porkchop-rob Samba Member
Posted: Thu May 13, 2021 10:21 am Post subject: Re: Door speaker placement |
Globespotter wrote: |
vwwestyman wrote: |
Ha ha, we're getting way off the original question!
Not really. The original question asked if there was any problem with speaker placement, and the responses identified both problems and potential alternatives. It's a constant source of amusement when people ask questions. I think they really just want the answer - "Looks awesome. Do it!" |
There has been some alternative options offered and some good input about protecting the from moisture in the door. I expected some flack for cutting holes in the door...and y'all didn't disappoint (LOL).
I was really hoping for someone to respond about sound quality and/or aiming of the speakers. _________________ 1965 Beetle
1968 Beetle Baja (Son's First Car)
1976 Bus with Subaru (Wife's Riviera Camper) |
Globespotter Samba Member
Joined: February 16, 2012 Posts: 1770 Location: Newmarket, ON
Posted: Thu May 13, 2021 10:48 am Post subject: Re: Door speaker placement |
porkchop-rob wrote: |
vwwestyman wrote: |
I was really hoping for someone to respond about sound quality and/or aiming of the speakers. |
Did you read my post?
Mounting them on the door results in really poor sound. They face each other and sound terrible. I eventually mounted under-dash speakers - on brackets and tilted both slightly inward and up. The sound is SO much better, and no worries about speakers in the doors.
_________________ 1977 Westfalia - October 2015 - Current
1971 Super Beetle - May 2012 - Current
1979 Westfalia - 1986-1991
1971 Super Beetle - 1977-1980
1971 SB Survivor Story: https://globespotter.com/
Road Trip Thread: https://www.thesamba.com/vw/forum/viewtopic.php?t=511800&highlight=
My 77 Westy Thread: https://www.thesamba.com/vw/forum/viewtopic.php?t=647114&highlight=
http://vw-mplate.com/mcode.php?lang=EN&id=30990
https://vw-type2-id.xyz/mplate/72067382 |
Posted: Thu May 13, 2021 11:21 am Post subject: Re: Door speaker placement |
vwwestyman wrote: |
Yes, I should have followed up with a question. Sorry. How and where were your door speakers mounted?
I think a lot of people may have poor performance due to mounting too low and without enough reinforcement (due movement of door panel).
This is why I am trying to move them up onto a stronger/higher portion of the door....and I'm considering building pods or mounts to slightly angle to speakers for better imaging. _________________ 1965 Beetle
Posted: Thu May 13, 2021 11:55 am Post subject: Re: Door speaker placement |
This is why I am trying to move them up onto a stronger/higher portion of the door....and I'm considering building pods or mounts to slightly angle to speakers for better imaging. |
Good questions. Mine were lower in the door - as most people - using that existing hole, so yeah that certainly would have a negative effect on the sound. they were fairly solid, but mounted to the panel, so movement could have been an issue too.
It would be interesting to hear how good your sound is if you do end up placing them there, and if any others have placed them higher. Thanks for the context. It helps. _________________ 1977 Westfalia - October 2015 - Current
richparker Samba Member
Joined: November 24, 2011 Posts: 6981 Location: Durango, CO
Posted: Thu May 13, 2021 4:11 pm Post subject: Re: Door speaker placement |
It’s a bus, not an infinity. It’s gonna be loud on the inside and you’re gonna have external noise interference drowning out the music. Time, energy and money could be better spent installing new door seals, new window seals, installing deadening, reducing induction and exhaust noise. Basically anything you can do to reduce road noise and your music will sound better, no matter what the speakers are mounted too. _________________ __________
’71 Westy build
Adventure thread
’65 Deluxe Build
’63 Deluxe Build |
Posted: Thu May 13, 2021 7:49 pm Post subject: Re: Door speaker placement |
richparker wrote: |
It’s a bus, not an infinity. It’s gonna be loud on the inside and you’re gonna have external noise interference drowning out the music. Time, energy and money could be better spent installing new door seals, new window seals, installing deadening, reducing induction and exhaust noise. Basically anything you can do to reduce road noise and your music will sound better, no matter what the speakers are mounted too. |
This is all true and also going to be addressed....not to an SQ level build, but some deadening and noise control is for sure necessary. _________________ 1965 Beetle
aeromech Samba Member
Joined: January 24, 2006 Posts: 16961 Location: San Diego, California
Posted: Thu May 13, 2021 9:10 pm Post subject: Re: Door speaker placement |
A couple ear pods are the answer. Times are changing. The old days when you park your bus and crank up the stereo are over. Now a Bluetooth speaker and an iPhone are all it takes. No more big amps and stereos powering several speakers. I use a Bose sound link resolve out by my swimming pool and it fills the whole yard with music. No wires. No expensive hardware. Speaker technology has come a long way. I don’t have a home stereo system like the old days. My echo show fills the whole living room with sound plus does a lot more. _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
Bursch Samba Member
Joined: October 28, 2006 Posts: 448 Location: Netherlands
Posted: Sat May 15, 2021 2:45 pm Post subject: Re: Door speaker placement |
Beefed up the lower part to fit 8" woofers.
Angled the mid and high to improve soundstage
_________________ 1978 T2b ASI Riviera Plan I // Camper Special with MegaSquirt & EDIS // 091 with 5.14 R/P and Peloquins LSD
Powered by Just Kampers, German Supply, Busted Bus & Aircooled Technology
2008: Amsterdam - Beijing - Olympics -- 17.500km
2010: Amsterdam - Cape Town - FIFA World Cup -- 26.000km
2014: New York - Rio de Janeiro - FIFA World Cup -- 28.000km
Camper Special Club Member |
vwwestyman Samba Member
Joined: April 24, 2004 Posts: 5688 Location: Manhattan, Kansas, USA
