brownbus2 Samba Member
Joined: October 13, 2020 Posts: 244 Location: Roanoke, VA
Posted: Wed May 12, 2021 8:48 am Post subject: Distributor condenser screw size |
The condenser screw head was stripped. Need to find a new one but couldn't find exact one at Lowes...
I found some similar sized but not the exact thread size or with the thread on just half of the screw
anyone know the size or have one to sell? _________________ formerly known as Brown_Bus
1976 FI Marino Yellow Westy |
hazetguy Samba Member
Joined: April 06, 2001 Posts: 10773 Location: iT StiNgeD iTseLf tO dEAd
Posted: Wed May 12, 2021 9:10 am Post subject: Re: Distributor condenser screw size |
which distributor, and where is the condenser located (that could determine the length you need)?
it should be a 4mm x .7 thread. it's just the length you need to be concerned about. _________________ thebucket: I invested in hoodride, now DBD won't return my call?
hazetguy: invested?
thebucket: Yeah Haze, its where people put money into a company in hopes of a return on their money |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76939 Location: Sneaking up behind you
Posted: Wed May 12, 2021 9:12 am Post subject: Re: Distributor condenser screw size |
4mm long will work for cast iron and most aluminum. You just don't want it too long or it will protrude inside and could be hit by the spinning internals.
A 5mm can work, but check it and if it touches then add a washer or 2.
_________________ Glenn
Member #1009
#BlueSquare |
Posted: Wed May 12, 2021 9:29 am Post subject: Re: Distributor condenser screw size |
You will probably have much better luck looking for screws at a hardware store instead of Lowes. |
Awesome...so that little area with no threads does not need to be on the new screw? _________________ formerly known as Brown_Bus
Joined: April 27, 2002 Posts: 6371 Location: Pentwater, Michigan
Posted: Wed May 12, 2021 7:46 pm Post subject: Re: Distributor condenser screw size |
the entire length of the screw shaft should be threaded. PM me and pay for shipping and i'll send you one. _________________ Roads Scholar &
1961 (October)Single Cab- Road Trip Workhorse |
Glenn Mr. 010
Posted: Thu May 13, 2021 1:02 am Post subject: Re: Distributor condenser screw size |
tasb wrote: |
the entire length of the screw shaft should be threaded. PM me and pay for shipping and i'll send you one. |
ACE Hardware has M4 screws for $0.10 which is a lot cheaper then the cost of mailing one since because of it being 3 dimensional it can't go in a letter envelope and would cost way more than $0.55 to mail. _________________ Glenn
Member #1009
#BlueSquare |
Posted: Thu May 13, 2021 8:55 am Post subject: Re: Distributor condenser screw size |
Glenn wrote: |
tasb wrote: |
ACE Hardware has M4 screws for $0.10 which is a lot cheaper then the cost of mailing one since because of it being 3 dimensional it can't go in a letter envelope and would cost way more than $0.55 to mail. |
A lot of hardware stores will have a box of flange head screws that are grade 10.9, that would be my choice if they have one of the correct size, thread, and length. |
