Mervo Samba Member
Joined: January 04, 2016 Posts: 75 Location: Australia
Posted: Sat May 08, 2021 11:26 pm Post subject: Limebug deck lid brackets |
Has anyone had experience with the Limebug one-piece (non-standoff) engine hood brackets? https://www.limebug.com/.../t1-beetle-single-piece.
I have spent 3 days manipulating the fit of my deck lid by adding new curved brackets, levelling the perches under the rear cowling, repairing a damaged hinge and it is now 85% right. There has to be an easier way! |
Dougy Dee Samba Member
Joined: August 21, 2004 Posts: 1669 Location: Niagara Region, CANADA
Posted: Sun May 09, 2021 1:19 pm Post subject: Re: Limebug deck lid brackets |
Lincoln was a lazy guy I used to work with.
Called him 404 Error because Linky no worky! |
Mervo Samba Member
Posted: Sun May 09, 2021 4:04 pm Post subject: Re: Limebug deck lid brackets |
Are you saying that these are not available or they don't work? |
Dan the workingstiff Samba Member
Joined: July 03, 2006 Posts: 824 Location: Downriver, MI
Posted: Sun May 09, 2021 4:54 pm Post subject: Re: Limebug deck lid brackets |
I believe he's saying, the supplied link isn't directly linked to the part your speaking of.
Neat website! _________________ '69 Beetle
'66 FG buggy
My other air-cooled's
'76 IH 1200
'75 IH 1200 |
Posted: Sun May 09, 2021 5:07 pm Post subject: Re: Limebug deck lid brackets |
˙˙˙˙ʎʞɹoM oN ʎʞuᴉ˥
sdlǝɥ sᴉɥʇ ǝdoH
˙˙˙sn∀ ɯoɹɟ ǝɹ,no⅄ |
Mervo Samba Member
Mervo Samba Member
Posted: Tue May 11, 2021 2:12 am Post subject: Re: Limebug deck lid brackets |
No feedback on my original question D Dee? |
Posted: Tue May 11, 2021 7:00 am Post subject: Re: Limebug deck lid brackets |
Sure. Only have had the adjustable Limebug brackets.
Cute design.
Not impressed.
I'll interpret this for you...
˙pǝssǝɹdɯᴉ ʇoN
˙uƃᴉsǝp ǝʇnƆ
˙sʇǝʞɔɐɹq ƃnqǝɯᴉ˥ ǝlqɐʇsnɾpɐ ǝɥʇ pɐɥ ǝʌɐɥ ʎluO ˙ǝɹnS |
hitest Samba Member
Joined: September 30, 2008 Posts: 10296 Location: Prime Meridian, ID
Posted: Tue May 11, 2021 7:56 am Post subject: Re: Limebug deck lid brackets |
They look like an aesthetic choice- not necessarily better than stock.
If manipulating the factory parts is hard, I highly doubt aftermarket would be easier or VW would have done it.
I think you simply have straightness issues of your hinge mounts on the car, the brackets, the hinges on the decklid or all of the above. Try mounting two matched, straight pieces of angle iron to the factory car body hinge mounts- have them stick out like two long fork tines parallel. Then see if those two irons remain aligned or need tweeking.
The decklid hinge alignment is also easy to check. Bolt one of those straight angle iron section between two of the decklid bolts. Then simply work the hinges. Does it bind or do the hinges roll smoothly from open to closed?
You see where I'm going with the alignment tests? _________________
EverettB wrote: |
FU#5 |
Mervo Samba Member
Posted: Tue May 11, 2021 2:02 pm Post subject: Re: Limebug deck lid brackets |
Dougy Dee wrote: |
Cute design.
Not impressed.
˙pǝssǝɹdɯᴉ ʇoN
˙uƃᴉsǝp ǝʇnƆ
You should be on the stage Dougy. Hilarious. |
Mervo Samba Member
Posted: Tue May 11, 2021 2:17 pm Post subject: Re: Limebug deck lid brackets |
hitest wrote: |
You see where I'm going with the alignment tests? |
Many thanks for the detailed reply Hitest. I had checked with my laser level and some metal flat stock, the alignment of the perches on the rear of the body and they were out in both planes (front-to-rear and side-to-side). The existing U brackets were bent as well. Adding new brackets would have done nothing of any value. I milled up a couple of ally spacers to get the perches set right and fitted new U brackets, removed the worn M6 bolts from the hinges and fitted and tapped M7x1 bolts to stop the old ones sliding in their also worn threads and last, spent lots of time aligning the height and gap of the lid. I would give it just over 8/10 now, which I can live with.
However the available new U brackets are of only fair quality and I was wondering if the design of the Limbug versions had greater strength and/or flexibility in use.
No one used them? |
