calvinater Samba Member
Joined: September 06, 2014 Posts: 3328 Location: 802 The Pointless Forrest
Posted: Wed May 19, 2021 12:45 pm Post subject: New concrete floor |
Whats your favourite topping for a fresh concrete slab, both for summer weddings and winter car parking. _________________ "Albatross"! |
Xevin Samba Member
Posted: Wed May 19, 2021 1:31 pm Post subject: Re: New concrete floor |
calvinater wrote: |
Whats your favourite topping for a fresh concrete slab, both for summer weddings and winter car parking. |
10W-30 _________________ Keep on Busin'
67rustavenger wrote: |
GFY's Xevin and VW_Jimbo! |
Clatter wrote: |
Damn that Xevin... |
skills@eurocarsplus wrote: |
SGKent wrote: |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51130 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Wed May 19, 2021 3:19 pm Post subject: Re: New concrete floor |
Xevin wrote: |
calvinater wrote: |
10W-30 |
But how much zinc?, and what about after break in? _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Wed May 19, 2021 3:52 pm Post subject: Re: New concrete floor |
Cmon guys , this is for a customer , and i know coatings have evolved recently.
Anyone with experience with an epoxy type coating? _________________ "Albatross"! |
Posted: Wed May 19, 2021 4:04 pm Post subject: Re: New concrete floor |
I used a 2 part epoxy floor paint on my shop floor 21 years ago, looks great and is easy to clean, I've scrootched off a few spots dragging heavy shit on it, and there's some spots wearing thin in high traffic areas, but overall it's way better than bare concrete.
No doubt formulas have improved, or maybe not, the stuff today may be "environmentally friendly", we all know how that's a long way to spell "sucks". _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
KTPhil Samba Member
Joined: April 06, 2006 Posts: 34003 Location: Conejo Valley, CA
Posted: Wed May 19, 2021 4:17 pm Post subject: Re: New concrete floor |
babysnakes Samba Member
Posted: Wed May 19, 2021 5:22 pm Post subject: Re: New concrete floor |
busdaddy wrote: |
I used a 2 part epoxy floor paint on my shop floor 21 years ago, looks great and is easy to clean, I've scrootched off a few spots dragging heavy shit on it, |
I want one of these epoxy coatings but I am concerned about floor jacks and stands causing a fubar situation. |
Posted: Wed May 19, 2021 5:45 pm Post subject: Re: New concrete floor |
babysnakes wrote: |
busdaddy wrote: |
I followed the instructions and etched it first, jacks and stands have no effect on it, it did scrape off in places when dragging a milling machine across it, and a few other places where heavy sharp things dug in, the stuff beside the scrapes is still stuck fine.
The only thing that's marked it is where a battery leaked and I didn't find it for months (bubbled up) and one place where I put newspaper flyers under a caliper job and the brake fluid soaked through and transferred the ink.
We also put poly sheeting under the slab before we poured it, the lack of moisture from below may play a part in the formula. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
raygreenwood Samba Member
Joined: November 24, 2008 Posts: 21513 Location: Oklahoma City
Posted: Wed May 19, 2021 8:59 pm Post subject: Re: New concrete floor |
The question is....are you looking for some kind of "chemical proof" barrier...or just a good sealed surface that is easy to keep uniform and clean looking?
If you need it sealed....there are numerous excellent two part epoxy systems like those being described.
As BD is getting at...like everything....prep is key and yes....keeping moisture from the backside will make it stay attached longer.
The other issue with ANYTHING epoxy based....is humidity while mixing and pouring. It can screw up curing and adhesion.
If you are just looking for a good looking smooth floor that makes cleaning up spills better....use a "dry-shake" style concrete dye....with a float concrete style application. Some use "integrally colored" concrete...where they add dye to teh concrete.
Then when its still wet....add a "dry shake" dye on top. With float style concrete....you leave a thin film of water on the top as it cures. This makes that slick polished type orf concrete you find inside of houses and buildings where the concrete will not be covered.
It makes a tighter surface. And...with a dry shake dye,....if you screw it up you can re-dye it to some extent. Ray |
my59 Samba Member
Joined: August 13, 2003 Posts: 3791 Location: connecting the dots
Posted: Thu May 20, 2021 12:08 am Post subject: Re: New concrete floor |
https://www.google.com/url?sa=t&source=web&...4HuYsywKAI
It's a new slab, so it needs to fully cure before anything gets painted on or soaked in. _________________ my59: Well son, my grandfather died before I got to drive it, so does that answer your question?
Other:'12 Jetta, '77 Benz 300D, and a 74 MG Midget. |
Posted: Thu May 20, 2021 3:57 am Post subject: Re: New concrete floor |
Definitely using plastic, wire mesh, and probably fibre mesh in mix. Trouble is customer wants to use for wedding less than two weeks after placing concrete, they have no idea of timing, or what it takes to make things last.
Probably gonna have to clean , etch, epoxy after it has been used. Not ideal but
It is what it is. Any thing we can add to mix to avoid having to top coat? _________________ "Albatross"! |
Letterman7 Samba Member
Joined: March 14, 2004 Posts: 3198 Location: Downingtown, PA
Posted: Thu May 20, 2021 5:44 am Post subject: Re: New concrete floor |
How big is the slab? If they want a wedding on it two weeks after the pour, I'd sell them on some of those click-together rubber tiles. Standing on concrete for hours is no fun, a cushioned tile makes life much easier. Then, they can properly wait for the cure to put whatever topcoat they want. I haven't done the epoxy coatings personally, but I know people that have with no issues. |
Posted: Thu May 20, 2021 7:44 am Post subject: Re: New concrete floor |
I'll bet you can rent some great big rugs from an event company, that'll make it pretty and hopefully protect it until it's fully cured. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
KTPhil Samba Member
Posted: Thu May 20, 2021 9:26 am Post subject: Re: New concrete floor |
Rugs are a good idea.
If you really want something all over, try the click-together plastic tiles (either solid or mesh), and you can be clever and start with a pattern with their name or wedding date spelled out, then reconfigure them to something else (cheered flag, red/white/blue, etc) after, at little expense. |
Q-Dog Samba Member
Joined: April 05, 2010 Posts: 8699 Location: Sunset, Louisiana
RIX70Bay Samba Member
Joined: June 14, 2017 Posts: 45 Location: moved to Iowa
Posted: Thu May 20, 2021 11:39 am Post subject: Re: New concrete floor |
I am currently building a steel building type garage and thinking of an epoxy coating on the floor. What do you guys think of the two-part epoxy kit they sell at Lowes? _________________ Rick
1970 7 Passenger Bus (Rose)
1968 Square back (Baby Huey)
1970 Standard Bug
1951 Crosley Super
1968 Camaro (Gifted to my son) |
Who.Me? Samba Member
Joined: July 14, 2014 Posts: 2207 Location: UK (South)
Zundfolge1432 Samba Member
Posted: Thu May 20, 2021 2:42 pm Post subject: Re: New concrete floor |
Just found an old can, the stuff I used was Amerlock 400 high solids epoxy coating, no complaints after 21 years. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Thu May 20, 2021 3:27 pm Post subject: Re: New concrete floor |
thanks to everyone who responded, i am a carpenter not a concrete ace, just trying to get the best results for the customer, concrete guy has no opinion on topping, not my choice of contractor. _________________ "Albatross"! |
