RBEmerson Samba Member
Joined: November 05, 2011 Posts: 2108 Location: SE PA
Posted: Sun May 09, 2021 4:45 pm Post subject: Small "knobs" with nails in them. |
The knob-like things with a nail through the middle. Typically used to support shelves.
1) What's the right name for them?
2) Are they available anywhere?
3) If the answer to 2 is no, suggested alternatives? _________________ Lord, give me coffee to change the things I can change, and wine to accept the things I can't change. |
shadetreemech Samba Member
Joined: October 05, 2005 Posts: 777 Location: Claremont, CA
markswagen Samba Member
Joined: January 28, 2018 Posts: 1030 Location: san diego
Posted: Sun May 09, 2021 6:00 pm Post subject: Re: Small "knobs" with nails in them. |
i have found them to be worthless, the go missing easily, i have taken to using the same things that you'll find in your kitchen, holding the shelves up.
not sure what they a called either.
i have a strip of aluminum drilled with the correct size holes at different levels, so i can get all 4 at the same height.
they work well for me, and are very easily replaceable. _________________ markswagen {mobile mechanic} san diego area all early VW's cared for.
619 201 0310 |
Posted: Sun May 09, 2021 7:22 pm Post subject: Re: Small "knobs" with nails in them. |
That certainly suggests some possibilities but the links are all as a dead as last week's halibut.
It sounds as though the only hope is to salvage them from a parts Westy.
ADDED: Angle brackets are a common solution to supporting a shelf. Unfortunately, the choice to use a really clever, and virtually irreplaceable thing instead. Grrr... _________________ Lord, give me coffee to change the things I can change, and wine to accept the things I can't change. |
Timwhy Samba Member
Posted: Mon May 10, 2021 4:37 am Post subject: Re: Small "knobs" with nails in them. |
2 1/2" diameter is a trifle large, but a lot closer than anything else. If I come up empty with chair glides, this is Plan B.
Thanks for finding this one, and passing it along. :) _________________ Lord, give me coffee to change the things I can change, and wine to accept the things I can't change. |
DuncanS Samba Member
Posted: Mon May 10, 2021 5:22 am Post subject: Re: Small "knobs" with nails in them. |
Toothpaste cap with a hole drilled? |
Timwhy Samba Member
candyman Samba Trout Slayer
Joined: December 20, 2003 Posts: 2694 Location: Missoula MT
Posted: Mon May 10, 2021 7:32 am Post subject: Re: Small "knobs" with nails in them. |
RBEmerson wrote: |
3) If the answer to 2 is no, suggested alternatives? |
How many do you need? |
Joined: January 01, 2007 Posts: 16863 Location: sticksville, ct.
Posted: Mon May 10, 2021 7:44 am Post subject: Re: Small "knobs" with nails in them. |
these look pretty close as well
https://www.ebay.com/itm/12-SHELF-SUPPORT-BRACKETS...2097168069 _________________
gprudenciop wrote: |
Jake Raby wrote: |
Brian wrote: |
dobryan Samba Member
Joined: March 24, 2006 Posts: 16503 Location: Brookeville, MD
Povi Samba Member
Joined: January 15, 2016 Posts: 16 Location: Kernersville, NC
Posted: Mon May 10, 2021 9:06 am Post subject: Re: Small "knobs" with nails in them. |
They also use them on premade sections of laminate countertops sold at big box stores to protect the edge of the counter.
Got a counter for the garage, and harvested them _________________ 89' Westy Subaru 2.2 |
Yellow Rabbit Samba Member
Posted: Mon May 10, 2021 11:41 am Post subject: Re: Small "knobs" with nails in them. |
Seems like a super quick 3d print. |
Californio Samba Member
Posted: Mon May 10, 2021 2:47 pm Post subject: Re: Small "knobs" with nails in them. |
You can use little hollow aluminum spacers from the hardware store, with a screw through the middle. |
dgbeatty Samba Member
Joined: October 26, 2006 Posts: 702 Location: Sacramento
Posted: Mon May 10, 2021 4:41 pm Post subject: Re: Small "knobs" with nails in them. |
I have a very few spares. Curious if 3D printing them would be worthwhile? FWIW they have always worked great for me, if the hole becomes enlarged in the cabinet a touch of flexible epoxy and better than new.
If someone were desperate I could turn a few in aluminium, stainless, brass or delrin, you know for the discerning owner. _________________ Schau in das Buch |
Jeffrey Lee Samba Member
Joined: February 04, 2014 Posts: 1488 Location: Wisconsin
Posted: Mon May 10, 2021 7:03 pm Post subject: Re: Small "knobs" with nails in them. |
dgbeatty wrote: |
If someone were desperate I could turn a few in aluminium, stainless, brass or delrin, you know for the discerning owner. |
What, no titanium or carbon fiber? I'm tryin' to reduce weight here ... _________________ Camp Westfalia
Camping Tips • Newsletter • Cool Campervan Apparel
www.CampWestfalia.com |
Posted: Mon May 10, 2021 7:30 pm Post subject: Re: Small "knobs" with nails in them. |
Jeffery what color of Ti would you prefer? Perhaps a nice swirl or a heatreated theme. Of course available in a variety of alloys. Bespoke in your personally trademarked pattern, please supply sample. _________________ Schau in das Buch |
Posted: Fri May 14, 2021 6:25 am Post subject: Re: Small "knobs" with nails in them. |
candyman wrote: |
RBEmerson wrote: |
If it's not being too grabby, 8, please. These things have a habit of dropping into places where they'll never be seen again. Grrr... _________________ Lord, give me coffee to change the things I can change, and wine to accept the things I can't change. |
Posted: Fri May 14, 2021 6:35 am Post subject: Re: Small "knobs" with nails in them. |
Darn close, but not in brown. Call me picky but "cherry" just isn't happening with the grey interior. Also, it seems that there's no assurance about all pieces have the same color for the order. Odd... Or very British. (Listing is from the UK)
Yeah, 3D printing in "pretty close to right" brown strikes me as a winner. I guess the overall shape is printed, and drilled afterwards. Something of a niche item (!) but still worth considering. Another, now NLA, item that could be a winner is beige screw caps for trim. Grey caps seem to be around (I bought out a VW dealer's inventory in a bad case of hoarding), but beige? Nah. _________________ Lord, give me coffee to change the things I can change, and wine to accept the things I can't change. |
Crooked Designer Samba Member
Joined: March 22, 2018 Posts: 323 Location: Chicago, IL
Posted: Fri May 14, 2021 8:07 am Post subject: Re: Small "knobs" with nails in them. |
Yellow Rabbit wrote: |
If you don't have a printer, I'm sure Uniwerks would print them up for you if you asked nicely. _________________ '85 Westy full camper, Subaru 2.5L, 5 speed SubiGears + 5speedbus shifter kit |
