What is that noise in my Vanagon?
4Gears4Tires
4Gears4Tires is offline
PostPosted: Mon May 10, 2021 8:05 am    Post subject: What is that noise in my Vanagon? Reply with quote
I searched and didn't find an existing thread. I thought having collected noises in one area might be helpful for people trying to stop various acoustic assailants.
I'll kick it off with a slight squeaking noise. It goes ee ee eee ee, very faint, I could believe it's a front wheel bearing but doesn't change sound when turning left or right but it does go away when I push in the clutch.
'87 Syncro
Ferric Oxyhydroxide Superleggera Edition
MarkWard
MarkWard is offline
PostPosted: Mon May 10, 2021 8:18 am    Post subject: Re: What is that noise in my Vanagon? Reply with quote
Moving? In gear or neutral? With a syncro, you'll have a harder time isolating the noise. Pushing in the clutch pedal in does a couple things. One, it pushes the crankshaft against the shim pack and thrust washer. It also loads the clutch release bearing. In addition, the input shaft is disconnected from the engine.
4Gears4Tires
PostPosted: Mon May 10, 2021 10:26 am    Post subject: Re: What is that noise in my Vanagon? Reply with quote
At speed, say 40mph, and in gear when I push the clutch in the noise goes away. Gear doesn't seem to matter.
'87 Syncro
MarkWard
MarkWard is offline
PostPosted: Mon May 10, 2021 10:31 am    Post subject: Re: What is that noise in my Vanagon? Reply with quote
Try shifting to neutral and letting the clutch out. Same result? Do you have a decoupler? VC or stub? You may want to drop the driveshaft and see if the noise goes away.
4Gears4Tires
PostPosted: Mon May 10, 2021 10:35 am    Post subject: Re: What is that noise in my Vanagon? Reply with quote
No decoupler, have VC. I will try neutral and removing the driveshaft and seeing if it changes/goes away. Thanks.
'87 Syncro
