markeaton Samba Member
Joined: July 09, 2013 Posts: 686 Location: Seacoast NH
Posted: Thu May 13, 2021 4:57 pm Post subject: Re: Seat belt question (photos included) |
Thanks to all. It was the 7/16-20. After I cleaned out some paint and grime it seated swimmingly well
tisius Samba Member
Joined: July 11, 2011 Posts: 1570 Location: Rotterdam,NL (+Chicago,IL)
Posted: Fri Oct 29, 2021 7:36 am Post subject: Re: Seat belt question (photos included) |
EverettB wrote: |
Yes, it's weird but they are American sizing
Could be because I think in Germany seat belts were not required by law until 1976?
Back then when the split bus was produced in Germany the largest "seatbelt equipped market" was the US one, so that is probably why they made them to fit US seatbelts?
My Austrian 1966 split bus does not have seatbelt mounts. _________________ drive it like you just robbed the bank
.... if it ain't dutch, it ain't much! |
Tizian Samba Member
Joined: February 18, 2015 Posts: 383 Location: Hamburg, Germany
Posted: Fri Oct 29, 2021 8:24 am Post subject: Re: Seat belt question (photos included) |
tisius wrote: |
EverettB wrote: |
My Austrian 1966 split bus does not have seatbelt mounts. |
Yes, seatbelts got mandatory in 1976 in Germany. And yes, the bolts are not metric...
Edit:
1974 it got mandatory for car manufacturers to install seatbelts.
1976 car passengers had to buckle up per law
Since 1984 you get fined for not using seatbelts |
donald.lemay Samba Member
Joined: March 01, 2009 Posts: 484 Location: Rhode Island
Posted: Fri Oct 29, 2021 2:00 pm Post subject: Re: Seat belt question (photos included) |
My guess is because they were installed in the United States. My original bill of sale the owner purchased his seatbelts. That means someone here had to put them in. I’m guessing in 1966 there weren’t too many metric bolts around here. _________________ 66 13 window deluxe
2085cc
9to1compression
ported polished heads 40x36 valves
010 distributor
VS 42mm exhaust
40 IDF carbs |
BonTonRoulet Samba Member
Joined: September 29, 2020 Posts: 362 Location: Mississippi
Posted: Fri Oct 29, 2021 2:13 pm Post subject: Re: Seat belt question (photos included) |
While we're on the topic, has anyone seen/found a source for the off white/ivory/nicotine yellow plastic washers that fit around the seat belt mounting bolts? I was just now looking at one from my 66 and it doesn't have a part number on either side of it, it's slightly deformed over the long years and appears to be very brittle. I think the ones at the walk through mounts are either broken or long gone.
Guessing since the seat belts were probably USA dealer installed back then, perhaps VW didn't make the components of the assemblies? |
Posted: Mon Nov 01, 2021 5:19 am Post subject: Re: Seat belt question (photos included) |
Hi BonTonRoulet-
I would call Wolfsburg West and ask them. They some times have items that are not listed.
Also, are these the items you are asking? Not in stock, but maybe call WCM and ask: https://www.westcoastmetric.com/i-22964393-111-781.html
-Mark |
