type11969 Samba Member
Joined: September 12, 2004 Posts: 474 Location: Collingswood NJ
Posted: Mon May 17, 2021 5:42 pm Post subject: Re: Rear bump stop - clearance? |
Thanks guys. Ultimately the point is that I can't rely on that 23deg number due to the additional subaru engine weight. But I don't know what that number needs to be - I need a different reference. Bump stop clearance might be a poor indicator, but it is at least a better target than the guess and check option I have now.
Anyway, I'll probably start with a degree or so lift and go from there.
-Chris _________________ 1969 VW Beetle - t4ed indeed
1971 Porsche 914 - jackstanded
1976 Westy - DD |
Posted: Mon May 17, 2021 6:16 pm Post subject: Re: Rear bump stop - clearance? |
type11969 wrote: |
-Chris |
The equation I gave you earlier will tell you how many degrees you need to add to get the lift you need. If you want to go up an inch just figure out how many degrees you need to add to get that amount of lift. |
richparker Samba Member
Joined: November 24, 2011 Posts: 6936 Location: Durango, CO
Posted: Mon May 17, 2021 7:09 pm Post subject: Re: Rear bump stop - clearance? |
type11969 wrote: |
-Chris |
Every bus is different, so we can’t just tell you what angle to set it at. Wildthings posted a equation for you to use, or you can just do trial and era like a lot of us have done.
I had a ‘68 that was at 21*. I moved the spring plate down one spline on the torsion bar and gave me 28*. That was too much at it topped out on the stop over every bump. I went back and readjusted it and settled at 25.5*, which I liked on that bus.
Fast forward a decade and I now have a ‘71 Westy. That measured 21* as well. I took it apart and set it at 26*, figuring that’s close to what I did on the ‘68 and it still sagged in the rear. It was taken apart again and raised another 2* to 28* and it sits just the way I like it now.
So 28* was too much on my ‘68 but perfect on my ‘71. Each bus is different and you’ll just have to get dirty and see what works.
Good luck! _________________ __________
’71 Westy build
Adventure thread
’65 Deluxe Build |
Posted: Mon May 17, 2021 7:40 pm Post subject: Re: Rear bump stop - clearance? |
Thanks guys, I don’t know what lift I need and I’m not asking for an angle, all I’m curious about is a linear dimension off of a stock ride height bus that I can aim for to match. I can perform the trig from there. I’ve already “gotten dirty” and replaced the bushings so I have a known good starting point.
For example, if a stock ride height bus has 8” of clearance to the bottom of the torsion tube, and I currently have 7”, I’ll aim for a 1” lift. I know how to get to a 1” lift. I don’t actually know what the dimension is for a stock ride height bus to determine if a 1” lift is a good target though.
I’ll start with the shared-earlier dim from the wheel center to the bottom of the fender lip.
1976 Westy - DD |
ImAddicted Samba Member
Joined: April 24, 2012 Posts: 1195 Location: Unorganized Territory, Maine
Posted: Tue May 18, 2021 4:40 pm Post subject: Re: Rear bump stop - clearance? |
Not sure if this is what you are looking for or not. Hard to see bump stops with the wheel on but it tried. I have about 3/4” between bump stop and plate. Spring plate set at 25*.
Tires are 27s
_________________ 1979 Transporter (sold)
KC1MUR
strfish7 wrote: |
Original condition, which means something different on this forum than anywhere else! |
Posted: Tue May 18, 2021 6:40 pm Post subject: Re: Rear bump stop - clearance? |
Thanks - love those tires! _________________ 1969 VW Beetle - t4ed indeed
1976 Westy - DD |
LouFilia Samba Member
Posted: Tue May 18, 2021 10:13 pm Post subject: Re: Rear bump stop - clearance? |
Wow, sometimes it's hard to get the answer you are looking for on the Samba. I really liked how you kept explaining what you wanted and why and then get the same answer, so you'd try again. I'm glad by the time I got to the end someone had posted a pic because they are a pain (and its dark). I have a solid inch maybe even 1 1/8th-inch clearance. It was small enough to worry me, so I strapped the go pro under there and it actually compresses to give quite bit more travel. _________________ '78 Westy (P22), 2.0FI (GE), 4speed (CP), thought I was buying a VW, ended up with a Bentley. |
Posted: Tue May 18, 2021 11:41 pm Post subject: Re: Rear bump stop - clearance? |
LouFilia wrote: |
Wow, sometimes it's hard to get the answer you are looking for on the Samba. |
I gave him the answer he needed halfway down the first page.
Quote: |
For my van the (distance from) center of the rear wheels to the lips of the wheel well is about 11". |
A tape measure can determine the wheel center to lip distance quite accurately, whereas trying to measure the clearance of the bumpstop is pretty subjective and could well vary considerably with the actual size of the bumpstop itself. |
Posted: Wed May 19, 2021 7:04 am Post subject: Re: Rear bump stop - clearance? |
LouFilia wrote: |
Wow, sometimes it's hard to get the answer you are looking for on the Samba. I really liked how you kept explaining what you wanted and why and then get the same answer, so you'd try again. I'm glad by the time I got to the end someone had posted a pic because they are a pain (and its dark). I have a solid inch maybe even 1 1/8th-inch clearance. It was small enough to worry me, so I strapped the go pro under there and it actually compresses to give quite bit more travel. |
As I stated above, every bus is different. Your bump stop gap is 1 1/8”, where imaddicted’s gap is 3/4”.
Why is stock so important? The OP’s bus is far from stock with a Subie swap. _________________ __________
’71 Westy build
Adventure thread
’65 Deluxe Build |
airschooled Air-Schooled
Joined: April 04, 2012 Posts: 12688 Location: on a bike ride somewhere
Posted: Wed May 19, 2021 8:11 am Post subject: Re: Rear bump stop - clearance? |
Wait, so you mean my bus shouldn't be resting on the Kong toys when parked?
www.airschooled.com |
sodbuster Samba Member
Joined: August 08, 2004 Posts: 1082 Location: wherever my baywindow takes me.
Posted: Wed May 19, 2021 9:50 am Post subject: Re: Rear bump stop - clearance? |
I'm surprised you are using the rubber snubbers as a reference. Where the spring plate contacts the bottom torsion housing stop seems more accurate to me.
off the top of my head 1/4 to 1/2 inch off of the bottom stop with the vehicle sitting at rest seems about right. Also be advised the inner and outer splines of the torsion bars are not the same spline count. This is for fine degree adjustment of the rear suspension. |
Posted: Wed May 19, 2021 9:55 am Post subject: Re: Rear bump stop - clearance? |
airschooled wrote: |
Robbie |
Only if you’re in the back rockin-n-rollin with Two Ton Tessie... _________________ __________
’71 Westy build
Adventure thread
’65 Deluxe Build |
Joined: January 01, 2007 Posts: 16803 Location: sticksville, ct.
Posted: Wed May 19, 2021 11:51 am Post subject: Re: Rear bump stop - clearance? |
type11969 wrote: |
I have a 76 westy with a subaru conversion - aka more weight hanging off the back end. |
you had issues before the swap. a fully dressed subaru engine is lighter than a fully dressed T4 _________________
gprudenciop wrote: |
Jake Raby wrote: |
Brian wrote: |
Posted: Wed May 19, 2021 12:10 pm Post subject: Re: Rear bump stop - clearance? |
For shits and giggles I just measured the gaps in my bus. My spring plate has a 1/2” gap between it and the stop and there is 1” of clearance between the kong and the stop. _________________ __________
’71 Westy build
Adventure thread
’65 Deluxe Build |
Posted: Wed May 19, 2021 1:15 pm Post subject: Re: Rear bump stop - clearance? |
Robbie |
Noooo, how will you get to the peanut butter if it is on the stops??? Geezzz. Westerners...
richparker wrote: |
For shits and giggles I just measured the gaps in my bus. My spring plate has a 1/2” gap between it and the stop and there is 1” of clearance between the kong and the stop. |
Couldn't find my tape measure (better half probably put it back where it belongs, which means I'll never find it) so I grabbed what I could. Pretty much 18mm or about 3/4" at the spring plate, about the same at Robbie's dog toy.
KC1MUR
strfish7 wrote: |
