Ruby68 Samba Member
Joined: February 19, 2021 Posts: 1 Location: Central Indiana
Posted: Sat May 15, 2021 6:41 pm Post subject: distributor parts list |
Looking for a parts breakdown for a 113-905-205P distributor or something close that shows how its put together and what parts are used. Have not been able to find that type of info.
Goes in a 68 autostick.
Steve |
Blue69Baja Samba Member
Joined: September 04, 2008 Posts: 1065 Location: Fair Oaks
Posted: Mon May 17, 2021 7:41 am Post subject: Re: distributor parts list |
The breakdown of the dizzy is the same for most of the vac advance dizzy's.
To determine what you have as a dizzy these should help verify you have the proper advance and dizzy.
As for your other requests there are many diagrams online for various vw distributors.
One of the videos on the tube:
Jim _________________ 69 Baja with a 1914...
72 Super 100% orig...W/ factory air... 56,000mi
Even the spare is original.. |
Joined: April 27, 2002 Posts: 6371 Location: Pentwater, Michigan
Posted: Mon May 17, 2021 10:22 am Post subject: Re: distributor parts list |
The guy in the video is not an expert. It may not have been his first distributor rehab but he hasn't done more than a few. Lot's of errors in that video. He gives erronious application information. He calls the drive dog a dog house which is a term meant for the fan housing. There are much easier and quicker ways of doing the steps than what he does. I don't believe I have ever seen a housing "out of round", obvious damage, yes. He totally skips soldering a new ground strap, likely because soldering doesn't usually work, brazing is much better. Finally he states at the end to match the 113 T to a Solex 30 PICT 1 or 2 and it was matched to a 30 PICT 3 originally.\\
I believe the OP is looking for an exploded view diagram. They do exist on the site. I did a quick search and didn't find one for a SVDA distributor. _________________ Roads Scholar &
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76937 Location: Sneaking up behind you
Posted: Mon May 17, 2021 10:37 am Post subject: Re: distributor parts list |
Watching just a few seconds of that video, all i can say is WOW.
Never thought of using a drill bit as a punch.
The vacuum only in the video is nothing like the vacuum/mechanical.
To the OP... this might help.
_________________ Glenn
Member #1009
#BlueSquare |
Posted: Mon May 17, 2021 9:01 pm Post subject: Re: distributor parts list |
That diagram, though not labeled, appears to be a 36 hp Beetle diagram, not the same as a 113 P. The diagram only shows one set of shims instead of two? _________________ Roads Scholar &
1961 (October)Single Cab- Road Trip Workhorse |
