how long has your gas water heater lasted?
Page: 1, 2, 3  Next
How long has your gas water heater lasted you
0-5 years
4%
 4%  [ 2 ]
5-10 years
12%
 12%  [ 5 ]
10-15 years
9%
 9%  [ 4 ]
15-20 years
24%
 24%  [ 10 ]
20+
48%
 48%  [ 20 ]
Total Votes : 41
crankbait09
crankbait09 is offline
PostPosted: Sun Jan 23, 2022 5:26 pm    Post subject: how long has your gas water heater lasted? Reply with quote
I have been in my home now for a year and a half. Upon moving in, I knew I would need a new water heater. Fast forward to now, and my water heater is still alive and kicking. I am now considering replacing it before it goes kaput. I am really on borrowed time right now.
My water heater has a date on it of 1988. yes, 1988! That is not a typo. So 34 years old!!!! Regardless if it had a 6, 9, or whatever year warranty, I'd say this water heater has had a good long life.
which brings me to this next question............how long has your water heater lasted you before having to replace it? can anyone beat 34 years?
1963 Ragtop
Mike Fisher
Mike Fisher is offline
PostPosted: Sun Jan 23, 2022 5:42 pm    Post subject: Re: how long has your gas water heater lasted? Reply with quote
38 years & still running for our electric hot water heater!
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
Zundfolge1432 Premium Member
Zundfolge1432 is offline
PostPosted: Sun Jan 23, 2022 6:04 pm    Post subject: Re: how long has your gas water heater lasted? Reply with quote
When the bottom falls out then you know it’s time to replace.
Abscate
Abscate is offline
PostPosted: Sun Jan 23, 2022 6:07 pm    Post subject: Re: how long has your gas water heater lasted? Reply with quote
That’s incredible for a gas water heater. 15 years is good.
.ssS!
OB Bus
OB Bus is offline
PostPosted: Sun Jan 23, 2022 6:12 pm    Post subject: Re: how long has your gas water heater lasted? Reply with quote
Depends somewhat on the water supply. In San Diego our tap water is extremely hard (500 ppm dissolved solids) so getting 12-14 years from a gas water heater is considered a long life. We spend a lot of time in a small town in the Sierras. The tap water there has <5 ppm of dissolved solids. I have seen water heaters in town that are over 45 years old. The electric one in our home up there is 29 years old.
Larry in OB
69 Westfalia and 2002 Eurovan Camper.
oprn
oprn is offline
PostPosted: Sun Jan 23, 2022 6:57 pm    Post subject: Re: how long has your gas water heater lasted? Reply with quote
Don't have one. I have a heat exchanger that transfers heat from the house hot water heating system.
I am also of the opinion that the older hot water heaters were of much superior quality just like older fridges, stoves and deep freezers. You cannot expect the same life out of a new one.
We had the stone age, the bronze age, the industrial age and now we are in the age of mass deception and mind control for corporate profit. (The mass media age)
my59
my59 is offline
PostPosted: Sun Jan 23, 2022 6:59 pm    Post subject: Re: how long has your gas water heater lasted? Reply with quote
Water heater crapped out a few months after we bought, and the replacement was going fine when we sold 10 years later.
my59: Well son, my grandfather died before I got to drive it, so does that answer your question?
Other:'12 Jetta, '77 Benz 300D, and a 74 MG Midget.
PostPosted: Sun Jan 23, 2022 10:44 pm    Post subject: Re: how long has your gas water heater lasted? Reply with quote
If I remember right the one in our current house was 17 years old when we replaced it. One of the elements had burned out, which can of course be fixed, but the bottom was showing visible exterior signs of rot 7 years earlier when something else was fixed on it and I didn't feel like having it burst a year later after we got it fixed again.
VW_Jimbo Premium Member
VW_Jimbo is offline
PostPosted: Mon Jan 24, 2022 12:17 am    Post subject: Re: how long has your gas water heater lasted? Reply with quote
Designed obsolescence! It is what it is right now.
Jimbo
TDCTDI wrote:
67rustavenger wrote:
janerick3
janerick3 is offline
PostPosted: Mon Jan 24, 2022 12:48 am    Post subject: Re: how long has your gas water heater lasted? Reply with quote
1st gas water heater (builder-installed): 7.5 years (6 yr rated)
2nd gas water heater: 7.5 yrs (10 yr rated)
3rd gas water heater (current): running on 10 years (10 yr rated)
We have hard water, but our mains were replaced in 2019 and the water quality has improved.
Thanks,
Jan K.
jspbtown
jspbtown is offline
PostPosted: Mon Jan 24, 2022 6:57 am    Post subject: Re: how long has your gas water heater lasted? Reply with quote
First water heater was 16 years old (propane on well water) and it looked and worked as good as day 1 when we sold the house. Our original builder was a stickler for energy efficiency (save the planet type guy) so I think it was a good one.
Second one is going on 15 years (propane and well) and still looks and functions like brand new.
I will probably sell this house before I need to replace it.
PostPosted: Mon Jan 24, 2022 8:43 am    Post subject: Re: how long has your gas water heater lasted? Reply with quote
How many people actually pull the maintenance on the heaters at least once a year ?
Cusser
Cusser is offline
PostPosted: Mon Jan 24, 2022 8:54 am    Post subject: Re: how long has your gas water heater lasted? Reply with quote
Very few !!!
Mostly maintenance is removing sediment from the bottom (I've had to use coat hangers to break this up, then use shop vac to pull our particles) and to replace the anode rod which is there to sacrificially donate its electrons so the steel fittings (like for water inlet/outlet fittings and heater elements on electric heaters) don't corrode and cause water leakage.
I've even made my own water inlet tube from copper pipe once the original fill tube to the bottom broke off. Yes, the sacrificial anode can be tough to remove if not checked frequently/yearly, but until the water heater leaks externally, most stuff can be fixed.
OK, my hands on: 33 years in Home #1, electric water heater, I have replaced twice myself.
Home #2 new in 2002: propane-fueled water heater has only needed replacement thermistor so the pilot light would operate properly.
Some water heaters have relatively small drain valves, so flushing out sediment can be a pain the butt !!!!
PostPosted: Mon Jan 24, 2022 9:33 am    Post subject: Re: how long has your gas water heater lasted? Reply with quote
Yes, some of the higher end tanks are stainless steel but I’ve never had one. We always go with old standbys like Bradford White or A. O. Smith
that you can buy at plumbing supply stores.
Avoid buying at big box store as they don’t know shit and are useless at answering any technical questions. We have very hard water here and the tanks last about 15 year maybe 20 but I’m not going to have one burst just to see how many pennies I could save 😀
Another option is instant hot water on demand. Upfront cost is more and it uses more fuel to operate. I have zero experience with those types.
About 20 years ago I bought top of the line at lowes and it had flame lock on the pilot light. What a POS it failed within 9 months and there was a recall. I got the new parts and it failed again within a year. Too much hassle trying to deal with big box so I pulled it and just dumped it off the back of my truck at their front door. No more new fangled technology for me I went back to tried and true builder grade A.O. Smith similar and equivalent to Bradford White.
It’s bad enough when one of these things leaks and it goes unnoticed but you can get lucky and catch it early using a kit that also alerts you via your IPhone.
Would that be nice to make temp adjustments, turn on off and have leak detection?
madmike
madmike is offline
PostPosted: Tue Jan 25, 2022 5:56 am    Post subject: Re: how long has your gas water heater lasted? Reply with quote
If you have 'Hard' water do not get a instant hot water unit,, my buddy has to clean his about every other month Rolling Eyes he sez it's a PITA too Crying or Very sad
'Black Ice'Drag Buggy 'Turbo'
Rail Buggy 1915 turbo
"If I'm ever on Life Support,UNPLUG Me, Then Plug me back In see if that Works"
obus Premium Member
obus is offline
PostPosted: Tue Jan 25, 2022 1:47 pm    Post subject: Re: how long has your gas water heater lasted? Reply with quote
this house was built in the 50s. It is running its original boiler and the gas hot water heater is from 1978!!! Shocked Shocked
one of the techs when i 1st bought the house commented that it may not be the most economical boiler but it will most likely out live me if i maintain it properly!
I dread the day the hot water heater goes. it is a monster and will most likely flood like a sob. i still need someone to put a pan under it and a pipe to run the water somewhere
66 21 window bus built 8/31/65 https://www.thesamba.com/vw/forum/viewtopic.php?t=777273
slayer61
slayer61 is offline
PostPosted: Tue Jan 25, 2022 2:36 pm    Post subject: Re: how long has your gas water heater lasted? Reply with quote
The Mrs. and I moved into the house in 2004... and it still has the same water heater. No idea how old it is?? Confused
Cusser wrote:
... Most folks are idiots when it deals with electrical !!!
3/4 race cam? What's missing, one of the lobes? Shocked
Paul
'68 Manx clone... Sears??
2276 built on AS21 case
W-125 w/ GB 1.25:1 rockers
Mahle forged pistons
CB 4340 crank
CB H beam rods
deep sump
44 HPMX
EMPI GTV 2 STG II wedge ports
CB Magna spark
1 5/8 merged collector w/ hater stinger
View user's profile Send private message AIM Address Yahoo Messenger MSN Messenger Facebook Twitter Instagram Gallery Classifieds Feedback
busdaddy
busdaddy is offline
PostPosted: Tue Jan 25, 2022 3:44 pm    Post subject: Re: how long has your gas water heater lasted? Reply with quote
I'll never know, my insurance company made me change HW tank after 20 years, and the previous one was changed about the same age to upgrade to NG from electric, neither had failed. The well pressure tanks are 47 years old though and so far so good, they say "glass lined" on them and have no bladders, fingers crossed on those since they are in a place that's going to be a pain to get at if they need replacement.
The boiler in my Mom's house is the original from 1957, they don't make em like that anymore.
Слава Україні!
Abscate
Abscate is offline
PostPosted: Wed Jan 26, 2022 12:46 am    Post subject: Re: how long has your gas water heater lasted? Reply with quote
About half the running cost vs a tank in my experience with 7 girl showers every morning. You need to run vinegar through them annually per the manual, takes about an hour
Linda’s tank last s forever but it doesn’t make hot water
.ssS!
c21darrel
c21darrel is offline
PostPosted: Wed Jan 26, 2022 12:41 pm    Post subject: Re: how long has your gas water heater lasted? Reply with quote
I bought my house in Oct. 1998. The 5-year water heater was 4 years old. Its 2022 and it is still works like the day i moved in. Its located in the garage, i wrapped it with one of those WH wraps to insulate. Other than that never drained it or touched it.
GhiaBuild
1967 DC build
Page: 1, 2, 3  Next
