type11969 Samba Member
Joined: September 12, 2004 Posts: 474 Location: Collingswood NJ
Posted: Mon May 17, 2021 9:37 am Post subject: Rear bump stop - clearance? |
I have a 76 westy with a subaru conversion - aka more weight hanging off the back end. Needless to say, I had some sag issues. I just swapped both the inner and outer spring plate bushings, and confirmed that the plates were indexed at 23 degrees. I decided not to mess with re-indexing yet to see how much the bushing replacement impacting things. Ends up bushing placement alone bought me ~0.5" of lift on each side at the wheel arch. But, I'm still basically on the bump stops - pass side is barely touching/engaged (I can wiggle the stop around), driver's side has some clearance.
I plan to re-index, but I'm trying to figure out by how much. I'd like to get back to stock ride height. Roughly how much clearance should I try to achieve between the rubber bump stop and the metal stop itself?
Besides the suby swap, I do have a full tank of gas, but otherwise nothing in the bus (besides the camping interior).
Help appreciated, thanks!
-Chris _________________ 1969 VW Beetle - t4ed indeed
1971 Porsche 914 - jackstanded
1976 Westy - DD |
Posted: Mon May 17, 2021 11:09 am Post subject: Re: Rear bump stop - clearance? |
The smallest adjustment you can make is 0° 40', so assuming I have the math right the minimum change in the height (H) is approximately
H = L x Sin(0°40')
H = L x 0.012
where L is the center to center length of the torsion arm. Two minimum adjustments would be about twice that.
Somewhere there are charts for this. |
Posted: Mon May 17, 2021 11:35 am Post subject: Re: Rear bump stop - clearance? |
Thanks, I don't have any questions about the math, or what I need to do to get to whatever target - I'm more curious about the target itself. Ultimately I'd really like to know how much bump stop clearance I should have. I can't imagine that what I have right now is correct, but maybe. Or is 1" more appropriate? Just looking for a rough number.
Certainly happy to use some other measurement metric if there is something better
1976 Westy - DD |
aeromech Samba Member
Joined: January 24, 2006 Posts: 16959 Location: San Diego, California
Posted: Mon May 17, 2021 1:32 pm Post subject: Re: Rear bump stop - clearance? |
Please also consider that after all these years the bars have taken a set. This means that when doing the adjustment add just a bit _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
Posted: Mon May 17, 2021 2:02 pm Post subject: Re: Rear bump stop - clearance? |
Yep, understood. But given that I'm running with more weight cantilevered over the rear (suby conversion), I'm going to need more than an adjustment to compensate for set. I'm just trying to figure out by how much. I'd rather only have to take apart/reassemble once more. I'm hopeful someone can share a dimension target for stock ride height - like bumpstop clearance or distance from the ground to the torsion tube, or?
1976 Westy - DD |
Posted: Mon May 17, 2021 2:11 pm Post subject: Re: Rear bump stop - clearance? |
The Bentley gives the numbers. I’m just saying that those numbers are based on new torsion bars. Add a bit to compensate for age _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
Posted: Mon May 17, 2021 2:40 pm Post subject: Re: Rear bump stop - clearance? |
For my van the center of the rear wheels to the lips of the wheel well is about 11". Your van should look like it is sitting down in the back a bit when unloaded. Add two people up front and it will look much more level.
Posted: Mon May 17, 2021 2:44 pm Post subject: Re: Rear bump stop - clearance? |
Right, Bentley gives the number for the spring plate angle for a stock bus. My spring plates currently measure at that angle without any adjustment, which means they really haven't taken a set (at least within the capabilities of my measurement equipment). But none of this really matters since my rear end is now heavier (ha ha). I need a new target. I know no one is going to be able to tell me the spring plate angle I should use with this added weight, but I can work through the geometry if someone can share a linear dimension off of a stock bus - like the bump stop gap or torsion tube to ground clearance or?
With some linear dimension at some distance from the torsion tube centerline, I can figure out the spline changes I need to achieve that dimension. Its the best option I have right now to try to avoid setting too high or too low.
Anyone have a few minutes to snap a pic of their rear bumpstop clearance in their non-saggy-rear-ended bus?
1976 Westy - DD |
germansupplyscott Samba Member
Posted: Mon May 17, 2021 2:45 pm Post subject: Re: Rear bump stop - clearance? |
Do you have a way to measure the angle of the Bus with respect to level?
(the 'gap' between the rubber bumper and the stop is not important really. It is significant but it's not a way to measure anything)
You can then calculate the amount of adjustment you need to end up with a level stance. There is debate on whether this measurement should be done with a driver or driver and passenger seated in the Bus. If the Bus is level without the driver / passenger it will be *slightly* nose down with them, this is usually OK. If you are let's say 1.5 degrees low in the rear, then rotate the torsion arm 1.5 degrees in the opposite direction and that will get you close to level.
Count on doing this twice, it's expected to have to re-do even if you have good measuring and math. _________________ SL
Last edited by germansupplyscott on Mon May 17, 2021 2:50 pm; edited 1 time in total |
Posted: Mon May 17, 2021 2:46 pm Post subject: Re: Rear bump stop - clearance? |
Wildthings wrote: |
For my van the center of wheel to the lip of the wheel well is about 11". Your van should look like it is sitting down in the back a bit when unloaded. Add two people up front and it will look much more level. |
Thanks, I'll see where I stack up against this. _________________ 1969 VW Beetle - t4ed indeed
1976 Westy - DD |
Posted: Mon May 17, 2021 2:53 pm Post subject: Re: Rear bump stop - clearance? |
Measuring to the driprail at roughly the center of each wheel indicates that on the driver's side, the rear is slightly higher than the front (1/16") and on the pass side, the rear is basically level with the front. But I also think I read that the drip rail has a slope, so I'm not sure how reliable this measurement is.
I'm also thinking that I should probably drive for a bit with the new bushings to see how things settle before I try to re-index.
Any recommendations for locations to measure bus slope? I've read middle of the slider door opening on the pass side, what about the drivers side?
-Chris
germansupplyscott wrote: |
Count on doing this twice, it's expected to have to re-do even if you have good measuring and math. |
1976 Westy - DD |
Posted: Mon May 17, 2021 3:01 pm Post subject: Re: Rear bump stop - clearance? |
The bottom edge of the rocker panel should be plum to the Bus however if the Bus has had any rocker work you don't know for sure.
In the repair manual the protractor tool is measuring off the frame. The factory tool is extremely accurate and fine in it's measurements, so much so that it's difficult to measure with any other method and be accurate enough. A laser measuring tool could work. The lower edge of the bulge in the middle of the body could be used. _________________ SL |
Posted: Mon May 17, 2021 3:08 pm Post subject: Re: Rear bump stop - clearance? |
Basically you take your best shot. See what happens. Then redo the job with a change to compensate for the first try.
Tip. Level the bus on stands before you start. I’ve used my iPhone to measure but now I have a digital protractor like we used at the airline to measure flight controls _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
Posted: Mon May 17, 2021 3:14 pm Post subject: Re: Rear bump stop - clearance? |
aeromech wrote: |
Tip. Level the bus on stands before you start. I’ve used my iPhone to measure but now I have a digital protractor like we used at the airline to measure flight controls |
Mitutoyo Digital Protractor
Model: 950-315
In Good Usable Condition, has wear as shown.
Made in Japan
My workbench is not level as shown, the protractor can be zero'd on any surface by pushing the ALT ZERO button _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
Posted: Mon May 17, 2021 3:18 pm Post subject: Re: Rear bump stop - clearance? |
Thanks, I was hoping to avoid iterations but maybe thats simply what I need to do.
I'd still love to see a pic of someone's non-saggy bump stop clearance - who wants to humor me?
1976 Westy - DD |
Posted: Mon May 17, 2021 3:31 pm Post subject: Re: Rear bump stop - clearance? |
type11969 wrote: |
-Chris |
You don't need to level the body or measure the angle it sits at. All you need to do is compare the angle of the torsion arm to the rocker. This tool will do that handsomely. Actually I can't remember off hand if this particular tool is for my T2 or my T181, as they are visually very close to being the same. The angle of the cut is what is important. Just place it along the rocker and eyeball the angle of the torsion arm. Easy enough to get within a 1/4 degree. The square cut is just clearance for the jack point.
Posted: Mon May 17, 2021 3:46 pm Post subject: Re: Rear bump stop - clearance? |
Leveling the bus takes just a few minutes and eliminates any potential math errors when measuring the angles.
As far as you looking at someone else’s bus I can’t see that to be much help since your weight is different. Using the most accurate tools available will only get you in the ballpark because of the years. You’ll need to “baby up on it”. _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
richparker Samba Member
Joined: November 24, 2011 Posts: 6980 Location: Durango, CO
Posted: Mon May 17, 2021 3:53 pm Post subject: Re: Rear bump stop - clearance? |
aeromech wrote: |
This is my technique. It really seems like you are looking for a number...if you’re at 23* Is why not shoot for, say like 27* and go from there.
You must measure the angle with the spring plates unweighted (that’s remove the spring plate cover and the spring plate off the stop). I usually loosen the spring plate cover bolts a good amount, then use a jack to raise the spring plate up, then slide a pry bar under the spring plate (usually using a hammer) and lower the jack. This will allow the spring plate to pass the stop and leaving the cover on will allow the plate to not come flying off and injure you. You can’t just move the plate down one spline, that will be too much of a lift. You have the pull the torsion bar out a little and rotate the inner the opposite way of the plate. Last time I did it I think I moved the inner and outer 5 splines to get the desired angle thet I just randomly made up.
Good luck! _________________ __________
’71 Westy build
Adventure thread
’65 Deluxe Build
’63 Deluxe Build |
Posted: Mon May 17, 2021 4:22 pm Post subject: Re: Rear bump stop - clearance? |
aeromech wrote: |
Leveling the bus takes just a few minutes and eliminates any potential math errors when measuring the angles. |
No need to do any math when using my method. The gauge board shown is cut at 23° (assuming it is for a bus and not my Thing) and I can easily make up one at some other angle if I so desire. |
Posted: Mon May 17, 2021 5:04 pm Post subject: Re: Rear bump stop - clearance? |
Better start selling those or it won’t matter because no one else has one _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
