Schwenk Springs in an 86 Full Camper?
Page: Previous  1, 2
VicVan
VicVan is offline
PostPosted: Fri May 14, 2021 10:39 am    Post subject: Re: Schwenk Springs in an 86 Full Camper? Reply with quote
Whatever you did on the van is irrelevant. If you pay for an alignment, you should get an alignment. Now, before jumping to any conclusions, did the other guy not adjust the camber because
1 he checked the camber measurements, they were within specs, so they did not need further adjustment, or
2 did not check at all?
'90 Little Blue Truck, 2WD auto, FAS GenV 2.0 NA (AVH)
MarkWard
MarkWard is offline
PostPosted: Fri May 14, 2021 10:45 am    Post subject: Re: Schwenk Springs in an 86 Full Camper? Reply with quote
Ask for the print out.
Drew N
Drew N is offline
PostPosted: Fri May 14, 2021 12:44 pm    Post subject: Re: Schwenk Springs in an 86 Full Camper? Reply with quote
Totally agree... I spoke with the manager and when I get my new tires put on next wed he said they would check it. My reasoning due to the changes and work I've done was completely understood.
Drew N
Drew N is offline
PostPosted: Fri May 14, 2021 12:47 pm    Post subject: Re: Schwenk Springs in an 86 Full Camper? Reply with quote
Yeah, I asked for it and they said they didn't have one. They only print them out if a customer asks for it.
...I understand if it was somehow miraculously in spec... but I'm more guessing it was laziness. Toe and go. Typical.
Drew N
Drew N is offline
PostPosted: Thu May 20, 2021 5:28 am    Post subject: Re: Schwenk Springs in an 86 Full Camper? Reply with quote
Finally at the finish line on this project. Got the tires installed yesterday. Falken Wildpeak AT, 8 ply D range. They're 215/75r15. My originals were 205/71r15. The difference is approximately another half inch in width and about 1 1/2" taller. Although I will say, when they had the old and new ties next to each other at the shop, it seemed like the Falkens were a solid 2" taller. It does actually say 28x8.5 right on the sidewall..
After some of the typical frantic discussion by the tire shop regarding, "these won't fit, they're bigger than what the computer says, Sir we can't mount these, what does the door sticker say for tire size... WHO PICKED THIS TIRE SIZE??" ....they finally agreed to mount one... then got really quiet after trying it and mounted the rest without a peep. (story of my life... I lift all my vehicles and always go through this).
No rubbing yet that I can see. I have been driving it a bit gingerly in anticipation, but so far so good!
Between the new springs, the new spring pads (no squeeks), and now the new tires, the van drives/handles substantially better. It is just a touch stiffer ride, but the big difference is the roll/lean/diving is all gone from the suspension and now the splashy/sloppy feeling that I had with the old tires is completely gone. The stiffer 8 ply sidewalls of the new tires really make a world of difference. And despite my concern initially, they don't feel hard at all. Granted, those old bologna skins I was driving around on were pretty beat. I think they were on the very bottom of the weight rating needed for the van.
I have a long road trip this weekend (6.5 hours each way) and will be doing some back roads and campground roads at my destination so it will be a good test. The van will be fully loaded with the family, bikes, whitewater kayak, roof box and roof bag... hopefully the van demonstrates good control at highway speeds with all that non-aerodynamic crap hanging off of it. After all, that was sorta the point of all this (although it does look cool too)! Very Happy
Page: Previous  1, 2
Page 2 of 2
