BNMike Samba Member
Joined: November 12, 2009 Posts: 333 Location: Hot Springs, SD
Posted: Sun May 09, 2021 10:14 am Post subject: Carb trouble |
Hi Folks...
Right off the top, I'm not much of a mechanic. Hermann, my Type 181, was running really well with the EMPI carb that came on him. Then...he started acting like he wasn't getting enough fuel. I checked the line, and it was flowing just fine. So, I'm thinking it must be a dirty carb. I don't believe I'm competent to fix it
So...the question is: Somewhere on here I saw information about a good carb repair man, who converts them to the screw-in fuel connection. I've searched using all the terms I can think of, but can't find the thread/address. Can somebody help? Thanks.
Mike |
Big Bull Shooter Samba Member
Joined: April 28, 2018 Posts: 460 Location: Canadian Rockies
Posted: Sun May 09, 2021 10:44 am Post subject: Re: Carb trouble |
Tim at Volkzbitz is your guy, but I think he may only work on original carbs(wich you may want to consider).
https://www.volkzbitz.com/ _________________ Where would this hobby be if no one shipped parts.
crukab
Feb. 11, 2021
Smokey says.... only you can prevent Bug fires!
zerotofifty
May 16, 2023 |
BNMike Samba Member
Posted: Sun May 09, 2021 11:07 am Post subject: Re: Carb trouble |
Big Bull Shooter wrote: |
https://www.volkzbitz.com/ |
Thanks, I'll get ahold of him and see what he says. |
BNMike Samba Member
Posted: Sun May 09, 2021 11:33 am Post subject: Re: Carb trouble |
Assuming I have to rebuild the carb myself. How do I tell which re-build kit I need?
I've started to clean it off, but I don't know where to find the model number. Here's a picture, if that helps.
I looked on 'JBugs', and the carb looks like the 34PICT-3 they show.
Mike |
Gene Kisner Samba Member
Joined: September 02, 2012 Posts: 80 Location: Fairmont, West Virginia
Posted: Sun May 09, 2021 1:11 pm Post subject: Re: Carb trouble |
Before you do anything with the carb you should replace that filthy air filter and then test drive it. That may be your entire problem if it ran properly before. If it can't breathe it won't operate correctly. |
BNMike Samba Member
Posted: Sun May 09, 2021 2:23 pm Post subject: Re: Carb trouble |
Gene Kisner wrote: |
Hi Gene...
That's a picture as I got the car. I replaced it with a stock air cleaner. It was running fine until it started acting like it wasn't getting gas, last fall.
Mike |
Posted: Sun May 09, 2021 5:38 pm Post subject: Re: Carb trouble |
Then it is time to check the fuel pump. Also, remember rubber fuel lines sometimes delaminate internally, thereby blocking liquid flow, then seem fine when you blow through them. Your buddy will always be hiding around the corner. |
FJBLF Samba Member
Posted: Sun May 09, 2021 5:54 pm Post subject: Re: Carb trouble |
BNMike wrote: |
Hi Folks...
Mike |
The one I have is an EMPY and has the screw in connection. Not a difficult thing to do, just tap and screw... Here is a link to a rebuild video on my YouTube page.
_________________ 1972 VW 181 SAFARI 1500 cc GRB Trans-axle |
BNMike Samba Member
Posted: Sun May 09, 2021 8:56 pm Post subject: Re: Carb trouble |
New fuel lines and filter were the first thing I did. The pump is working fine. |
BNMike Samba Member
Posted: Sun May 09, 2021 8:58 pm Post subject: Re: Carb trouble |
FJBLF wrote: |
Thanks, I'll take a look at it. I can tap the hole, where do I get the fitting? I've got a lathe, I can make one if I have to. |
doublecanister Samba Member
Joined: September 23, 2008 Posts: 1184 Location: Richmond, Va
Posted: Fri May 14, 2021 6:23 am Post subject: Re: Carb trouble |
Just to mention, I had a similar issue on a day trip once and the THING started bucking like it wasn't greeting enough fuel, would idle fine but under load bucking like a bronco.
Carb got cleaned twice, noticed the fuel filter fuel was purple with rust balls, ended up being the gas tank.
Old pre-ethanol tank sealer was melting and had clogged the fuel filter located in the tank and of course rust in there too.
I had to remove the tank's sending unit and look in there with a flash light to find it, just be careful if you do as it's the fuel tank and your face will be over the hole looking in. mind sparks, static electricity and such we dont want no fires!
My fix ended up being a new tank and ended up getting a pict34 carb from volksbits but I dont belive my old carb was bad just was a pic31(wrong size).
I Hope you can fix it yourself, it's a great feeling to learn how these cars go
and being able to do it yourself.
Good luck with it,
T _________________ ****************************************
2020 - Mustang Eco Boost [High Performance]
1973 - Thing
1966 - Mustang GT- Fastback
1951 - Ford F1 pickup Flathead V8 |
BNMike Samba Member
Posted: Fri May 14, 2021 8:51 am Post subject: Re: Carb trouble |
FJBLF...
Your video is very helpful. It looks like my choke spring needs adjusting, like you show. When I get out from under the 'gardening' chores, I'll have time to try that.
Mike |
Posted: Tue May 25, 2021 10:44 pm Post subject: Re: Carb trouble |
BNMike wrote: |
Mike |
You have an adapter between the carb and the manifold which would lead me to believe you might have something besides the PICT34-3 carb. |
