jamesinontario Samba Member
Joined: June 06, 2018 Posts: 4 Location: Ontario, Canada
Posted: Thu May 13, 2021 9:07 am Post subject: dometic fridge parts - help - need thermocouple |
does anyone know where to source a new or good used theromocouple for late model Dometic 3-way fridge? mine is 89. my theromocouple needs to be replaced. thanks (location Ontario, Canada) _________________ '89 Westie, EJ2.5 RJES conversion, RMW header, Small car pan |
khughes Samba Member
Joined: July 13, 2013 Posts: 747 Location: Phoenix AZ
Posted: Thu May 13, 2021 10:52 am Post subject: Re: dometic fridge parts - help - need thermocouple |
jamesinontario wrote: |
does anyone know where to source a new or good used theromocouple for late model Dometic 3-way fridge? mine is 89. my theromocouple needs to be replaced. thanks (location Ontario, Canada) |
Maybe someone else has the part # for a retrofit, but as I read the manual, the TC only does two things: it provides enough current for the current sensor in the gas shutoff valve to remain open, and it provides enough voltage to illuminate the flame indicator.
For these features, you could fabricate your own with an off the shelf Type J or K. Either should work I would think and readily available. _________________ '86 Westy FAS GenV Turbo (Marvin) |
Californio Samba Member
Posted: Thu May 13, 2021 11:27 am Post subject: Re: dometic fridge parts - help - need thermocouple |
The original are hard to find. Yes, you can adapt an ordinary thermocouple from the hardware store, but you'll have to change the fittings that hold it in. I forget exactly what that amounted to but it isn't hard. Alternatively, Dometics come up regularly for sale cheap or free, so cannibalize one? |
puchfinnland Samba Member
Joined: December 26, 2005 Posts: 279 Location: Deale Maryland
Posted: Thu May 13, 2021 5:36 pm Post subject: Re: dometic fridge parts - help - need thermocouple |
send me a message, I stripped down 2 working fridges and have the parts, I may have a used thermo couple _________________ ABYC marine master technician , EX European auto technician, new business- EASTCOASTWEST , custom work on campers, only systems, no mechanical |
jimf909 Samba Member
Posted: Thu May 13, 2021 5:40 pm Post subject: Re: dometic fridge parts - help - need thermocouple |
Folks try to give the dometics away often enough so a part may become available. _________________ - Jim
Abscate wrote: |
dgbeatty Samba Member
Joined: October 26, 2006 Posts: 702 Location: Sacramento
Posted: Fri May 14, 2021 7:30 am Post subject: Re: dometic fridge parts - help - need thermocouple |
Looking through my stash I found a new thermocouple still in the original package, $90. Also a "new looking" used, test good, $50. Shipping included in the lower 48.
Also have a rough looking, but test good, $-gratis. Just pay shipping. _________________ Schau in das Buch |
