photos included) |
Exactly Toolbox...... I'll be in the garage tonight and I need to clean out some residual pain in the threads to make a better assessment.... |
