Chickensoup Samba Member
Joined: January 06, 2018 Posts: 5368 Location: Good Hope, GA
Posted: Sat May 15, 2021 5:44 pm Post subject: Parts YOU want to see made for the community |
My friend posted a similar thread for type 3's so I thought id do the same for the general sub forum.
I CAD and can 3D and Resin print. And soon i will have the CNC mill wrapped up.
Im working on a few ideas i dont want to share until theyre finished but I made this thread so people could make request or share ideas on parts they'd like to see produced.
For example, heres a super simple piece. the plate that sits behind the horn grill. which can be made in a plastic or aluminum to prevent corrosion.
And then some of you may of seen other CAD files ive designed in other forums. i figured this would be an opportunity for people needing hard to come by parts reproduced. _________________ -'85 c10 5.3 LS, 222 cam, long tubes, x pipe, 3 inch spin tech's
'65 Tourist Delivery Build
'66 RIP
'69 RIP
Hosea 4:6 "My people are destroyed for lack of knowledge"
Dan the workingstiff Samba Member
Joined: July 03, 2006 Posts: 824 Location: Downriver, MI
Posted: Sat May 15, 2021 6:22 pm Post subject: Re: Parts YOU want to see made for the community |
I started this thread with you in mind in fact..... please consider it. Thanks
https://www.thesamba.com/vw/forum/viewtopic.php?t=754178
I did pencil rubbings of my oval slots. I believe I have at least one German fender. Its very heavy compared to the others. The slots seem very similar in size without measuring. _________________ '69 Beetle
'66 FG buggy
My other air-cooled's
'76 IH 1200
'75 IH 1200 |
my59 Samba Member
Joined: August 13, 2003 Posts: 3790 Location: connecting the dots
Posted: Sat May 15, 2021 6:27 pm Post subject: Re: Parts YOU want to see made for the community |
Replacement buttons and knobs for Motorola radio, in ivory. _________________ my59: Well son, my grandfather died before I got to drive it, so does that answer your question?
Other:'12 Jetta, '77 Benz 300D, and a 74 MG Midget. |
Posted: Sat May 15, 2021 7:36 pm Post subject: Re: Parts YOU want to see made for the community |
Dan the workingstiff wrote: |
I did pencil rubbings of my oval slots. I believe I have at least one German fender. Its very heavy compared to the others. The slots seem very similar in size without measuring. |
hi, i read your thread. if you have dimensions or know someone who does, i can get it done. i can also print in different colors too. maybe even color match etc. if you cant get dimensions i know someone who may be able to snag some from a junkyard and take dimensions. _________________ -'85 c10 5.3 LS, 222 cam, long tubes, x pipe, 3 inch spin tech's
'66 RIP
'69 RIP
Hosea 4:6 "My people are destroyed for lack of knowledge" |
Posted: Sat May 15, 2021 7:37 pm Post subject: Re: Parts YOU want to see made for the community |
my59 wrote: |
Replacement buttons and knobs for Motorola radio, in ivory. |
hi, again, i will need dimensions for it to be accurate. im guessing its for a 6mm shaft?
thanks _________________ -'85 c10 5.3 LS, 222 cam, long tubes, x pipe, 3 inch spin tech's
'66 RIP
'69 RIP
Posted: Sun May 16, 2021 3:32 am Post subject: Re: Parts YOU want to see made for the community |
Chickensoup wrote: |
hi, i read your thread. if you have dimensions or know someone who does, i can get it done. i can also print in different colors too. maybe even color match etc. if you cant get dimensions i know someone who may be able to snag some from a junkyard and take dimensions. |
I can measure them. I have a mic. I'm just unsure how to measure the radius.
If I were to scan in the pencil rubbings and sent you a pdf would that be more accurate or easier for you? You can pm if you would like to keep the the thread clean. Or maybe post info for others,also. _________________ '69 Beetle
'66 FG buggy
'76 IH 1200
'75 IH 1200 |
Posted: Sun May 16, 2021 7:15 am Post subject: Re: Parts YOU want to see made for the community |
If I were to scan in the pencil rubbings and sent you a pdf would that be more accurate or easier for you? You can pm if you would like to keep the the thread clean. Or maybe post info for others,also. |
Yes please send me a pencil rubbing and a few pictures. That would be great.
Thanks _________________ -'85 c10 5.3 LS, 222 cam, long tubes, x pipe, 3 inch spin tech's
'66 RIP
'69 RIP
Posted: Mon May 17, 2021 3:32 am Post subject: Re: Parts YOU want to see made for the community |
Thanks |
I will, thank you. This is a great thing you're doing!!! _________________ '69 Beetle
'66 FG buggy
'76 IH 1200
'75 IH 1200 |
Who.Me? Samba Member
Joined: July 14, 2014 Posts: 2204 Location: UK (South)
Posted: Mon May 17, 2021 12:20 pm Post subject: Re: Parts YOU want to see made for the community |
I made this thread so people could make request or share ideas on parts they'd like to see produced. |
Fresh muffler heater pips to replace the ones fitted to all the aftermarket mufflers. They never line up with the heat exchangers and/or the holes in the rear tin.
Don't see why they couldn't be made of aluminum but the shape might be difficult. Maybe they could be made of more than just two parts though, with tabs to lock the parts together? _________________ Andy
Looking for info on my truck's history. Are you from Campbell California or nearby. Do you recognise it? ... http://www.thesamba.com/vw/forum/viewtopic.php?t=636786 |
Abscate Samba Member
Joined: October 05, 2014 Posts: 22639 Location: NYC/Upstate/ROW
Posted: Mon May 17, 2021 2:55 pm Post subject: Re: Parts YOU want to see made for the community |
Can we cross post this to the
“Parts I’m willing to pay for”
Thread _________________ .ssS! |
Posted: Mon May 17, 2021 4:40 pm Post subject: Re: Parts YOU want to see made for the community |
Who.Me? wrote: |
Don't see why they couldn't be made of aluminum but the shape might be difficult. Maybe they could be made of more than just two parts though, with tabs to lock the parts together? |
Yeah I know how bad the repro ones are. I have a german set but making new ones would be difficult for a 1 man shop maybe if I get into stamping its doable.
Not unless you want high $$$ CNC billet units _________________ -'85 c10 5.3 LS, 222 cam, long tubes, x pipe, 3 inch spin tech's
'66 RIP
'69 RIP
Abscate wrote: |
Thread |
Never heard of that thread I dont think. _________________ -'85 c10 5.3 LS, 222 cam, long tubes, x pipe, 3 inch spin tech's
'66 RIP
'69 RIP
Posted: Thu May 20, 2021 10:56 am Post subject: Re: Parts YOU want to see made for the community |
my59 wrote: |
are you talking about this style?
[/quote] _________________ -'85 c10 5.3 LS, 222 cam, long tubes, x pipe, 3 inch spin tech's
'66 RIP
'69 RIP
56Cabrio Samba Member
Joined: May 22, 2008 Posts: 1899 Location: San Fernando Valley, CA
Posted: Wed May 26, 2021 4:39 pm Post subject: Re: Parts YOU want to see made for the community |
Well heres the 68-73 beetle bumper bracket block off pieces. Im checking to make sure the mounting process goes smoothly. Got a set on the printer now.
Anyone else have any request?
'66 RIP
'69 RIP
mark tucker Samba Member
Posted: Thu May 27, 2021 8:01 am Post subject: Re: Parts YOU want to see made for the community |
what parts?? high quality parts of coarse...and cheep too I need some intake manifold addaptors...go from idf to ida....like the old scat ones to put ida on 356/912 stuff(solex) scat # 912.
what ever you make ..make it the best it can be made. |
Posted: Thu May 27, 2021 2:58 pm Post subject: Re: Parts YOU want to see made for the community |
mark tucker wrote: |
I can do that. I need dimensions as you know
I just finished these up. They are the bumper bracket block offs mentioned earlier.
I test printed a NEW FLEXIBLE material called TPU. It actually dope as hell. I got a video of me "flexing" But i had to throw some random harp music over the video because my stomach was growling and made the video awkward.
heres the video,
https://youtu.be/69fG_FGoUjk
and here are the cad screenshots
Going on the market soon! maybe.
regarding quality, i think checking what gets shipped out the door plays a giant role. Its one thing to have a well engineered product, but if half of what you sell has defects or falls apart within a month because your cheeped out on production cost, no ones gonna have a fun time. _________________ -'85 c10 5.3 LS, 222 cam, long tubes, x pipe, 3 inch spin tech's
'66 RIP
'69 RIP
KTPhil Samba Member
Joined: April 06, 2006 Posts: 33991 Location: Conejo Valley, CA
Posted: Fri May 28, 2021 10:55 am Post subject: Re: Parts YOU want to see made for the community |
Well heres the 68-73 beetle bumper bracket block off pieces. Im checking to make sure the mounting process goes smoothly. Got a set on the printer now. |
I'm looking forward to getting these put on! I'll post pics when mounted up. _________________ '69 Beetle
'66 FG buggy
'76 IH 1200
'75 IH 1200 |
