Texas Cal Looker 64 Sunroof build.
Page: 1, 2, 3  Next
Texcallooker
Texcallooker is offline
PostPosted: Tue May 18, 2021 11:18 am    Post subject: Texas Cal Looker 64 Sunroof build. Reply with quote
So I thought I would start a build thread on my 64 sunroof car. I picked it up from a buddy of mine as a project. It is surprisingly rust free, just a little in the pans but the body is solid. It was taken apart to be media blasted and body worked prior to me getting it. Other than some blocking the body is ready to go.
Texcallooker
PostPosted: Tue May 18, 2021 11:35 am    Post subject: Re: Texas Cal Looker 64 Sunroof build. Reply with quote
I pulled the body off the pan and started looking at the floors and decided on only patches as the rest is pretty solid. It’s nice to have a lift in your home shop. Sure makes things easy.
Texcallooker
PostPosted: Tue May 18, 2021 11:41 am    Post subject: Re: Texas Cal Looker 64 Sunroof build. Reply with quote
Next up since this car will be used from drag racing a street use it will have RLR cutch in it so I figured I’d better check the clutch tube and yep it’s broke loose at the front and back. A little surgery and we’re back in business.
sportin-wood
sportin-wood is offline
PostPosted: Tue May 18, 2021 1:25 pm    Post subject: Re: Texas Cal Looker 64 Sunroof build. Reply with quote
Looks like a decent starting point. Good luck on the build! I'll be following.
Paused 66 project bug
RUNKLE
RUNKLE is offline
PostPosted: Tue May 18, 2021 1:45 pm    Post subject: Re: Texas Cal Looker 64 Sunroof build. Reply with quote
Texcallooker wrote:
Looks like you neighbor is a little jealous... all he got was a lawnmower. Laughing
Type 1
Type 3
1968 Squareback
matthew henricks
matthew henricks is offline
PostPosted: Tue May 18, 2021 1:49 pm    Post subject: Re: Texas Cal Looker 64 Sunroof build. Reply with quote
Looks like a solid starting place. Being a sunroof bug check the lower A-pillars. Common rust hiding place.
Good luck.
1964 Original Owner build Thread. https://www.thesamba.com/vw/forum/viewtopic.php?t=702135&highlight=
Ambulance Fan's. https://www.thesamba.com/vw/forum/viewtopic.php?t=627707&highlight=
Parts i am looking for:
64 bug nice used front/rear Black LHD floor mat.
Texcallooker
PostPosted: Tue May 18, 2021 2:07 pm    Post subject: Re: Texas Cal Looker 64 Sunroof build. Reply with quote
Thanks. The cars been media blasted and its rock solid.
Good luck.
Chickensoup
Chickensoup is offline
PostPosted: Tue May 18, 2021 7:12 pm    Post subject: Re: Texas Cal Looker 64 Sunroof build. Reply with quote
wow that car is solid AF! i wish all my projects looked that good lol. looking forward to seeing the end result! although the journey is decently important too Wink
-'85 c10 5.3 LS, 222 cam, long tubes, x pipe, 3 inch spin tech's
'65 Tourist Delivery Build
'66 RIP
'69 RIP
Hosea 4:6 "My people are destroyed for lack of knowledge"
Texcallooker
PostPosted: Thu May 20, 2021 3:59 am    Post subject: Re: Texas Cal Looker 64 Sunroof build. Reply with quote
I generally don’t get this lucky but I did on this one.
Texcallooker
PostPosted: Thu May 20, 2021 4:00 am    Post subject: Re: Texas Cal Looker 64 Sunroof build. Reply with quote
RUNKLE wrote:
Haha yep!!
Texcallooker
PostPosted: Thu May 20, 2021 4:11 am    Post subject: Re: Texas Cal Looker 64 Sunroof build. Reply with quote
So I’ll try and add some kind of update daily but for now it’ll be just random stuff as I go.
Spent the day removing the last of the old tar board. Can out pretty easy.
I removed the old fuel like from the tunnel, by far no easy task. I did it to make room for the new fuel line going in. Big motor w dual IDA’s is the plan.
Got a pile of goodies from summit for the brakes a fuel system. Plan is to get everything fitted up and then take out to prep and powder coat or paint the pan. This will help lessen the chance of skinning up the finish or run into snags along the way.
Practicing my engine turning skills for the plates where the fuel line will exit the pan for a little clean finish.
Texcallooker
PostPosted: Thu May 27, 2021 9:31 am    Post subject: Re: Texas Cal Looker 64 Sunroof build. Reply with quote
Update 5/27/21
Built a dolly to roll the pan around and to be able to get it outside to blow all the blast grit out of the tunnel.
Last of the fuel/brake lines and fitting showed up.
Decided to do something cool at least. Made and engine turned a bulkhead cover for the fuel line where it comes through the pan.
heimlich Premium Member
VWNOS.com
heimlich is offline
PostPosted: Fri May 28, 2021 3:59 pm    Post subject: Re: Texas Cal Looker 64 Sunroof build. Reply with quote
I've got that same car. Are you in Houston?
Texcallooker
PostPosted: Sat May 29, 2021 10:18 am    Post subject: Re: Texas Cal Looker 64 Sunroof build. Reply with quote
close, Beaumont
aaronr25
aaronr25 is offline
PostPosted: Sat May 29, 2021 11:45 am    Post subject: Re: Texas Cal Looker 64 Sunroof build. Reply with quote
I dig the dolly that you built to roll the pan around. That's a great Idea.
65 Bug
66 Landcruiser FJ40
Life's too short to drive a stock VW
turboedbug
turboedbug is offline
PostPosted: Sun May 30, 2021 3:11 pm    Post subject: Re: Texas Cal Looker 64 Sunroof build. Reply with quote
Nice build! Keep us rolling with photos!
Check out my video log of my beetle! suby swapped!
Instagram BoostedPower_ check me out!
Youtube channel!
https://m.youtube.com/channel/UCS4MUNXfeo3ZV9t2v4Wu-6A
Build thread video collection
https://www.thesamba.com/vw/forum/viewtopic.php?t=752062&highlight=
View user's profile Send private message Send e-mail MSN Messenger Classifieds Feedback
Chickensoup
PostPosted: Sun May 30, 2021 3:16 pm    Post subject: Re: Texas Cal Looker 64 Sunroof build. Reply with quote
turboedbug wrote:
Nice build! Keep us rolling with phots!
Did you mean,
thots
farts
or shots Shocked Question Wink
'66 RIP
'69 RIP
turboedbug
PostPosted: Sun May 30, 2021 3:17 pm    Post subject: Re: Texas Cal Looker 64 Sunroof build. Reply with quote
Chickensoup wrote:
Did you mean,
thots
farts
Fat fingers make me look stoopid
Youtube channel!
Texcallooker
PostPosted: Sun Jun 06, 2021 6:28 pm    Post subject: Re: Texas Cal Looker 64 Sunroof build. Reply with quote
New update of sorts.
Picked up some néw tools. I found a turret style flaring tool that comes with both 37 and 45 deg flare dies as well as bubble and double flares. Included was 25 feet of stainless 3/-16” brake line all for the same price as the Eastwood tool.
I also made a a tubing straightener since I’m cheap and didn’t want to spend the $100-200 for the same tool.
And finally was able to get the last of the undercoat chipped ground and burnt off the pan. Not a great time but it’s done.
Chickensoup
PostPosted: Sun Jun 06, 2021 7:19 pm    Post subject: Re: Texas Cal Looker 64 Sunroof build. Reply with quote
dang your making quick pace!
'66 RIP
'69 RIP
Page: 1, 2, 3  Next
