jocoman Samba Member
Joined: August 11, 2016 Posts: 427 Location: Ottawa, Canada
Posted: Fri May 14, 2021 9:34 am Post subject: Rostra universal cruise brake switch help |
Hi folks.
I'm taking a stab at installing the universal cruise control system.
I am fabbing a switch holder for a brake switch and a switch holder for the clutch switch.
Rostra want to see a ground on the violet lead when the cruise is engaged.
I picked up a universal normally closed stop light switch.
It is normally closed however when installed and riding the brake lever it is open.
I can't see how I can supply a ground when the brake is not used.
I think I need a normally open stop light switch that is closed when installed on the brake pedal to make this thing work.
Is there such a thing?
Txs _________________ '86 Westfalia 2.0L Zetec
'97 Volvo 850 AWD Turbo
" The fun never stops" |
MarkWard Samba Member
Joined: February 09, 2005 Posts: 17155 Location: Retired South Florida
Posted: Fri May 14, 2021 10:49 am Post subject: Re: Rostra universal cruise brake switch help |
Yes, the clutch pedal switch should open when the pedal is depressed. The brake switch if you need to provide a continuous ground for the cruise, it should work like the clutch pedal switch.
It's opposite of how a mechanical brake light switch works. It completes the circuit when the bayonet comes out. So, you'd be looking for clutch pedal switches not brake pedal switches if I understand your question. _________________ ☮️ |
Posted: Fri May 14, 2021 11:19 am Post subject: Re: Rostra universal cruise brake switch help |
Yes, exactly!
I can't easily find one on-line in Canada yet.
Posted: Fri May 14, 2021 11:22 am Post subject: Re: Rostra universal cruise brake switch help |
Bayonet switch “normally closed” _________________ ☮️ |
Posted: Fri May 14, 2021 12:11 pm Post subject: Re: Rostra universal cruise brake switch help |
Can you look up an appropritae switch for me on Digikey?
I was overwhelmed with so much choice when i looked.
Amazon up here had nothing quick.
txs _________________ '86 Westfalia 2.0L Zetec
jlrftype7 Samba Member
Posted: Fri May 14, 2021 12:41 pm Post subject: Re: Rostra universal cruise brake switch help |
not sure if this one is of use for you, but it's available off amazon seller. Looks Generic enough for 2 flat pins with your wiring, and easy enough to cobble a mounting brake for the stem mounting section.
https://www.z1motorsports.com/switches/nissan/oem-...10345.html _________________ '68 Westy- my first VW and vehicle/Bus- long gone.- sold it to a traveling Swiss couple....
‘84 Tin Top - Hilga....Auto |
jimf909 Samba Member
Posted: Fri May 14, 2021 1:21 pm Post subject: Re: Rostra universal cruise brake switch help |
Rostra sells a clutch disengagement switch kit 250-4206 and it's available at many online sellers...
https://www.google.com/search?q=rostra+cruise+cont...p;ie=UTF-8
Here's a pic of it installed on my van...
For the brake switch, connect the Rostra purple to the Red/Black on the brake switch at the master cylinder. Given the VW brake switch is a pressure switch and it doesn't illuminate the brake lights until some pressure is applied I use the clutch to disengage the cruise 95% of the time.
I have my dash apart, here's the purple connected to the red/black...
Here are the install instructions with wiring suggestions...
http://rostra.com/manuals/250-4206_Form2391A.pdf _________________ - Jim
Abscate wrote: |
Posted: Fri May 14, 2021 1:41 pm Post subject: Re: Rostra universal cruise brake switch help |
Thank you very helpful. _________________ '86 Westfalia 2.0L Zetec
Posted: Sat May 15, 2021 11:23 am Post subject: Re: Rostra universal cruise brake switch help |
jocoman, I realize you pm'd me with questions so I'll answer them in your thread for visibility...
jocoman wrote: |
Hi Jim
So...
I am looking for some pics.
Specifically:
1) how you mounted the unit . I found one pic and I like the chosen spot and how you routed the cable.
2) how you attached to the TB.
Also did you have to splice extra lengths of wire so that you could get the signals up to the cab?
Any insight would be appreciated.
For the wire, I spliced in a 6(?) wire bundle in a sleeve to extend the wires to the front.
I'll post some better photos today, including the dip switch settings.
Controller installed...
Abscate wrote: |
Posted: Sat May 15, 2021 11:55 am Post subject: Re: Rostra universal cruise brake switch help |
Oh thank you.
I am using the Rostra VSS with 2 magnets.
I have the vss mounted on the passenger side and the control unit mounted like you.
I would love to get the settings. Rostra tech said use 2 magnets and 2000 ppm.
No idea if that is ball park or not.
I am running a zetec as well.
Can't wait to try it out, but I still have a lot of wiring to do and it takes a while to do a decent job.
thanks again
Jim _________________ '86 Westfalia 2.0L Zetec
Posted: Sun May 16, 2021 7:56 am Post subject: Re: Rostra universal cruise brake switch help |
To extend the wires from the engine bay I used Ancor 8 conductor signal wire:
https://www.ancorproducts.com/en/158010
West Marine sells it by the foot...
https://www.westmarine.com/buy/ancor--20-8-round-signal-cable-by-the-foot--541748
The RF receiver box that receives signals from the wireless steering wheel control and cutoff switches and the Ancor wire...
Routed through the grommet below the vents...
[/img] _________________ - Jim
Abscate wrote: |
Posted: Sun May 16, 2021 2:09 pm Post subject: Re: Rostra universal cruise brake switch help |
Dip switch positions...
Mounting bracket...
Throttle body...
Abscate wrote: |
Posted: Mon May 17, 2021 4:03 am Post subject: Re: Rostra universal cruise brake switch help |
Great thank you.
What are you using for VSS? I am going with the Rostra and 2 magnets.
Cheers _________________ '86 Westfalia 2.0L Zetec
