waller Samba Member
Posted: Mon May 10, 2021 5:23 pm Post subject: Accessing GEN lamp |
Hi all,
I've dealt with all my wiring issues and I'm still perplexed, but based on what you've coached me with, my issue may be a bad connection at the GEN lamp, or a dying lamp. When I grounded the B+ on the alternator housing- no GEN light.
It also comes on periodically. Sometimes I turn the key, the GEN is on. Sometimes it's off. Sometimes first thing in the morning it's there, sometimes not.
My q: how do I access the GEN lamp? Is it just a matter of unscrewing the 5 screws in the trunk?
It's a 78 Super
glutamodo The Android
Joined: July 13, 2004 Posts: 26301 Location: Douglas, WY
Posted: Mon May 10, 2021 11:52 pm Post subject: Re: Accessing GEN lamp |
I'm surprised no one has answered yet. So I will...
Your question is pretty much about pulling the speedometer head out so you can access the charging lamp. To do this, you have to reach under the dash (there's probably a small square-ish plate in the way that will have to get removed) and unscrew the speedometer cable. Once the cable is disconnected, the speedometer needs to be shoved toward the steering wheel. It's only held in by a corrugated rubber sleeve. Sometimes it's easier to pull it towards the rear of the car by a couple of right-angle pick tools, one on each side.
(that metal plate in the trunk only allows access to the wiper motor and an air chamber, but NOT the speedometer)
Now, the fact that the bulb lights up sometimes and not others is a different topic. Dash bulbs seldom fail in this manner, either they work or they don't. Yes, Bosch alternators do need the small current that goes through the dash bulb to "excite" the charging circuit, so you want that bulb to be lit up before you start the car. (generators, on the other hand do not need this) _________________ Andy T.
Jimbug57 Samba Member
Joined: October 08, 2002 Posts: 817 Location: Mid Michigan
Posted: Tue May 11, 2021 4:21 am Post subject: Re: Accessing GEN lamp |
glutamodo wrote: |
Yes, Bosch alternators do need the small current that goes through the dash bulb to "excite" the charging circuit, so you want that bulb to be lit up before you start the car. (generators, on the other hand do not need this) |
I didn't know the generator didn't require that - I thought they all did, thanks.
glutamodo - I used to live close to your location. We would go to Laramie for vacations with my family because it was the "Big City". Those were the days. I miss Big Sky Country. You can't explain Big Sky to someone from the midwest flats. _________________ Repeat after me "I am smarter than metal!" |
sjbartnik Samba Member
Joined: September 01, 2011 Posts: 5986 Location: Brooklyn
Posted: Tue May 11, 2021 1:45 pm Post subject: Re: Accessing GEN lamp |
waller wrote: |
Uh, when you did what? _________________ 1965 Volkswagen 1500 Variant S
2000 Kawasaki W650 |
Starbucket Samba Member
Posted: Tue May 11, 2021 2:00 pm Post subject: Re: Accessing GEN lamp |
Have you cleaned the ground straps to the body (there is one on the front of the trans. also). Post a pic of the motor so we can see your wiring. A Bosch alt. has a plastic plate with a spade connector held in by 3 screws and there is a brush under there that might need replacing. |
