santo Samba Member
Posted: Sat May 15, 2021 2:46 pm Post subject: Dog House oil cooler |
What is your opinion on replacing the upright oil cooler for a dog house cooler on an earlier engine? good idea? No? I know it takes more than just the cooler.
the engine is a HO 1500
thanks |
Tim Donahoe Samba Member
Joined: December 08, 2012 Posts: 11740 Location: Redding, CA
Posted: Sat May 15, 2021 3:03 pm Post subject: Re: Dog House oil cooler |
Santo, I bought a single-cab bus that had had a fairly new engine but ran very hot. The engine builder placed an aftermarket oil cooler in front of the fan opening. Hot, hot, hot!
I switched to a doghouse arrangement, and the difference in oil temperature was amazing. And, with the doghouse, offset oil cooler, and larger fan, I wasn’t pre-heating the cooling air for number 3 cylinder that an upright cooler would have done.
Do it! You won’t regret it.
Tim _________________ Let's do the Time Warp again!
Richard O'Brien |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31361 Location: Hot Arizona
Posted: Sat May 15, 2021 3:55 pm Post subject: Re: Dog House oil cooler |
santo wrote: |
thanks |
Yes, I think it's a good idea if done correctly. Either get a captive insert for the case at top left, or take off the two small tins to access the mounting nut.
Tim Donahoe wrote: |
Tim |
I've used an external oil cooler over the fan opening on my 1835cc DP engine since back in 1976, and it's worked fine for me. Arizona, and with dealer-added AC.
Remember that doghouse stuff was hard to find and costly back in 1976; just saying that this is what I run in my 1971, with lid standoffs, not really recommending this to others. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
gt1953 Samba Member
Posted: Sat May 15, 2021 4:04 pm Post subject: Re: Dog House oil cooler |
Do it correctly, add the dog house oil cooler, make sure you have the proper components as well as the thermostat and flaps if you do not have them. _________________ Volkswagen: We tune what we drive.
72 type 1
72 Squareback
santo Samba Member
Posted: Sat May 15, 2021 4:56 pm Post subject: Re: Dog House oil cooler |
Got it, Thank you, guys!! |
Airstream65 Samba Member
Joined: January 28, 2019 Posts: 172 Location: Tulsa,Ok
Posted: Sun May 16, 2021 10:39 am Post subject: Re: Dog House oil cooler |
I recently did a doghouse conversion on my stock 67 1500, made a big difference. I sourced German tin and used a Hoover bit and sealed the cooler pieces correctly. |
Starbucket Samba Member
Posted: Sun May 16, 2021 11:44 am Post subject: Re: Dog House oil cooler |
Don't buy a Chinese dog house fan shroud as they don't have the internal routing pieces to correctly route the cooling air. |
santo Samba Member
Posted: Tue May 18, 2021 9:59 pm Post subject: Re: Dog House oil cooler |
thanks for the advice, I already started sourcing original german parts
Cusser Samba Member
Posted: Wed May 19, 2021 2:05 pm Post subject: Re: Dog House oil cooler |
I would suggest buying a new cooler, you never know what could be in that cooler! |
Zundfolge1432 Samba Member
Posted: Wed May 19, 2021 5:12 pm Post subject: Re: Dog House oil cooler |
I’d clean it and see. Bet it will work as designed, save your money. |
