andk5591 Samba Member
Joined: August 29, 2005 Posts: 16758 Location: State College, PA
Posted: Wed May 12, 2021 12:38 pm Post subject: 78 vert door window kicks back when almost fully up |
Working on a really nice 78 vert. Passenger window frame was loose on the glass so I installed a new seal and got it all together properly. (4 ratchet straps are wonderful for this). Anyway, when you roll the window up, goes well until the last couple inches, then it starts to move back at at the top away from the vent frame. The window was messed up when the customer bought the car, so was it ever right? Who knows.
The initial thought was the regulator is not pushing the rear of the window enough. I slotted the regulator mounting holes a little and rotated the regulator slightly and it seemed to help a little, but not enough.
The bushings and all that for the window frame to regulator are in good shape. Also, when I thought I almost had it, the window pulled out of the bottom channel, so, got that back in with a little adhesive. Back to where I started.
The rear top "seal" that goes at the end of the window opening slot on tehe top of teh door is missing, so gonna see if I have one, but I really don't think that is going to help. This is the last thing I need to do on the car and I can send it home.
I did search and have not found an answer. _________________ D-Dubya Manx clone - 63 Short pan,1914.
Starbucket Samba Member
Posted: Wed May 12, 2021 3:12 pm Post subject: Re: 78 vert door window kicks back when almost fully up |
Is the felt at the top of the window pinched forcing the glass out, maybe rub a birthday candle on the felt to lube it unless the frame is pinched then you will need to pry it out. |
Posted: Thu May 13, 2021 4:59 am Post subject: Re: 78 vert door window kicks back when almost fully up |
Convertible _________________ D-Dubya Manx clone - 63 Short pan,1914.
Posted: Thu May 13, 2021 7:21 am Post subject: Re: 78 vert door window kicks back when almost fully up |
I was talking about the top of the channel the wind wing closes on. As the glass slides up that channel it would be pushed out. |
Posted: Sat May 15, 2021 10:39 am Post subject: Re: 78 vert door window kicks back when almost fully up |
I believe I found it - window was not fully seated in bottom rail. _________________ D-Dubya Manx clone - 63 Short pan,1914.
