3foldfolly Samba Member
Joined: March 08, 2009 Posts: 894 Location: Edwardsville, Il
Posted: Mon May 17, 2021 8:48 am Post subject: Speedometer glass |
I accidentally cracked the glass lens in my 1954 speedometer by over tightening the speedo to dash retaining screws trying to establish a good ground for the speedometer illumination lights. I hoping someone can tell me what year speedos use the same diameter glass. I suspect all from oval to 67 are the same but I am not certain. |
66brm Samba Member
Joined: January 25, 2010 Posts: 3676 Location: Perth Western Australia
Posted: Tue May 18, 2021 5:17 am Post subject: Re: Speedometer glass |
Yeah pretty sure to they are the same, just find a trashed, common as muck 60's Speedo, strip it down and transfer the glass _________________ Aust. RHD 66 Type 1
Aust. RHD 57 Type 1 Oval
modok wrote: |
I am an expert at fitting things in holes, been doing it a long time |
ZENVWDRIVER Samba Member
Joined: November 07, 2008 Posts: 3340 Location: N.E. Oklahoma
Posted: Wed May 19, 2021 1:39 pm Post subject: Re: Speedometer glass |
… the speedo glass in our 1950 11G cracked in half - we left that character for several years, but the new owner changed it, pretty fast - nothing is perfect was my feeling - z _________________ 5/50, pastel green 11G - SOLD
8/50, gray 11A Beetle
6/52, pastel green 11C - SOLD
1960 single cab
9/63 Pacific blue, Ghia
'87 Toyota MR2
All super-heroes, wear a MASK |
Zwitterkafer Samba Member
Joined: November 17, 2007 Posts: 879 Location: Lanark County, Ontario, Canada
Posted: Wed May 19, 2021 5:22 pm Post subject: Re: Speedometer glass |
The glass diameters were the same for a long time. But there were differences in thickness. Accordingly, there are slight variations in the chrome bezels, and in the 3 rubber seals (or rubber seals + paper gasket). If a donor speedo has a different thickness glass, it may be best to transfer glass + bezel + gaskets. This prevents the completed assembly from being too tight or too loose. _________________ "Criticism comes easier than Craftsmanship"
- Zeuxius, 400 BC |
Posted: Thu May 20, 2021 7:10 am Post subject: Re: Speedometer glass |
Zwitterkafer wrote: |
The glass diameters were the same for a long time. But there were differences in thickness. Accordingly, there are slight variations in the chrome bezels, and in the 3 rubber seals (or rubber seals + paper gasket). If a donor speedo has a different thickness glass, it may be best to transfer glass + bezel + gaskets. This prevents the completed assembly from being too tight or too loose. |
Thank you for this valuable information. |
Posted: Thu May 20, 2021 1:36 pm Post subject: Re: Speedometer glass |
No problemo! I had a flakey speedo ground once as well. I admit to performing a hack....I added a spade ground terminal under one of the two screws that hold the speedo head to the speedo casing. Easy connection point for a nice new brown push-on ground wire. Easily reversible when reverting to purist mode. _________________ "Criticism comes easier than Craftsmanship"
- Zeuxius, 400 BC |
