brundl3fly Samba Member
Joined: August 21, 2012 Posts: 32 Location: Lake Havasu City, AZ
Posted: Wed May 26, 2021 4:59 pm Post subject: Fuel Tank Balance Tube - replace with fuel line? |
Hi, this might be a strange topic but I bought a fuel tank reseal kit from GoWesty after my van started dumping gas on filll up. Long story short I put it in, it did not go well.
Among other things I think the balance tube might not have been routed back in exactly like the pervious one (not that they give you instructions at all for the replacement kits). I think that the angle of the rigid balance tube ripped the grommet(s). Since then I've tried to replace grommets. Sadly the grommets pushed into the tank rather than the barbs going into the grommets as they should have, bad angle I guess.
My question is I've about had it with that rigid tube, I want to cut that part off and simply run appropriate diameter flexible tube so that these issues all go away (after I drop the damned tank again and fish out my grommets). IS there any good reason that I should NOT do this? I cannot think of anything myself but am open to suggestions from those with more experience.
I wish I understood how/why this tube is at the wrong angle, etc etc but I do not know and there were no instructions and really its too late, I'm ready to cut the rigid hose off the barbs and put them in with fuel line.
Thanks for input! |
VicVan Samba Member
Joined: July 01, 2015 Posts: 1837 Location: Vancouver Island, BC
Posted: Wed May 26, 2021 7:14 pm Post subject: Re: Fuel Tank Balance Tube - replace with fuel line? |
That's totally fine. It's actually what other sellers do with their kit. I've used this one and recommend it:
https://www.vancafe.com/KT-2980103-p/kt-2980103.htm
Ask them if they sell the aluminum fittings individually. _________________ '90 Little Blue Truck, 2WD auto, FAS GenV 2.0 NA (AVH) |
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32561 Location: Reading Pennsylvania
ZsZ Samba Member
Joined: December 11, 2010 Posts: 1644 Location: Budapest Hungary, Europe
Posted: Thu May 27, 2021 3:20 am Post subject: Re: Fuel Tank Balance Tube - replace with fuel line? |
the only reason not to use a standard fuel hose is the quality of the hoses nowadays.
It can perish in a few years and you will have to do it again. _________________ Zoltan
1.9 MTdi 2wd Multivan (ex Caravelle)
Van since 2006, engine since 2008 |
Posted: Thu May 27, 2021 6:58 am Post subject: Re: Fuel Tank Balance Tube - replace with fuel line? |
Thanks for the replies!
Yeah you'd think that tube wouldnt be that bad but the angle it installs (at least how I've done it) creates issues... ripped grommets, grommets popping in the tank.
I like the looks of that kit on Vancafe, I wish I'd seen it an known the issues prior to going at this the first time. I'd have looked for that one.
I've ordered some new grommets and ear clamps already so I'll try to fix it that way, just need to find the diameter of the barbs or that rigid tube to get appropriate fuel line.
Thanks again! |
