J.A.P.III Samba Member
Posted: Sun May 09, 2021 3:23 pm Post subject: Front caliper hard lines |
replacing my front calipers on my 89' 2.1, took to long and I can't figure out how the hard line is positioned to hook up to the flex hose. If anyone could please help with maybe a pic. that would be awesome. I started out just changing pads, turned into all new front brake system, and all around Bilstiens
Stoked! |
Ahwahnee Samba Member
Joined: June 05, 2010 Posts: 9810 Location: Mt Lemmon, AZ
Posted: Sun May 09, 2021 4:12 pm Post subject: Re: Front caliper hard lines |
Mine's an 84 but perhaps the same. Is this the line you're dealing with?
Posted: Sun May 09, 2021 4:31 pm Post subject: Re: Front caliper hard lines |
Thats the line but the caliper looks different |
jlrftype7 Samba Member
Posted: Sun May 09, 2021 5:38 pm Post subject: Re: Front caliper hard lines |
J.A.P.III wrote: |
. It should, earlier Vanagons will have a slightly different brake setup vs your later Van. But it’s a nice reference to start with. With your calipers bolted to their spindles by a single bolt as a starting point, you should be able to hold up each hardline and see which way it fits best as a link between the caliper and the flex hose.
Usually, on any vehicle , those hard bent lines are very ‘handed’ and only fit one way to a side on an axle.
Otherwise, wait for someone with a picture of the late model calipers to post a picture _________________ '68 Westy- my first VW and vehicle/Bus- long gone.- sold it to a traveling Swiss couple....
‘84 Tin Top - Hilga....Auto |
