dkoesyncro Samba Member
Posted: Fri May 14, 2021 8:02 am Post subject: 1.8T questions? |
I'm into my swap and would like to know the opinions of those who are driving on the 1.8T conversion (06A) ; What coolant lines they are using? IMO the longitudinal from a Passat or Audi make the most sense, however the assembled kits from the vendors are using the transverse stuff? |
xoo00oox Samba Member
Joined: February 11, 2010 Posts: 2672 Location: East Nassau, NY
Posted: Fri May 14, 2021 9:01 am Post subject: Re: 1.8T questions? |
The longitudinal coolant parts are much easier to work with just like the longitudinal motor mount parts when putting these in the vans.
On my red Westy 1.8t there where no coolant pipes at all when I got it, I ran 1 1/4 FlexFab hose all the way from the engine up to the radiator.
I have worked on many of the SAH conversions and while they did do an extremely nice job building that kit, it seems to me like there was a LOT more work done than needed to be done if they had just used the Passat and Audi A4 parts rather than the Jetta/Golf/Beetle/TT parts. The engine it inline in the van, not transverse, it just makes sense.
https://www.hpcouplers.com/products/flexfab-5526-1...-hose-1-25 |
revolution337 Samba Member
Joined: May 23, 2009 Posts: 372 Location: Pennsylvania
Posted: Fri May 14, 2021 9:27 am Post subject: Re: 1.8T questions? |
I went the same route as Andrew, by using marine grade flex hose for all of my cooling lines. My van was air-cooled, so there were no existing coolant lines to being with. I found the rubber hose was much easier to work with, as opposed to buying stainless pipes.
This is what I used, Gates Green Stripe heater hose, p/n 28445.
https://www.gates.com/us/en/fluid-power/engine-hos...04411.html
Only sold in 50ft rolls, so I had some extra. But it was still cheaper than buying stainless pipes. _________________ 1982 Westfalia AEB 1.8t
2017 VW Golf Sportwagen
2001 Audi A4 4.2 V8 swapped
2000 BMW Z3 roadster
-Mark |
