Fresh Air box refurb
Max Welton
Max Welton is offline
PostPosted: Tue May 11, 2021 11:08 am    Post subject: Fresh Air box refurb Reply with quote
The air boxes for my 67 weren't too bad. A little surface rust inside. I had them blasted and powder-coated. They look great.
What doesn't look great is the plastic parts that go inside. They have warped and just don't fit well. There were no screens so I made my own.
Got a little strong with the little M4s on the vent pivots and broke one. Had to drill that out, tap the hole and replace the screw with an M4 from Ace. No shoulder but should still work.
One thing I don't like about powder-coat is the thickness. Had to get out the dremel and needle files.
For the seals I'm trying weather-stripping. It is very soft and should work but I'm going to look for something flatter that I don't have to cut and paste.
Max
1967 Type-3 Fastback
Max Welton
PostPosted: Tue May 11, 2021 11:12 am    Post subject: Re: Fresh Air box refurb Reply with quote
Alright, not horrible. But I don't like the distorted plastic pieces.
Might be a candidate for a 3D model and print.
Max
Bobnotch
Bobnotch is offline
PostPosted: Tue May 11, 2021 11:58 am    Post subject: Re: Fresh Air box refurb Reply with quote
Max
For those seals I used pick up truck cap seal (self stick kind). Worked very well on my 65, as they are nice and soft, and conform to the shapes real nice.
Bob 65 Notch S with Sunroof
Tram wrote:
Tram wrote:
mdege
mdege is offline
PostPosted: Tue May 11, 2021 12:22 pm    Post subject: Re: Fresh Air box refurb Reply with quote
Are those seals between fresh air box and body new? And if so where did you get them?
- Michael
1963 Typ3 Notchback project
1988 Multivan Magnum 112i
Max Welton
PostPosted: Tue May 11, 2021 1:56 pm    Post subject: Re: Fresh Air box refurb Reply with quote
Thanks Bob. This looks like the stuff Steve talks about in his thread. Has a consistency like memory-foam.
Max Welton
PostPosted: Tue May 11, 2021 1:59 pm    Post subject: Re: Fresh Air box refurb Reply with quote
Michael, those are from ISP. Should work although I haven't put this all up against the car yet.
https://vwispwest.com/fresh-air-box-seal-kit-311259149ay/
Max
Max Welton
PostPosted: Tue May 11, 2021 4:02 pm    Post subject: Re: Fresh Air box refurb Reply with quote
Perfect.
Max
Bobnotch
Bobnotch is offline
PostPosted: Wed May 12, 2021 2:04 pm    Post subject: Re: Fresh Air box refurb Reply with quote
Yup, I tried that out on my T-34 first, then on my Notch after the Colorado Invasion. Worked very well, and a roll gives you multiple tries to get it right for cheap.
Tram wrote:
Tram wrote:
