skip2th Samba Member
Joined: June 18, 2017 Posts: 30 Location: Alexandria, VA
Posted: Mon May 10, 2021 6:25 am Post subject: 1600DP What Distributor# to use? / UPDATE |
First post here after coming out of hiatus status....
I have a 1967 DC bus truck. After a few years (almost 4) of sitting idle on the project. Work began in March 2021 to finish up a "preservation" restoration. Basics: Run, Stop, Shift, Drive. Originally set out to bring my numbers matching single port engine back to life. That was put on the back burner for original German parts acquiring. A recently rebuilt engine / opportunity presented itself. I jumped on it knowing it would not be my "forever engine". Wanting only to get my project on the road and begin enjoying it. FYI: this rebuilt engine came out of: 1969 Karmann Ghia / Electric Conversion "Blue" listed for sale locally still & on this site at one point last month.
The engine breakdown:
- Case# H5768276 "68-69 type 1, 1500cc / 44bhp DIN / 53HP SAE M157 - USA"
- Engine rebuilt to stock specs (in contact with original builder / VW shop owner for over 20years back in the day)
- Engine was rebuilt with Brand New Dual Port heads (Mexico 043101375H / VW logo & "5")
- Carburetor: 34PICT-3 / aftermarket replacement - no brand name
- Distributor: "009" w/ Pertronix cap / ignition.
- Bosch Premium Spark Wires
- Autolite 425 Spark Plugs
- Has Alternator now also / no longer a Generator
- Brosol Fuel Pump (alternator style)
- 12volt Blue replacement Bosch (Mexico?) Coil
- New stock bus muffler
I am using my factory stock 1967 oil bath air cleaner. My truck is otherwise completely stock: 4 speed manual trans, Big Nut RGB's, Fuel System from the Tank all the way to the Fuel Pump is 100% Brand New...the tank, all the hard & soft lines (fuel filter in place under bus).
My questions:
I am extremely confused on what IS correct and which distributor I should buy? As the engine code for my case comes back as a "205M" distributor.
Do I get a 205(?)......OR a "034"?
And I am not even positive anymore if the 34PICT-3 should be on my engine? As it is coming back as a later model carburetor then when my engine originally was built.
Any suggestions on which (part#) German Bosch Distributor I need to get would be much appreciated. I Only want to purchase a restored German Distributor not an aftermarket Chinese one.
Lind Samba Member
Joined: November 06, 2000 Posts: 9913 Location: idaho
Posted: Mon May 10, 2021 6:43 am Post subject: Re: 1967 DC with a "H5" Type 1 Engine / Carb & Dist..What do I use?? |
Post some pics of your engine, and your M-code plate.
Get rid of the 009, and get a vacuum advance distributor that works.
Generally ignore your engine code, as your engine has been converted to dualport. _________________ .
Wanted:
Posted: Mon May 10, 2021 6:57 am Post subject: Re: 1967 DC with a "H5" Type 1 Engine / Carb & Dist..What do I use?? |
Posted: Mon May 10, 2021 7:20 am Post subject: Re: 1967 DC with a "H5" Type 1 Engine / Carb & Dist..What do I use?? |
Braukuche Samba Member
Posted: Mon May 10, 2021 7:21 am Post subject: Re: 1967 DC with a "H5" Type 1 Engine / Carb & Dist..What do I use?? |
You need a 71 up style “push/pull” distributer for a bus. The engine you built is what they used on 71 buses and 71 up Type Is.
https://oldvolkshome.wetwesties.org/ignition.htm _________________ Go Reds! Smash state!
Retirement is here!
1956 Ghia
1959 SO-23 Westfalia
1960 double cab
1960 Baja Bug
1963 stretched double cab
1962 Golde sunroof Ghia
1963 356 B coupe
1963 Notchback
1967 21 window less rusty now |
Posted: Mon May 10, 2021 7:37 am Post subject: Re: 1967 DC with a "H5" Type 1 Engine / Carb & Dist..What do I use?? |
Lind, photos uploaded you requested.
To the others:
I did NOT build this engine. The engine I am referring to above in the rather lengthy, but detailed post, came out of a 1969 Karmann Ghia, NOT a 71 bus.
What is a "push / pull" distributor? I am learning so much everyday. I am by no means an expert in this mechanical area. So I will need the replies / repair descriptions / suggestions, to be for a novice....please. |
Clara Samba Member
Posted: Mon May 10, 2021 9:12 am Post subject: Re: 1967 DC with a "H5" Type 1 Engine / Carb & Dist..What do I use?? |
While many people prefer a vac dist, the symptoms you describe are not because of a 009.
Driving with a 009 does require a different and more engaged driving style than a 205M A 009 is famous for having a flat spot when paired with your carb.
Check that the plug did not fall out of your carb. I can't see it well in the kind of far off pic. Maybe add a pic with just the engine compartment opening.
Is there fuel supply to pump? If the truck sat for years, it can have a rusty tank.
Is there crap in your fuel filter?
You may want to put a magnet down the tank to pick up rust flakes.
It is easier than pulling the tank and cleaning it out, but you can do that.
I like to put the fuel filter here, for easy access.
If it is under the bus, it is very easy to get gasoline on you when you change the filter. _________________ The Obsolete Air-Cooled Documentation Project http://oacdp.org/ |
BonTonRoulet Samba Member
Joined: September 29, 2020 Posts: 359 Location: Mississippi
Posted: Mon May 10, 2021 9:52 am Post subject: Re: 1967 DC with a "H5" Type 1 Engine / Carb & Dist..What do I use?? |
I'm going all in on a fuel delivery issue here.
1) If you used your original fuel tank without cleaning it, chances are it has trash in it that has gathered around the mesh sock at the fuel outlet inside the tank. And/or
2) These old VW's don't have a separate line into the fuel tank to act as a vent. You need air going into the tank to get gas out of the tank. The tank gets vented through the gas cap. That's why the proper gas cap is termed "Vented". When it quit on you on the road, it could have been that the tank was not getting vented via the cap and the fuel pump was pulling a vacuum on the tank. Once the vacuum overcame the pumps ability to draw fuel you get no more fuel. At that point, on the side of the road, you could have attempted to remove the fuel tank cap. If it was relatively hard to pull off and resulted in an instantaneous "whoosh" sound due to air entering the tank to equalize the previous vacuum situation, then you would realize that's your problem. And you could have driven away for a little bit with the cap back on until the process repeated itself or until the tank was empty with the cap uninstalled.
Plenty of used gas caps for sale around here in the classifieds. And a lot of them somebody drilled a hole through the top of them. That aint how you do it......
EDIT: Ok, I re-read your initial post to see that the fuel system is "all new including the tank". Did you install a new gas cap as well? |
Lind Samba Member
Posted: Mon May 10, 2021 5:08 pm Post subject: Re: 1967 DC with a "H5" Type 1 Engine / Carb & Dist..What do I use?? |
skip2th wrote: |
To the others:
With those heads and carburetor, it is a '71ish engine. Regardless of what the engine came in most recently.
That M-code plate doesn't indicate mountain gears. _________________ .
Wanted:
BarryL Samba Member
Joined: November 01, 2004 Posts: 14257 Location: Casa de Oro, California
Posted: Mon May 10, 2021 6:41 pm Post subject: Re: 1967 DC with a "H5" Type 1 Engine / Carb & Dist..What do I use?? |
Check the condition of the rubber and the clamps for tightness on your dualport boots. |
c21darrel Samba Member
FarmerBill Samba Member
Joined: July 25, 2017 Posts: 766 Location: New England
Posted: Mon May 10, 2021 7:40 pm Post subject: Re: 1967 DC with a "H5" Type 1 Engine / Carb & Dist..What do I use?? |
I also vote for rust in the tank interrupting the fuel supply. If you have rust flakes in the bowl they're probably all through the carb in the jets by now. I had a friend that pulled a 1948 Jeep out of a barn and went through 3 or 4 in line filters the first few weeks he drove it. This was after he had to remove and clean out the carb twice. I am considering putting a sediment bowl in front of the filter on my bus if i don't end up replacing the fuel tank, it should cut down on the number of filters I go through. |
Posted: Tue May 11, 2021 3:28 am Post subject: Re: 1967 DC with a "H5" Type 1 Engine / Carb & Dist..What do I use?? |
1- I am using my original VW Fuel Cap that came with my truck. It is in excellent condition. However I ordered and replaced the Cork Gasket that is underneath the cap. Once I get driving again....I will definitely check the pressure on the cap. TY for this suggestion.
2- I will also check the rubber boots on the DP intake manifolds. I have not done this. TY for this suggestion.
3- The build date on my DC is 08/09/1966. So yes I believe it is a very early built (possibly right after the workers returned from Summer Break). This is also the same date the Beatles released "Yellow Submarine" in the USA. No reverse lights, and my truck did NOT have a factory dual circuit Master Cylinder (now does). It has been interesting to read the date codes from parts I have. My original dome top fuel pump, I call my "evil fuel pump"...date is 0666.
4- Thank you for correcting me on the "Mountain Gears". I was going off of info that VWOA had sent to me with my COA. I had been told by others that sometimes they miss the mark on some of the info.
5- FUEL TANK IS A BRAND NEW UNIT. I NEVER STARTED THE ENGINE OFF THE OLD TANK. ONLY A NEW FUEL CONTAINER. NEW FUEL SENDING UNIT, NEW HARD & SOFT LINES, NEW FUEL FILTER, NEW TANK ELBOW/SOCK. The inline fuel filter is still clear with no debris.
However, as I mentioned in my original post. When I went on the shake down drive on 05/01/21. And had to pull over, I noticed a lot of small rust chips all around the inside of the engine compartment area. So much I had to use a shop rag to "sweep" them up and try to get them all (impossible) out. So I am guessing that this may be the culprit to the rust chips I found inside the carburetor when removed to clean it. I am also guessing I did not clean it thoroughly enough as there may still be something blocking the jets. My original 1967 Oil Bath Air Cleaner does have fresh oil in it, filled to the "orange/red line". |
Posted: Tue May 11, 2021 3:57 am Post subject: Re: 1967 DC with a "H5" Type 1 Engine / Carb & Dist..What do I use?? |
Just because it's a "new" tank doesn't mean it can't have rust. I bought a "new" tank for a Toyota Hi-lux that had a coat of rust in it so thick that it looked orange inside. That said it sounds like your carb was contaminated by some other means. If your filters, (air and fuel) are working properly that leaves assembly for the path for rust into the bowl. Clean out your jets and I'll bet your problem goes away. |
Lind Samba Member
Posted: Tue May 11, 2021 6:31 am Post subject: Re: 1967 DC with a "H5" Type 1 Engine / Carb & Dist..What do I use?? |
The engine also needs the metal vacuum line between the carb and distributor. Otherwise fuel will collect in the vacuum can on the distributor and make it fail. _________________ .
Wanted:
Posted: Tue May 11, 2021 12:40 pm Post subject: Re: 1967 DC with a "H5" Type 1 Engine / Carb & Dist..What do I use?? |
skip2th wrote: |
Thanks. My DC is 9/16/66, 5 weeks after yours. Also Pearl White, no reverse lites, Dual M/C. 7027859. Thats a lot of busses in 5 weeks. _________________ GhiaBuild
1967 DC build
Posted: Wed May 12, 2021 7:53 am Post subject: Re: 1967 DC What Distributor# to use? |
Yes I ordered a correct distributor metal vacuum line with the "loop". It is on the way. The hose you see in the photo was ran temporarily to try that Chinese SVDA 034.
Can anyone please.......suggest a part# for which German Bosch distributor I should be looking for? That would be most helpful. |
Joined: April 27, 2002 Posts: 6371 Location: Pentwater, Michigan
Posted: Wed May 12, 2021 8:37 am Post subject: Re: 1967 DC What Distributor# to use? |
Since you are looking for an original preservation here is what I would do. Acquire a restored 30 PICT 1 German Solex carburetor. Mate that to a restored Bosch 113 905 205 K (Bosch# 0 231 137 009)vacuum advance only distributor. This was the factory pairing in 1967. On your current engine you will need an adaptor plate between the intake and carburetor. When you switch to the earlier engine your pairing will be a perfect match and you can ditch the adaptor plate. _________________ Roads Scholar &
ryans65 Samba Member
Joined: February 16, 2016 Posts: 1259 Location: Yulee FL
Posted: Wed May 12, 2021 8:38 am Post subject: Re: 1967 DC What Distributor# to use? |
I'll look in my stash, I think I have a 205T and 205M I'm not using at the moment. |
Posted: Wed May 12, 2021 8:41 am Post subject: Re: 1967 DC What Distributor# to use? |
To be more accurate you have a 113 M and a 113 T in your stash. Every distributor VW has used is a "205". _________________ Roads Scholar &
1961 (October)Single Cab- Road Trip Workhorse |
