samm1 Samba Member
Joined: August 20, 2012 Posts: 217 Location: Saskatoon,Sask.
Posted: Fri May 14, 2021 10:24 am Post subject: New Carb |
So, I just got this today and opened the box for a look. I noticed right away the position of the accelerator pump. It’s way off the the end. All my other carbs are in the center or slightly to the right or left of center. They claim this Carb is supposed to be better than all those chinese carbs. It’s listed as a new product. Just wondering if anyone else that ordered one has the same setting.
_________________ Hella ya! |
Matt Wilson Samba Member
Joined: November 14, 2005 Posts: 2408 Location: Colorado
Posted: Fri May 14, 2021 10:32 am Post subject: Re: New Carb |
Like any new carburetor, you probably need to open it up, and check and clean stuff, install the jets you needs, and check accel. pump squirt volume, which is adjusted with the screw/linkage section you show. _________________ 1972 Standard Beetle
1969 Baja Beetle |
ashman40 Samba Member
Joined: February 16, 2007 Posts: 15982 Location: North Florida, USA
Posted: Fri May 14, 2021 10:52 am Post subject: Re: New Carb |
Unless the advertisement claimed they had test run every carb I wouldn't loose sleep over how the screws were placed.
Just as I would not assume the adjustment screws for the throttle arm, bypass screw or volume screw were spot on.. I would not assume the accelerator pump adjustment was correct out-of-the-box. Center the screw in the accelerator pump adjustment range and make sure there is no play anywhere in the linkage. After cleaning out the carb to make sure there is no dust clogging passages, set all your screw adjustments to their initial positions and follow the tune-up steps to fine tune.
While you are at it, make sure all screws and screw in jets are snug. Often some will be crazy loose when pulled from the box. Your role as the installer is to make sure they are not. _________________ AshMan40
glutamodo The Android
Joined: July 13, 2004 Posts: 26315 Location: Douglas, WY
Posted: Fri May 14, 2021 4:16 pm Post subject: Re: New Carb |
That's on the Plus side, and it probably does not need to be there. You might end up impacting your fuel economy negatively.
New carbs "shouldn't" have issues with play in the accelerator pump linkage like worn German carbs do.
But I still look for it, I always adjust the linkage so that all play is taken up, regardless of where it falls on the dial. You want the spray to start as soon as you open the throttle lever. I've seen it where German carbs needed to be adjusted all the way on the MINUS side to ensure no play in the linkage. (Why do you want no play? Well, to avoid the dreaded "flat spot" on acceleration.)
I replaced that linkage with one much less worn (and the generator style) and it ended up here, still on the minus side but not as far...
_________________ Andy T.
samm1 Samba Member
Posted: Fri May 14, 2021 4:54 pm Post subject: Re: New Carb |
Ok thanks all for the reply’s 👍🏽 _________________ Hella ya! |
