DigiMatrix Samba Member
Joined: April 20, 2010 Posts: 450 Location: Up North Canada
Posted: Sun Oct 17, 2021 10:32 pm Post subject: Re: WBX Emulator - real time data, onboard diagnostics and tuning |
When the Emulator looses connection with the ECU data output because of poor soldering it can cause the engine to stumble or stall. This is why I have been saying it is very important to solder the wire to the ECU properly. I have updated the installation instructions with 3 options depending on your skill level.
Please use solder flux and don't apply too much heat. In all 3 cases I have had to re-solder the connection and testing shows the issue is solved.
To test if the issue is the connection to ECU, use your laptop and connect with the Windows application and de-select the "enable digidiag" checkbox on the bank you are using. This turns off the output from the ECU and will solve the issue if it is a poor solder connection until the connection can be properly repaired. If it doesn't solve the issue then e-mail me and I will make arrangements to correct the issue.
_________________ _________________
'91 Syncro Westfalia
soon to be 2.5 liter stroker WBX 10:1 comp
Digifant ECU with knock sensor and custom
cylinder selective knock control by me |
Vana Guy Samba Member
Posted: Thu Oct 21, 2021 2:54 pm Post subject: Re: WBX Emulator - real time data, onboard diagnostics and tuning |
Not sure if this has been mentioned, or if an Android phone is suitable for the emulator, but when I need an Android device I buy a reconditioned phone from Tracfone. What is available depends on your location. I was getting some very nice LG rebel phones for $10.00 + $15.00 (cell service, 30 days, you have to by some cell service to buy the phone) The phones work well after the service expires, or you can just sell the service to someone. They do not need to be activated to work.
Around Christmas you can find these phones on sale in stores, sometimes for $20.00, but you don't need to buy service when purchased from store, typically. |
Posted: Sat Oct 23, 2021 8:20 am Post subject: Re: WBX Emulator - real time data, onboard diagnostics and tuning |
DuncanS wrote: |
When I was a kid and wanted something I had reasonably good luck with my North Pole supplier. Have you tried writing Santa? I hear he may now respond to emails, but not texts. Hope he doesn't have to disappoint many this December. |
So, I guess Santa also reads posts on the Samba. This morning my wife told me a parcel arrived for me. She went and grabbed it to show me and it was from Mouser Elecrtonics. 25 more microprocessors that weren't supposed to be available until Feb 4th, 2022. So, now I will try and up my game and get people taken care of before Chrisrmas.
I also just noticed there are 3 "D" version ECU's available in the classifieds right now that will work with the emulator if you are looking for one. _________________ _________________
crazyvwvanman Samba Member
Joined: January 28, 2008 Posts: 9935 Location: Orbiting San Diego
Posted: Sat Oct 23, 2021 9:10 am Post subject: Re: WBX Emulator - real time data, onboard diagnostics and tuning |
Please add me to the list and if available I'd like a second one for multiple van owning friends to borrow.
thanks,
Mark
DigiMatrix wrote: |
This morning my wife told me a parcel arrived for me. She went and grabbed it to show me and it was from Mouser Elecrtonics. 25 more microprocessors that weren't supposed to be next available until Feb 4th, 2022. So, now I will try and up my game and get people taken care of before Chrisrmas. |
jb20thae Samba Member
Posted: Sat Oct 23, 2021 10:05 pm Post subject: Re: WBX Emulator - real time data, onboard diagnostics and tuning |
Very interested, sent PM |
Bradgt74 Samba Member
Joined: May 04, 2009 Posts: 251 Location: Minneapolis
Posted: Wed Oct 27, 2021 12:43 pm Post subject: Re: WBX Emulator - real time data, onboard diagnostics and tuning |
Nice, Bradgt74 glad you have it working.
Diagnostic TIP
To help diagnose tempII sensor, if you turn your ignition on before the first start of the day, and connect to the Emulator both values of ECT and IAT should be very close to the same value. You can see this in the image posted above, although I suspect the ECT was already on the rise because the engine is running.
Why:
In the "D" version ECU the voltage divider used for the ECT input and the IAT input is the same going to the A/D convertor. The service manual also states that the resistance values are the same for the sender for intake air temperature(G42) and the Coolant temperature sensor (G18). Thus it makes sense that if your engine is left to cool, the outside air temperature and the coolant temperature should approach the same value. Not a perfect method because quickly changing outside temperature can mess up the readings, but it is a quick check if you suspect problems.
Here is one of my screen shots - both values are the same and it was my first start of the day at 5:00 pm
natejohn Samba Member
Joined: February 20, 2020 Posts: 57 Location: Vancouver, BC
Posted: Wed Oct 27, 2021 6:18 pm Post subject: Re: WBX Emulator - real time data, onboard diagnostics and tuning |
DigiMatrix wrote: |
Diagnostic TIP
Why:
I noticed the same when I took my warmup vid. Interesting how ours are exactly the same.
_________________ 1990 Vanagon Westfalia |
Steve M. Samba Member
Joined: July 30, 2013 Posts: 6832 Location: Fort Lauderdale, Fl.
Posted: Wed Oct 27, 2021 6:48 pm Post subject: Re: WBX Emulator - real time data, onboard diagnostics and tuning |
natejohn wrote: |
DigiMatrix wrote: |
Diagnostic TIP
Why:
Mine also says 78 degrees advanced timing. _________________ This free advice is worth exactly what you paid for it.
Posted: Wed Oct 27, 2021 7:20 pm Post subject: Re: WBX Emulator - real time data, onboard diagnostics and tuning |
Steve M. wrote: |
Mine also says 78 degrees advanced timing. |
That is perfectly normal, because timing in the ECU is calculated once the ECU starts seeing Hall pulses. Since just the ignition is on and the engine is not turning over it hasn't calculated the timing value yet and
Advance = 78-(calculated value).
See picture below once the engine starts turning over - only at 189 RPM so not even up to cranking speed yet.
montanasurfer Samba Member
Joined: March 06, 2014 Posts: 319 Location: United States
Posted: Wed Nov 03, 2021 9:05 pm Post subject: Re: WBX Emulator - real time data, onboard diagnostics and tuning |
I am now even more excited for this WBX emulator as I just encountered a running issue tonight! Cut outs both at 60 mph and at idle, engine hot. I suspect the AFM. Any updates on the next batches? _________________ 1987 Vanagon GL - Wolfsburg Edition |
Posted: Wed Nov 03, 2021 10:30 pm Post subject: Re: WBX Emulator - real time data, onboard diagnostics and tuning |
Was working on them again tonight. I got 6 more built with some testing. I now have a total of 16 built and am in the midst of testing them. I have all the parts on hand to build 4 more. I then have to buy 21 more PCB's for run 3 (have the other parts on hand for that run)
montanasurfer it's going to be about 2 weeks before I can ship yours (it is built). Hoping to maybe ship some next Monday if I find enough time this weekend to test in my Van. Bench testing continues - burn in, SRAM testing, loading files, flashing firmware Connecting to TunerpPro, the Windows application, and ALDLdroid - it's a process that takes time. _________________ _________________
Posted: Thu Nov 04, 2021 8:28 am Post subject: Re: WBX Emulator - real time data, onboard diagnostics and tuning |
DigiMatrix wrote: |
montanasurfer it's going to be about 2 weeks before I can ship yours (it is built). Hoping to maybe ship some next Monday if I find enough time this weekend to test in my Van. Bench testing continues - burn in, SRAM testing, loading files, flashing firmware Connecting to TunerpPro, the Windows application, and ALDLdroid - it's a process that takes time. |
Oh my goodness! What a great update to hear! I am continually grateful for all your hard work! My running issue is intermittent so I am so very excited about the data logging aspect! This is just such a rad product! You rock DigiMatrix! _________________ 1987 Vanagon GL - Wolfsburg Edition |
9.5isCanadian Samba Member
Joined: September 16, 2017 Posts: 465 Location: In your blind spot.
Posted: Thu Nov 04, 2021 10:12 am Post subject: Re: WBX Emulator - real time data, onboard diagnostics and tuning |
DigiMatrix wrote: |
>SNIP< it's a process that takes time. |
I appreciate your work and am still willing to prepay to finance the purchase of more parts for your next run.
A word of caution though, I started making stove grates for the cook top, there's a thread on here somewhere, and it quickly grew in scope. I found I was spending a lot of time making parts and not working on or enjoying my van.
I was a little relieved when our two countries had a tariff / NAFTA spat that drove the cost of material and shipping up to the point I couldn't justify making them at the price I was selling them for.
You are making a great product but don't burn out. _________________ 9 1/2 - missing a few pieces.
1987 Getaway Hightop
1980 Sunroof Vanagon
2018 BMW R Nine T
2012 Golf tdi |
xavior12 Samba Member
Joined: September 25, 2006 Posts: 92 Location: Portland, Oregon
Posted: Sat Nov 06, 2021 3:45 pm Post subject: Re: WBX Emulator - real time data, onboard diagnostics and tuning |
I'd like to get in on the next batch with tuning ability. |
Posted: Sat Nov 06, 2021 5:05 pm Post subject: Re: WBX Emulator - real time data, onboard diagnostics and tuning |
xavior12 wrote: |
You have been added to the list. The tuning ability is possible with the purchase - same price. I have not released it yet because I don't have the time to complete the needed file. Once it is ready, it will be available to all. _________________ _________________
Posted: Mon Nov 15, 2021 5:27 pm Post subject: Re: WBX Emulator - real time data, onboard diagnostics and tuning |
So... there is going to be a delay shipping out the second batch of Emulators. Unfortunately we have been evacuated from our town due to flooding. Not sure when we will be allowed back. The water treatment plant has been compromised so it might be a while - hope not. If you search Merritt BC you'll see the pictures. We are up high on a hill, so will not have the damage others in the lower areas will. _________________ _________________
Posted: Mon Nov 15, 2021 5:30 pm Post subject: Re: WBX Emulator - real time data, onboard diagnostics and tuning |
DigiMatrix wrote: |
So... there is going to be a delay shipping out the second batch of Emulators. Unfortunately we have been evacuated from our town due to flooding. Not sure when we will be allowed back. The water treatment plant has been compromised so it might be a while - hope not. If you search Merritt BC you'll see the pictures. We are up high on a hill, so will not have the damage others in the lower areas will. |
Oh my gosh! I hope you and your loved ones stay safe and dry! What a horrible situation! I'm glad to hear that your property is safely up on a hill. What a nightmare! First wildfires and now floods _________________ 1987 Vanagon GL - Wolfsburg Edition |
Posted: Mon Nov 15, 2021 5:45 pm Post subject: Re: WBX Emulator - real time data, onboard diagnostics and tuning |
DigiMatrix wrote: |
I was looking at the news. The storm just blew through here an hour ago. Wife says our place is still dry but there’s no way we’ll be anywhere near as bad as you have it.
Stay safe my friend.
Owen _________________ 9 1/2 - missing a few pieces.
2018 BMW R Nine T
2012 Golf tdi |
Posted: Wed Nov 24, 2021 6:37 pm Post subject: Re: WBX Emulator - real time data, onboard diagnostics and tuning |
I got back home yesterday afternoon so testing has re-started. Our mail service from Merritt hasn't resumed yet so I don't know when I will be shipping the next batch.
I did, however use some of my time away working on a Vanagon fuel calculator that will help with tuning for changes to your engine. The calculator loads the Vanagon binary and does the fuel calculation from the fuel tables and displays them as injector pulse width. It can also convert from injector pulse width back to the fuel table values. This is helpful because if you are running different injectors, you can scale the injector pulse width table and it will automatically calculate what the new fuel table should be. Say like Marco injectors and ratio rockers for instance. I will show more detail when I am finished. _________________ _________________
