rusty_74_bug Samba Member
Joined: November 22, 2019 Posts: 321 Location: Vancouver, WA
Posted: Wed May 26, 2021 5:06 pm Post subject: Re: '74 Super brakes - adjuster nut |
polypetalous wrote: |
I polished everything... even chucked a bit of scotchbrite in a drill and did the backing plate holes where the star adjuster go.
Made it so everything turned smooth and easy even without grease/antiseize.
Ben |
Just finished up for the day but I did find some perfect sized washers...4 or 5 seemed to have worked and prevents the nut from digging itself in too far. I also need to go get a proper adjustment tool, the control arms and the sway bar on a Super make it really difficult to use a screwdriver. I have officially decided I do not like doing brakes _________________ '74 Standard Bug |
polypetalous Samba Member
Joined: January 14, 2021 Posts: 110 Location: Kansas, USA
Posted: Wed May 26, 2021 4:30 pm Post subject: Re: '74 Super brakes - adjuster nut |
Ben |
Posted: Wed May 26, 2021 3:29 pm Post subject: Re: '74 Super brakes - adjuster nut |
Cusser wrote: |
I've used steel wool to clean these in the past. Then some grease. |
thanks Cusser. I tried grease...the adjuster nut still just wants to work itself deeper into the hole and the grease doesn't help. Once it gets to a certain point, it's impossible to turn. I'm going to see if I can find something to stuff in there to prevent the adjuster nut from going too deep. _________________ '74 Standard Bug |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31379 Location: Hot Arizona
Posted: Wed May 26, 2021 3:07 pm Post subject: Re: '74 Super brakes - adjuster nut |
I think I see what's happening. On one of them, when I start to turn to adjust, it starts working itself into the backing plate holder(?) thing, essentially tightening itself somehow to the point that I can't turn it anymore. I'm going to try to stuff it with grease but I doubt that will work. _________________ '74 Standard Bug |
Posted: Wed May 26, 2021 2:14 pm Post subject: Re: '74 Super brakes - adjuster nut |
OK, looks like I'm still having problems. I got new adjuster nuts in on the right side front but I still can't get these adjusted. I can move the nut about a 1/4 or 1/2 turn and then it will not budge anymore. It's clearly not enough as I have zero resistance and it's obvious the shoes are NOT touching the drum at all. Why won't the adjusters move anymore? _________________ '74 Standard Bug |
Posted: Wed May 26, 2021 12:04 pm Post subject: Re: '74 Super brakes - adjuster nut |
rusty_74_bug wrote: |
I am taking a break from working on this Super's autostick to give some badly needed attention to the brakes. I need to adjust the brakes but I had problems moving the adjuster nut...must be seized. I have 4 new adjuster nuts so I decided I'd just replace the ones on the front brakes. Got the drums off but I cannot get the old adjuster nuts off...they will not budge at all. I believe they are just held in by friction? What is a good way to get these out without buying some weird special tool? |
Besides penetrating oil, heat and hard pulling...
My trick was that I have a slide hammer that has a threaded end that just so happens to be the same thread type as the adjustment screw... just threaded it in and kept threading till it bottomed out and pushed the Star Adjuster out... (just used the threading power, didnt need to actually pull on the slide hammer)
So.. if you had a M10-1.5 (I THINK thats the adjuster screw thread size/type) long-ish bolt, you could just thread it into the star adjuster and push it out... easy-peasy.
1st one I pulled out by brute force and did a real number on the star adjuster, the threading trick (above) pulled the other three out without any damage. Cleaned em up and chased the threads and good as new.
Be sure to anti-seize/lube the new ones goin in, you want (need) those things to turn like butter.
Good Luck
Ben |
Oh man, that was easy. Embarrassed I didn't think of that
Problem solved, thanks for your help! _________________ '74 Standard Bug |
Posted: Wed May 26, 2021 11:59 am Post subject: Re: '74 Super brakes - adjuster nut |
Good Luck
Ben |
thanks, I'll see what bolts I have around here. _________________ '74 Standard Bug |
Posted: Wed May 26, 2021 11:45 am Post subject: Re: '74 Super brakes - adjuster nut |
Good Luck
Ben |
Posted: Wed May 26, 2021 11:10 am Post subject: '74 Super brakes - adjuster nut |
I am taking a break from working on this Super's autostick to give some badly needed attention to the brakes. I need to adjust the brakes but I had problems moving the adjuster nut...must be seized. I have 4 new adjuster nuts so I decided I'd just replace the ones on the front brakes. Got the drums off but I cannot get the old adjuster nuts off...they will not budge at all. I believe they are just held in by friction? What is a good way to get these out without buying some weird special tool? _________________ '74 Standard Bug |
