NRAgunnut1993 Samba Member
Posted: Mon May 17, 2021 12:27 pm Post subject: What would be a good engine swap for my 66 Beetle? |
My Beetle currently has a Brazilian made engine which I believe is 1300cc. It’s top speed is maybe 70 to 75 mph. I would like to put a bigger engine in it because with the one I currently have I cannot drive on the highway and just have to stay in town. To my understanding the later model VW buses (70s) had a bigger engine and from the research I’ve done it should just be a drop in (direct fit) replacement with no modifications made. I’m still pretty new to air cooled VW’s but I would like to make my Beetle have a top speed of at least 90 mph so I can take slightly longer trips.
Replacing my engine on the bus engine was the first thing to come to mind I would like to still keep it somewhat original without breaking the bank too much what what would yall recommend? Thank you in advance! |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76946 Location: Sneaking up behind you
Posted: Mon May 17, 2021 12:31 pm Post subject: Re: What would be a good engine swap for my 66 Beetle? |
How fast can you afford?
Type 2s had basically a Beetle engine in them to 1972 when they went to the Type 4 engine. That being said, you can fit a T4 engine in but it's not a straight bolt up. A late model 1600 T1 engine is a stock upgrade. From there you can go to a 1776 or then to a stroker 2110 and larger.
It just depends on your budget _________________ Glenn
Member #1009
#BlueSquare |
Posted: Mon May 17, 2021 12:47 pm Post subject: Re: What would be a good engine swap for my 66 Beetle? |
I wouldn’t want to spend more than a grand, but if I needed to i would. like I said I’m not trying to make my Beetle beat a Z06 on a 1/4 mile, I’m just trying to drive comfortably at 80 and more if needed on the highway to the beach or something. |
Posted: Mon May 17, 2021 12:50 pm Post subject: Re: What would be a good engine swap for my 66 Beetle? |
One thing I should’ve mentioned earlier, is what do y’all think of the Mexican Beetles say from the 90s? I’ve heard those engines are very desirable because their fuel injected and a few other things. I live very close to the Mexican border so I might be able to get ahold of one very easily, would just like y’all’s thoughts. |
Glenn Mr. 010
Posted: Mon May 17, 2021 1:02 pm Post subject: Re: What would be a good engine swap for my 66 Beetle? |
NRAgunnut1993 wrote: |
I wouldn’t want to spend more than a grand |
For $1000, you can't buy a rebuild stock 1600 longblock. you'll need to triple your budget.
I suggest looking for a used engine. _________________ Glenn
Member #1009
#BlueSquare |
Posted: Mon May 17, 2021 1:45 pm Post subject: Re: What would be a good engine swap for my 66 Beetle? |
I planned to go used in the first place, and if I need to make some modifications like rebuild the carburetor or replace some other parts I will. I’d prefer to do the work myself and save money. So it could be an old dirty engine for all I care |
KTPhil Samba Member
Joined: April 06, 2006 Posts: 34022 Location: Conejo Valley, CA
Posted: Mon May 17, 2021 1:57 pm Post subject: Re: What would be a good engine swap for my 66 Beetle? |
90 mph in an otherwise stock Beetle doesn't sound like a fun or safe driving experience!
But for better acceleration and easier trek to freeway speeds, a stock dual port 1600 will do wonders. They are so common they are the most affordable way to increase power from your single port 1300. |
Zundfolge1432 Samba Member
Posted: Mon May 17, 2021 3:31 pm Post subject: Re: What would be a good engine swap for my 66 Beetle? |
Whatever you do don’t drive a VW fast. Using the words right out of the owners manual I quote. “ Your new VW can be driven at full speed, cruising speed is full speed”
I’m running pretty much stock 74 bug 😀 I like driving it at speed, it feels good. |
