zoti Samba Member
Joined: December 26, 2007 Posts: 2061 Location: Plano, TX USA
Posted: Sun May 16, 2021 8:19 pm Post subject: Vent window hold open clip. |
I made a design for a vent window clip to prevent the vent window from flipping when driving at highway speed.
I cut it from acrylic on my laser but I made a version fro 3D printing that is available on thingiverse.
https://www.thingiverse.com/thing:4861114
vanis13 Samba Member
Joined: August 15, 2010 Posts: 3100 Location: ABQ NM USA.... Except when not
Posted: Sun May 16, 2021 9:21 pm Post subject: Re: Vent window hold open clip. |
My fav design so far from those I've seen. I like that it is flat. Nice! _________________ 83.5 Westy with Subaru 2.5, 4 spd manual, center seat, COLD A/C on 134a!, Winter camp heated with an Espar B4 gasoline furnace
www.SuperVanagon.com - some stuff I make |
IdahoDoug Samba Member
Joined: June 12, 2010 Posts: 10251 Location: N. Idaho
Posted: Sun May 16, 2021 11:28 pm Post subject: Re: Vent window hold open clip. |
Nice! You should label the two positions as follows:
Position A - Vectors injured bees and hornets into your chest.
Position B - Bounces them across the van at your wife!! _________________ 1987 2WD Wolfsburg Vanagon Weekender "Mango", two fully locked 80 Series LandCruisers. 2017 Subaru Outback boxer. 1990 Audi 90 Quattro 20V with rear locking differential, 1990 burgundy parts Vanagon. 1984 Porsche 944, 1988 Toyota Supra 5 speed targa, 2002 BMW 325iX, 1982 Toyota Sunrader |
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32629 Location: Reading Pennsylvania
space Samba Member
Posted: Mon May 17, 2021 5:03 am Post subject: Re: Vent window hold open clip. |
I like it
made mine out of ceiling wire
it wraps around the front of the opening _________________ 82 westy
w:
2.5 JDM Subie
Rear discs |
zoti Samba Member
Posted: Mon May 17, 2021 7:29 am Post subject: Re: Vent window hold open clip. |
djkeev wrote: |
I notice that newer Vans have a vent window rotation limiter on them.
That wide open vent isn't possible.
Dave |
What is a newer van? This is an 88 |
zoti Samba Member
Posted: Mon May 17, 2021 10:23 am Post subject: Re: Vent window hold open clip. |
djkeev wrote: |
zoti wrote: |
djkeev wrote: |
Dave |
1990, first month of production.
Dave |
Have a picture of the window? |
Franklinstower Samba Member
Posted: Mon May 17, 2021 10:40 am Post subject: Re: Vent window hold open clip. |
zoti wrote: |
djkeev wrote: |
zoti wrote: |
djkeev wrote: |
Dave |
Dave |
My 89 has the vent opening limit pin. I just removed it.
You do know that instead of making some special vent window stay device, you can tighten the screw on the pivot arm and it will stay where you leave it.
Pin removed to allow full rotation:
_________________ '89 Westy - EJ25/22 Frank 4.44 5mt
'75 Miami Blue Sunroof FI Standard Bug |
zoti Samba Member
Posted: Mon May 17, 2021 10:45 am Post subject: Re: Vent window hold open clip. |
I tried tightening stuff. Which screw are you referring to?
Franklinstower wrote: |
zoti wrote: |
djkeev wrote: |
zoti wrote: |
djkeev wrote: |
Dave |
Dave |
jlrftype7 Samba Member
Posted: Mon May 17, 2021 2:03 pm Post subject: Re: Vent window hold open clip. |
zoti wrote: |
zoti wrote: |
djkeev wrote: |
zoti wrote: |
djkeev wrote: |
Dave |
Dave |
I feel your pain. I was pretty successful in tightening the Drivers Side screw with the needle nose Visegrips trick but less so with the Passenger side. Could be a wear pattern on the pivot between the two , or there is more lube and less rust on the passenger side, allowing a bit more freedom in the 'Wind' as it were, to move back to the close position once you're going fast enough.... _________________ '68 Westy- my first VW and vehicle/Bus- long gone.- sold it to a traveling Swiss couple....
‘84 Tin Top - Hilga....Auto |
