avoll Samba Member
Joined: September 04, 2014 Posts: 119 Location: Ottumwa
Posted: Sun May 16, 2021 1:26 am Post subject: 78 Heating duct under bus / Asbestos? |
Does the original duct pipes have asbestos in them?
Does The Y wrap thing have asbestos in it?
Does anything on a 78 have asbestos in it?
I'm wanting to replace all the ducts, because I'm in the process of prepping the underside for paint.
The center duct I have that connects front to back is a bendable duct like the others that connect to the Y but bigger. 90mm I believe, but only replacement one I can find is a soid pipe.
Whats the best replacement parts option for replacing all the ducts?
I don't plan on replacing the Y wrap, seems like it traps more moisture than anything. But, if I did whats the best modern option?
Thanks |
avoll Samba Member
Posted: Sun May 16, 2021 4:07 pm Post subject: Re: 78 Heating duct under bus / Asbestos? |
I attached a couple pictures of the heat ducts.
Anyone know a good place to order the whole set of them?
Thanks
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51150 Location: Surrey B.C. Canada, but thinking of Ukraine
avoll Samba Member
Posted: Sun May 16, 2021 6:37 pm Post subject: Re: 78 Heating duct under bus / Asbestos? |
Thanks, I appreciate the information and the help.
There seems to be just a bunch of bits and pieces of information all over about them. Nothing cut and dry.
I read a lot of that stuff already.
I think I might just order the aircraft tubing and go that route with clamps.
Still would like to know 100% where all the asbestos is on the bus.
Seems like that should be a safety sticky somewhere about full dismantle.
Think I'm just going to treat all the duct work as if it has asbestos in it just in case as I remove it all.
This endeavor all started with a simple brake pad change, then seen ball joints bad and few other things, so then moved on to spraying underside before I put new parts on. Next thing I know im scraping and sanding whole bottom of bus preeping for paint. 🤪
Thanks again |
Posted: Sun May 16, 2021 9:08 pm Post subject: Re: 78 Heating duct under bus / Asbestos? |
The bushings for the accordion tubes are the only asbestos I can think of at the moment. You can buy the equivalent part for the aircooled Vanagon, which is made from silicone. I don't know what the insulating material in the heat exchangers is made of or the insulation in the accordion tubes themselves. Remember you are not working in an asbestos mine or processing plant, where the air glitters with asbestos dust 24/7/365. |
aeromech Samba Member
Joined: January 24, 2006 Posts: 16971 Location: San Diego, California
Posted: Sun May 16, 2021 9:09 pm Post subject: Re: 78 Heating duct under bus / Asbestos? |
I think maybe you’re over reacting on the danger involved. _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
avoll Samba Member
Posted: Sun May 16, 2021 9:34 pm Post subject: Re: 78 Heating duct under bus / Asbestos? |
I probably am being overly cautious. More worried about tracking it inside house around kids more than anything.
I breathed in couple pounds of rust dust over the weekend sanding under there, so thats probably not to great either. Should have plenty of iron for a while though.
Thanks everyone for the information and help. |
Posted: Sun May 16, 2021 9:42 pm Post subject: Re: 78 Heating duct under bus / Asbestos? |
If left alone there’s not much floating around. Disturb it and now there’s an issue. Even then, it’s probably nothing to be too concerned about. _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
avoll Samba Member
Posted: Sun May 16, 2021 10:12 pm Post subject: Re: 78 Heating duct under bus / Asbestos? |
Pulling them off and scraping / sanding the metal they were on is for sure going to disturb it. But ILL try to keep them wet, and wipe off whats left on the metal with soapy water rag. Also wear a mask, and mop up gararge when i'm all done.
Any other advice? |
avoll Samba Member
Posted: Thu Jun 10, 2021 3:05 pm Post subject: Re: 78 Heating duct under bus / Asbestos? |
Anyone know roughly how many feet of 3 1/2 pipe, and 2 1/4 pipe I need to order to make all the run? |
Jetfxr69 Samba Member
Joined: December 28, 2018 Posts: 1293 Location: White mtns nh
Posted: Fri Jun 11, 2021 4:38 am Post subject: Re: 78 Heating duct under bus / Asbestos? |
aeromech wrote: |
I think maybe you’re over reacting on the danger involved. |
Was thinking the exact same thing. Unless your working with this stuff for prolonged periods of time, its not gonna be a problem. Its not like its radioactive or something, where 1 limited exposure is gonna kill you. Hell, ive injested enough toxic chemicals in aviation for years. Skydrol, jet fuel, mek, solvents of various carcinogenic make up, and at 51, it aint got me yet.
Oh yeah, forgot about the 100% Deet bug dope we need up here just to walk outside in the summer. Apparantely that aint too good for you either. Its good for me to not get swarmed by all the damn bugs up here.
Of course, 52 may be different, but not gonna worry about tomorrow. _________________ You can't be a real country unless you have a beer and an airline. It helps if you have some kind of a football team, or some nuclear weapons, but at the very least you need a beer. Zappa
‘77 westy Seamus
‘76 tintop Crusher
‘77 westy The Judge
‘72 tintop bastard westy Hudson |
my59 Samba Member
Joined: August 13, 2003 Posts: 3793 Location: connecting the dots
Posted: Fri Jun 11, 2021 5:25 am Post subject: Re: 78 Heating duct under bus / Asbestos? |
When I took the heating system apart (to remove critter nests, clean, and get rust holes closed up) I wore gloves and a respirator. The asbestos cuffs went into a plastic bag and then the trash can. The wrapping on the Y was unfastened and re used. A section of metal duct was cut to fit for the straight pipe. The other parts that are tack welded were scrubbed out (think wads of rags on coat hanger) and dried with compressed air. Riveted some patches over rust holes, with metal duct tape to seal (yeah, not the best way to go, I know)
Made a major difference for fall and spring driving.
Having a sunroof makes it a greater challenge to try to keep heat in... _________________ my59: Well son, my grandfather died before I got to drive it, so does that answer your question?
Other:'12 Jetta, '77 Benz 300D, and a 74 MG Midget. |
secretsubmariner Champagne Wrangler
Joined: January 08, 2011 Posts: 3104 Location: Tulsa, OK
Posted: Fri Jun 11, 2021 6:10 am Post subject: Re: 78 Heating duct under bus / Asbestos? |
avoll wrote: |
There is a factory tool that might interest you, not surprising that your bus didn't come with it, they tend to get lost over the years. Google "tape measure" and you'll see a lot of options for quality replacements _________________ -Tony
ᏣᎳᎩᎯ ᎠᏰᎵ
1978 Champagne Edition Bus FI
1970 Auto Fastback FI |
alaskadan Samba Member
Joined: January 09, 2013 Posts: 1858 Location: anchor pt. alaska
Posted: Sat Jun 12, 2021 8:55 am Post subject: Re: 78 Heating duct under bus / Asbestos? |
Radial caliper. |
avoll Samba Member
Posted: Sun Jun 13, 2021 12:57 pm Post subject: Re: 78 Heating duct under bus / Asbestos? |
Measuring it would work if I was home to do it.
Was hoping to order the stuff and have it waiting when I got home.
Thought maybe someone who's done it already might know the measurements. |
