will t Samba Member
Posted: Mon May 24, 2021 1:56 pm Post subject: Is it a 66 or a 67? |
Hi all,
Last week I purchased a 67 Westfalia at auction (BaT). Some of you may have seen the proceedings. This isn't my first camper - between 1977 and 1995 I had three 66's and two 67's, all Westfalia campmobiles. All my 66's had the shore power in the back above the taillights, and no backup lights. Both my 67's had backup lights above the taillights, and they had the 12 Volt lightning sticker in the driver's side door jamb.
The camper I bought last week has the shore power in back and no backup lights. The date code on the chassis plate is 07 7 and the first digit of the VIN is 7. So that says July 7, 1967.
The Westfalia package is a 66. Says so on the plate. Benonnung SO42 Fabrik Nr. 6416 Baujahr 19 66
I haven't had time to get into the electrical system and engine - I've barely looked the bus over. But it sure looks like the 66's I owned more than it looks like the 67's.
My question is, have you all ever seen other 67's made this way, with no backup lights?
Thank you all for your wisdom,
Will |
srfndoc Samba Member
Posted: Mon May 24, 2021 2:14 pm Post subject: Re: Is it a 66 or a 67? |
Plenty of early 67's with no backup lights, small radio opening.
Does the VIN on the mcode plate match the stamped VIN/VIN tag?
July 67 would be late in the split production so you would expect all the late features (backup lights, big radio opening). I've seen a few early 67 Westy's with 66 dated kits in them.
Post the whole mcode plate. _________________ RPM=(MPH*336* (R&P*4th*1.26))/Tire Diameter in inches |
hitest Samba Member
Joined: September 30, 2008 Posts: 10296 Location: Prime Meridian, ID
Posted: Mon May 24, 2021 2:59 pm Post subject: Re: Is it a 66 or a 67? |
The first digit of the VIN is a "7?" The third digit is key to knowing model year of your bus.
The earliest '67s had no backup lights as srfndoc said. But For it to have an early July manufacture date it should still be a '66. Could it have been held over at Westfalia? I'll bet it could.
Nobody will try anything devious with your VIN info so it won't be a risk to share nearly the whole VIN- enough for us to be helpful any way. _________________
EverettB wrote: |
FU#5 |
turkis-deluxe Samba Security
Posted: Mon May 24, 2021 4:42 pm Post subject: Re: Is it a 66 or a 67? |
Here's the edited M-code plate off BAT. Personally I think this just a super late hold over and no back up lights installed at the factory. Not sure exactly when the change was made and I'm sure someone with time can look into Progressive Refinements and figure it out.
Looks like a nice Westy and have fun with it! I just sold my 67 Westy last year but went slightly older to a 63 SO34. |
will t Samba Member
Thank you for your prompt replies. I should have posted these pictures before but here they are. These are actually shots from the auction. I have not had time to do much with the camper yet. One thing, I do wish to take some stripper or whatever and get to the engraved number. The picture is rather hard to see but it appears to show 2370, which would match up. I'm also including a shot of the Westfalia plate. I think it very well may be that the car got held up at Westfalia. The VIN on the title (Michigan) is shown as C237002101
(The M-code plate is covered in white spray paint - as is much of the interior original paint, and most if not all of the exterior has been poorly painted too. Radio hole got enlarged too). But all that will be another thread...
Erik G Samba Member
Joined: October 16, 2002 Posts: 13280 Location: Tejas!
Posted: Mon May 24, 2021 5:50 pm Post subject: Re: Is it a 66 or a 67? |
3rd digit = 7 means it's a 67. End of story |
truckersmike Elder Sambanite
Joined: March 16, 2001 Posts: 2025 Location: Bellingham, WA
Posted: Mon May 24, 2021 7:15 pm Post subject: Re: Is it a 66 or a 67? |
My 67 Westy has the plug in the back, no back-up lights and a single circuit MC but it has a large radio hole. Go figure. _________________ 59 DD panel. Former Romano's TV delivery bus
67 Westy SO-42 pop-t |
VWAdam Samba Member
Joined: February 14, 2002 Posts: 3331 Location: Birmingham, Alabama
Posted: Mon May 24, 2021 7:34 pm Post subject: Re: Is it a 66 or a 67? |
My first split was a very early '67. I still remember the VIN 247000426
No reverse lights, small radio opening and single circuit brakes.
It was 12 volt, had the '67 dash knobs, the '67 gas flap and hatch. _________________ All he needed was a wheel in his hand and four on the road.
'59 Euro Beetle ragtop
'63 Standard Microbus
Come to my show! www.volksjam.com
Looking for badge/sticker/frame from Western Motors in Great Falls, Montana |
BulliBill Samba Member
Joined: July 09, 2004 Posts: 4572 Location: St Charles, MO
Posted: Mon May 24, 2021 7:53 pm Post subject: Re: Is it a 66 or a 67? |
Yep! That VIN plate on your overhead air channel is telling us that it is a very early 1967 model year Transporter. Cool!
Bill _________________ I'm looking for these license plate frames for my fleet:
Mission VW - San Fernando
Thornton VW - Stockton
Thanks for any help! |
will t Samba Member
Posted: Mon May 24, 2021 8:45 pm Post subject: Re: Is it a 66 or a 67? |
Thanks to all for the informative responses! It's nice to have a split window bus again and be amongst the people who love them |
widehatch Samba Member
Joined: May 27, 2007 Posts: 775 Location: Memphis, TN aka The Armpit of the South
Posted: Tue May 25, 2021 6:03 am Post subject: Re: Is it a 66 or a 67? |
will t wrote: |
wait a minute! looks to me that the stamped vin and the 2 removable vin tags dont match up!!!!! the tags both say 237002101 while the stamped, and most likely original vin, says 237082?9?. looks like someone swapped the vin tags from another bus. _________________ Missouri Micros |
will t Samba Member
Posted: Tue May 25, 2021 6:20 am Post subject: Re: Is it a 66 or a 67? |
Quote: |
wait a minute! looks to me that the stamped vin and the 2 removable vin tags dont match up!!!!! the tags both say 237002101 while the stamped, and most likely original vin, says 237082?9?. looks like someone swapped the vin tags from another bus. |
I see the same thing. I am going to strip the (added) paint off that area to expose the stamped VIN this morning. |
velvetgreen Samba Member
Posted: Tue May 25, 2021 6:52 am Post subject: Re: Is it a 66 or a 67? |
If any VIN swapping went on they did a mighty fine job with an eye for detail. The insanely small dome head screws that secure the mcode tag look original and untouched with factory paint (these usually get lost in the process of swapping and replaced with whatever phillips screws the scoundrel has at hand) . The rivets that hold the aluminum tag to the overhead box also look 50+ years old and unscathed. Strip back a wee bit of paint in the engine compartment to reveal the VIN before pushing panic button |
will t Samba Member
Posted: Tue May 25, 2021 7:44 am Post subject: Re: Is it a 66 or a 67? |
Ok I stripped back a wee bit of paint to get a good look:
I agree the rivets and screws look pretty untouched other than the white spray paint on the M-code plate |
Posted: Tue May 25, 2021 7:52 am Post subject: Re: Is it a 66 or a 67? |
will t wrote: |
Everything matches up like it should so you're all good. The m-code plate doesn't list the 23 portion of the VIN as it's technically the model#. 23 is the 2312. 231 is Kombi with left hand drive and the 2 is the paint type. |
Posted: Tue May 25, 2021 7:55 am Post subject: Re: Is it a 66 or a 67? |
great news. i swear that first pic of the vin looked like an 8. _________________ Missouri Micros |
Posted: Tue May 25, 2021 8:02 am Post subject: Re: Is it a 66 or a 67? |
Yay! Good news!! Mcode tag is supposed to be painted the same colour as the rest of the cab- that is why it is a give away when it has been removed/replaced as the paint around it frequently is damaged when the tag is carelessly removed. |
will t Samba Member
Posted: Tue May 25, 2021 8:03 am Post subject: Re: Is it a 66 or a 67? |
turkis-deluxe wrote: |
will t wrote: |
Yes, I agree, the way I read the M-codes is: UN is destination New York, of 2312 i read 23 is Kombi, 23A is cargo doors right, LHD, which this bus is, but isn't an "A", 1 is the "variation on the model", perhaps that it was destined for Westfalia, and the 2 is Nitro-Laquer finish |
will t Samba Member
Posted: Tue May 25, 2021 8:06 am Post subject: |
velvetgreen wrote: |
This bus was "restored"! Much of the interior is painted with white spray paint. They even painted vinyl on the rear big cushion and the (wrong for this model) stool! I have some pictures:
stool
cushion - all sides of course
sheet metal all over, and radio hole enlarged
and the pulley wheels?
vwuberalles Samba Member
Joined: October 18, 2003 Posts: 1357 Location: Richmond, VA
