Sonny29 Samba Member
Joined: November 12, 2018 Posts: 44 Location: Valdosta,Georgia
Posted: Fri May 14, 2021 8:15 am Post subject: Need heating tins |
Is there a good diagram showing each heating tin for a type 4 engine? I have a 1976 Bay missing the left and right belly tins. Also, any suggestion on where to buy or find them. _________________ Ain’t nothing to it but to do it! |
mccandmore Samba Member
Joined: July 19, 2017 Posts: 15 Location: St. Louis, MO
Posted: Fri May 14, 2021 8:50 am Post subject: Re: Need heating tins |
I had good luck getting those parts from Busted Bus (bustedbus.com). They have parts diagrams on their site. Here's a link for the engine tin (it sounds like you need items 20 and 21):
https://bustedbus.com/images/microfiche/t201000.gif
McCandmore |
Posted: Fri May 14, 2021 2:18 pm Post subject: Re: Need heating tins |
Thanks I will check it out. _________________ Ain’t nothing to it but to do it! |
Posted: Fri May 14, 2021 8:42 pm Post subject: Re: Need heating tins |
Most of the tins are primarily for cooling the engine and not heating anything. They are there to keep your air cooled engine from suffering a melt down or other heat related problem and are not there to provide creature comfort. |
Jetfxr69 Samba Member
Joined: December 28, 2018 Posts: 1293 Location: White mtns nh
Posted: Sat May 15, 2021 7:43 pm Post subject: Re: Need heating tins |
Even if you just make up some bent tin pieces and screw em in for now, you will be saving your motor from premature destruction due to improper cooling air flow, and excessive road heat cooking the bottom of the jugs. _________________ You can't be a real country unless you have a beer and an airline. It helps if you have some kind of a football team, or some nuclear weapons, but at the very least you need a beer. Zappa
‘77 westy Seamus
‘76 tintop Crusher
‘77 westy The Judge
‘72 tintop bastard westy Hudson |
