Steve M. Samba Member
Joined: July 30, 2013 Posts: 6833 Location: Fort Lauderdale, Fl.
syncrodoka Samba Member
Joined: December 27, 2005 Posts: 12008 Location: Santa Cruz, CA
Posted: Fri May 14, 2021 3:55 pm Post subject: Re: Window scraper seals leak. |
Yup. That is the reason for the drain holes and plastic that is stuck to the door behind the door panel. |
Crooked Designer Samba Member
Joined: March 22, 2018 Posts: 323 Location: Chicago, IL
Posted: Sat May 15, 2021 7:52 am Post subject: Re: Rain water getting past the Wndow Scraper seals. |
Wait. So it is supposed to do that? _________________ '85 Westy full camper, Subaru 2.5L, 5 speed SubiGears + 5speedbus shifter kit |
Joined: January 01, 2007 Posts: 16885 Location: sticksville, ct.
Posted: Sat May 15, 2021 8:27 am Post subject: Re: Rain water getting past the Wndow Scraper seals. |
Crooked Designer wrote: |
Wait. So it is supposed to do that? |
yes. any non fixed moving window has to leak like that, there is no choice in the matter.
if you have a car with a sunroof....it leaks.... into a tray which collects the water and pisses it out of the 4 corners of the sunroof tray down tubes and out the bottom of the car
same with convertibles (well, modern ones) the top sits into a tub that allows water to collect and be redirected out of the car
a lot of people don't realize how much water comes in like that _________________
gprudenciop wrote: |
Jake Raby wrote: |
Brian wrote: |
Posted: Sat May 15, 2021 11:16 am Post subject: Re: Rain water getting past the Wndow Scraper seals. |
skills@eurocarsplus wrote: |
a lot of people don't realize how much water comes in like that |
Guess I need to put my speakers in a plastic bag. _________________ '85 Westy full camper, Subaru 2.5L, 5 speed SubiGears + 5speedbus shifter kit |
jlrftype7 Samba Member
Posted: Sat May 15, 2021 12:41 pm Post subject: Re: Rain water getting past the Wndow Scraper seals. |
Guess I need to put my speakers in a plastic bag. |
Crutchfield and others sell nice foam enclosures that protect speakers mounted in doors or other water prone areas.
Really easy to install and generally very inexpensive too
For reference,
https://www.crutchfield.com/p_696B050331/Boom-Mat-6-1-2-Speaker-Baffles-Slim-line-2-1-2-depth.html _________________ '68 Westy- my first VW and vehicle/Bus- long gone.- sold it to a traveling Swiss couple....
‘84 Tin Top - Hilga....Auto |
16CVs Samba Member
Joined: February 22, 2004 Posts: 4026 Location: Redwood City, California
Posted: Sat May 15, 2021 12:48 pm Post subject: Re: Rain water getting past the Wndow Scraper seals. |
Those widow scrapers are not designed to shed water. They cover the door edge and keep twigs and large debris out as well as place to rest your arm while driving.
Years ago Pioneer used the include a plastic half round water cover that fit between the speaker and the panel that would shed water. Although the speakers are up behind the vent vent window assembly there is still an amazing amount of water that comes in.
There should always be a vapor barrier on a door. If you look at a Vanagon door you will see some weep holes on the inside stamping. The vapor barrier attaches to the flat part and then in the cavity he water comes in and hits the vapor barrier and then runs out the bottom of the door.
I like to use 3 mil plastic and attach it with Construction Adhesive. It works well because it stick to anything and can be applied over. When You have to get into you just cut it with a razor blade and then re glue.
Stacy _________________ 1987 Syncro Westfalia Triple knob (bastard)
Samba member # 14980
Don't let your van end up in an "abortions" thread. |
Posted: Sat May 15, 2021 2:23 pm Post subject: Re: Rain water getting past the Window Scraper seals. |
If you do not have the vapor barrier/plastic sheet and your interior door panels are not flat this is the reason why! _________________ This free advice is worth exactly what you paid for it.
