WBX Emulator - real time data, onboard diagnostics and tuning
Page: Previous  1, 2, 3, ... 29, 30, 31  Next
DigiMatrix
DigiMatrix is offline
PostPosted: Fri May 21, 2021 12:24 pm    Post subject: Re: WBX Emulator - real time data, onboard diagnostics and tuning Reply with quote
I have started a list based on this post and have ordered 20 PCB's for now. I am only doing this to help out fellow vanagon owners with the later WBX so please be patient. Not sure how long the PCB's will take to arrive and then there is build time and testing on top of that.
I will update the progress in this thread.
DanHoug
DanHoug is offline
PostPosted: Fri May 21, 2021 12:27 pm    Post subject: Re: WBX Emulator - real time data, onboard diagnostics and tuning Reply with quote
thank you for offering this to the community! your R&D plus production is truly appreciated.
-dan
www.thefixitworkshop.com
davideric9
davideric9 is offline
PostPosted: Fri May 21, 2021 9:46 pm    Post subject: Re: WBX Emulator - real time data, onboard diagnostics and tuning Reply with quote
sounds great. Can I move this from one of my vans to another? Please put me on the list for "one".
1987 Syncro Westfalia, stock (bought 1994)
1986 Syncro Westfalia SVX, 3 knob (bought 2008)
1987 Westfalia (bought 2010)
1988 Wolfsburg GL (bought 2012)
DigiMatrix
PostPosted: Fri May 21, 2021 10:02 pm    Post subject: Re: WBX Emulator - real time data, onboard diagnostics and tuning Reply with quote
Sure you can move from one van to another provided it is also uses Digifant 1. The emulator itself requires one of the ECU versions listed above, but a van not running one of these versions (VW part # 025 906 022 either Bosch or Triumph Adler) will run just fine on the "D" version. Easier to swap the ECU than the emulator itself. On the list
MayorMcCheese
MayorMcCheese is offline
PostPosted: Sat May 22, 2021 2:39 am    Post subject: Re: WBX Emulator - real time data, onboard diagnostics and tuning Reply with quote
I need this
edit: But for Digijet
Steve M.
Steve M. is offline
PostPosted: Sat May 22, 2021 4:42 am    Post subject: Re: WBX Emulator - real time data, onboard diagnostics and tuning Reply with quote
Good on you.
Do you need any money up front to help fund it?
MartinG
MartinG is offline
PostPosted: Sat May 22, 2021 6:05 am    Post subject: Re: WBX Emulator - real time data, onboard diagnostics and tuning Reply with quote
I would also be interested in this emulator. Don't know if I Have the "D" ECU but I'll check.
DigiMatrix
PostPosted: Sat May 22, 2021 6:56 am    Post subject: Re: WBX Emulator - real time data, onboard diagnostics and tuning Reply with quote
Thanks for asking, but I'm good. This offering isn't intended to be a money maker and I hope I don't regret it. I am working on comprehensive instructions to minimize my time required to get purchasers up and running. I would like to ask that people check their ecu is compatible before adding their name here to the list. Once the first 20 are sold, I will continue to do batches, time permitting.
If you want to be on the list, please state you wish to be added to the list. Everyone wants a lot of things, including me, but that doesn't mean I'm going to buy it. The list is to judge interest and when I need to order more parts - once emulators become available, I will notify those that have requested to be on the list. If you decline, or don't respond, I will move down the list. If you want back on, you'll have to restate your interest.
AndyBees
AndyBees is offline
PostPosted: Sat May 22, 2021 6:58 am    Post subject: Re: WBX Emulator - real time data, onboard diagnostics and tuning Reply with quote
Subscribed ....
'84 Vanagon Tin-top, ALH TDI. 1989 Tin-top
1983 Air-cool, 225k miles, 180k miles mine. Seven trips to Alaska from 1986 thru 2003.
dhaavers
dhaavers is offline
PostPosted: Sat May 22, 2021 7:06 am    Post subject: Re: WBX Emulator - real time data, onboard diagnostics and tuning Reply with quote
Don't know if this is something I need, but curious about cost...ballpark?
- Dave
"The WonderVan"
Steve M.
Steve M. is offline
PostPosted: Sat May 22, 2021 7:22 am    Post subject: Re: WBX Emulator - real time data, onboard diagnostics and tuning Reply with quote
Please add me to the official list! Very Happy
DigiMatrix
PostPosted: Sat May 22, 2021 7:29 am    Post subject: Re: WBX Emulator - real time data, onboard diagnostics and tuning Reply with quote
- Dave
The price was buried on the first page, I have now added it to the first post so people will see it.
bheins
bheins is offline
PostPosted: Sat May 22, 2021 12:12 pm    Post subject: Re: WBX Emulator - real time data, onboard diagnostics and tuning Reply with quote
I'd like to be added to the list as well. Thanks!
ohhorob
ohhorob is offline
PostPosted: Sat May 22, 2021 1:08 pm    Post subject: Re: WBX Emulator - real time data, onboard diagnostics and tuning Reply with quote
MayorMcCheese wrote:
I need this
Me too. I've already extracted the EPROM from a Digijet ECU. Was hoping to find the air/fuel map and allow adjustments. Perhaps a microcontroller can replace the physical EPROM and provide instructions & data to the Digijet as it runs?
But I couldn't find a decompiler, and didn't make much process trying to decompile by hand.
"Gundy" - '85 Westfalia
GoWesty 2300cc, Digijet
DigiMatrix
PostPosted: Mon May 24, 2021 6:49 pm    Post subject: Re: WBX Emulator - real time data, onboard diagnostics and tuning Reply with quote
Little update from the weekend:
My friend Rafal, has done the testing and this emulator will also have an immobilizer built into it. No Fuel or spark available from the ECU when this feature is enabled. Very Happy
No extra cost for this as it is important in our opinion.
dabaron
dabaron is offline
PostPosted: Mon May 24, 2021 6:53 pm    Post subject: Re: WBX Emulator - real time data, onboard diagnostics and tuning Reply with quote
"hey man, mind if i charge my phone, i can't start my Westy"
looking forward to having realtime metrics and the ability to disable remotely.
1991 Vanagon GL Camper
"burnin oil and cookin coils" -- Destructo
BiWerks Design, LLC
DigiMatrix
PostPosted: Mon May 24, 2021 7:19 pm    Post subject: Re: WBX Emulator - real time data, onboard diagnostics and tuning Reply with quote
#1 - unlock and open door, plug in phone charger, power from 150 Ah on board Lifepo4 battery, turn on phone and disable immobilizer - easy! Very Happy
#2 - or, remove emulator and plug old chip back in
#3 - or, always carry a spare ECU
dabaron
dabaron is offline
PostPosted: Mon May 24, 2021 7:21 pm    Post subject: Re: WBX Emulator - real time data, onboard diagnostics and tuning Reply with quote
#1 - always carry a spare ECU
#2 - or, unlock and Open Door, plug in phone charger, power from 150 Ah on board Lifepo4 battery, turn on phone and disable immobilizer - easy! Very Happy
Twisted Evil
BiWerks Design, LLC
korfmach
korfmach is offline
PostPosted: Wed May 26, 2021 6:26 am    Post subject: Re: WBX Emulator - real time data, onboard diagnostics and tuning Reply with quote
This is a GREAT idea and something that will be a major aid to anyone who comes to Vanagon-land from modern OBD-capable vehicles. Thanks very much for putting the time and effort into this.
I'd love to have one, sign me up!
1989 Westy
2016 Golf TSI
Gone, but not forgotten:
1974 Dorper Baywindow, "The Bleeding Trout"
1998 Jetta TDI, "Trixie"
1987 GTI, "Heike"
1974 Thing, "The Luftwaffel"
1974 Ghia
1966 Ghia
uberaudi
uberaudi is offline
PostPosted: Wed May 26, 2021 11:43 am    Post subject: Re: WBX Emulator - real time data, onboard diagnostics and tuning Reply with quote
I'm down for one (if I can find a reasonably priced 'D' ECU)...what an awesome development!!
'84 Adventurewagen 1Z Tdi, '89 Tintop ABA, and a 86 Syncro tintop WBX.
Page 2 of 31
