ncpi Samba Member
Posted: Thu May 13, 2021 6:40 am Post subject: Recommendation for Ring Compression Tool |
Any recommendations for a good Ring Compression Tool?
TIA, Bill |
Dale M. Samba Member
Posted: Thu May 13, 2021 7:01 am Post subject: Re: Recommendation for Ring Compression Tool |
Probably something of this style, but can get quite expensive.....
This style is also used on aviation air cooled engines....
I made one from a strip of 1-1/2 wide sheet metal and reinforced grip points to use with channel locks....
Zundfolge1432 Samba Member
Posted: Thu May 13, 2021 7:13 am Post subject: Re: Recommendation for Ring Compression Tool |
On the left is the genuine Hazet tool you’ll see in the manuals. It’s meant for getting into a tight spot between the studs, even just one cylinder like a field repair on the side of the road.
Each one is a fixed size so you need multiples if you use these.
I prefer this band clamp it fits all sizes, it’s cheap and simple to use in over 40 years it’s not failed me |
c77owen Samba Member
Joined: July 07, 2017 Posts: 454 Location: Kansas City, MO
Posted: Thu May 13, 2021 8:09 am Post subject: Re: Recommendation for Ring Compression Tool |
Dale M. wrote: |
Dale |
This is the Snap-On one that I use and it works great from everything air cooled to big block Chevy and Ford |
runamoc Samba Member
Joined: June 19, 2006 Posts: 5601 Location: 37.5N 77.1W
Posted: Thu May 13, 2021 8:38 am Post subject: Re: Recommendation for Ring Compression Tool |
I've started using this tool with good results
_________________ Daily driver: '69 Baja owned 44 yrs - Plan B: '81 Rabbit Diesel LS Deluxe - Plan C: '72 Ghia
Yard Art: 2 Sandrails
Outback: '69 Ghia - '68,'69,'70,'72 Beetle - '84 Scirocco, GTI - Pair of '02 Golfs-
VW Wiring = It's just wires |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76941 Location: Sneaking up behind you
Posted: Thu May 13, 2021 8:45 am Post subject: Re: Recommendation for Ring Compression Tool |
c77owen wrote: |
Dale M. wrote: |
Dale |
I have a no name copy.. cheap and does the job. Just oil the bands well and the pistons drop right in. _________________ Glenn
Member #1009
#BlueSquare |
Posted: Thu May 13, 2021 8:53 am Post subject: Re: Recommendation for Ring Compression Tool |
runamoc wrote: |
But you have to put piston into cylinder before inserting piston & pin onto rod...
Can see this style working on cast iron block engines but seems harder to work with on a aircooled... _________________ “Fear The Government That Wants To Take Your Guns" - Thomas Jefferson.
KTPhil Samba Member
Posted: Thu May 13, 2021 9:36 am Post subject: Re: Recommendation for Ring Compression Tool |
Zundfolge1432 wrote: |
There was this time in Band Clamp...
KTPhil Samba Member
Posted: Thu May 13, 2021 9:37 am Post subject: Re: Recommendation for Ring Compression Tool |
I have used wide worm clamps, VERY carefully torqued and oiled liberally. Make sure there are no burrs or sharp edges on the clamps if you do this. |
ncpi Samba Member
Posted: Thu May 13, 2021 10:05 am Post subject: Re: Recommendation for Ring Compression Tool |
Thanks guys! Very helpful. |
txoval Samba Member
Joined: January 23, 2004 Posts: 3552 Location: The Woodlands, TX
Posted: Thu May 13, 2021 10:32 am Post subject: Re: Recommendation for Ring Compression Tool |
I use similar, just made by Total Seal.
You simply push the piston out far enough to slide the wrist pin in and install the clip. Much easier to me, but we all have our own techniques.
Dale M. wrote: |
runamoc wrote: |
Can see this style working on cast iron block engines but seems harder to work with on a aircooled... |
UK Luke 72 Samba Member
Joined: September 07, 2011 Posts: 2867 Location: Little Britain
ncpi Samba Member
Posted: Thu May 13, 2021 12:35 pm Post subject: Re: Recommendation for Ring Compression Tool |
I kinda like the idea of Band Camp...errr... Band Clamp style. There are lots out there. What is the maximum height of the band that will allow you to slide the cylinder on far enough to get the rings inside the cylinder (from the bottom of the cylinder) then pull the band off? |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31380 Location: Hot Arizona
vwracerdave Samba Member
Joined: November 11, 2004 Posts: 15309 Location: Deep in the 405
Posted: Thu May 13, 2021 3:15 pm Post subject: Re: Recommendation for Ring Compression Tool |
I was taught to use the band style clamp and for many years that is all I used. I watched somebody use the sleeve style tool and how simple and goof proof it was. Now the sleeve is all I use. _________________ 2017 Street Comp Champion - Thunder Valley Raceway Park - Noble, OK
chrisflstf Samba Member
Joined: February 10, 2004 Posts: 3446 Location: San Diego
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 9772 Location: Oregon
Posted: Thu May 13, 2021 4:28 pm Post subject: Re: Recommendation for Ring Compression Tool |
I made a similar band clamp like this.
But I used metal crate banding I got from work. It was real expensive. $0.00! _________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo! |
FreeBug Samba Member
Joined: March 12, 2012 Posts: 4278 Location: deepest, darkest Switzerland
Posted: Fri May 14, 2021 2:25 am Post subject: Re: Recommendation for Ring Compression Tool |
(Thanks Dale.M for the picture)
the advantage of these is that you can extract the compression band from behind a cylinder. The only complaint is that you really have to make sure you've squeezed down enough, and they don't cover all of the rings completely, always a gap, you just have to be more careful about how everything lines up.
If money weren't an issue, I'd get those Jaycee type things, one for each size I use, but still keep the other for "special" occasions. |
ncpi Samba Member
Posted: Fri May 14, 2021 4:44 am Post subject: Re: Recommendation for Ring Compression Tool |
Thanks everyone! Good info and pics.
...Bill |
stanthedog Samba Member
Joined: October 11, 2006 Posts: 357 Location: Portland,oregon.
Posted: Fri May 14, 2021 1:26 pm Post subject: Re: Recommendation for Ring Compression Tool |
what 67rustavenger said. same here. |
