pupjoint Samba Member
Posted: Fri May 28, 2021 9:42 am Post subject: 36 IDF venturi type |
I am trying to find some 28mm and 30mm choke for my Italian 36 IDFs.
are there early and late type of venturis ?
CB doesnt sell anything for 36, only 40IDF above. cant even find repair kit.
who would have most of the parts I need. dont want to get the wrong style that i cant use.
vwracerdave Samba Member
Joined: November 11, 2004 Posts: 15308 Location: Deep in the 405
Posted: Fri May 28, 2021 9:44 am Post subject: Re: 36 IDF venturi type |
That Alfa guy on ebay is the best source for 36 IDF parts. _________________ 2017 Street Comp Champion - Thunder Valley Raceway Park - Noble, OK
mcdragracer Samba Member
Posted: Fri May 28, 2021 9:57 am Post subject: Re: 36 IDF venturi type |
I dealt with the 40 through the 48 Weber carburetors oh, but have not had a set of 36 size I do have some vents for the i d f carbs, I just don't know the outer diameter size of those 36 are different than the 40s |
Alstrup Samba Member
Joined: July 12, 2007 Posts: 7216 Location: Videbaek Denmark
Posted: Fri May 28, 2021 10:45 am Post subject: Re: 36 IDF venturi type |
Alstrup wrote: |
36 IDF venturis have the same dimensions as venturis for 40 IDF70/71 |
I'll check and see what I have. Thanks for the info Alstrup! |
Posted: Fri May 28, 2021 4:39 pm Post subject: Re: 36 IDF venturi type |
Alstrup wrote: |
so any venturi for 40 IDF will fit 36 IDF or are there any late/early versions? |
modok Samba Member
Joined: October 30, 2009 Posts: 26788 Location: Colorado Springs
Posted: Fri May 28, 2021 11:41 pm Post subject: Re: 36 IDF venturi type |
Well, no, not all "40idf" use the same size venturi.
The vents CB sells for 40 idf, will fit your 36 idfs, they are the same.
41mm bore for the venturi & full round auxiliary venturi. |
Posted: Sat May 29, 2021 10:56 am Post subject: Re: 36 IDF venturi type |
modok wrote: |
thanks! any idea if the 40IDF rebuild kit CB sells will fit 36 IDF too? |
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 9770 Location: Oregon
modok Samba Member
Posted: Sat May 29, 2021 4:53 pm Post subject: Re: 36 IDF venturi type |
I don't buy rebuild kits. Some are poor quality and/or contain many extra parts I have no use for.
So I don't really know, but probably some of the parts fit. Probably the gaskets can be modified to work. The gasket can be re-used several times if you take care not to break them, so possibly you won't need to replace that.
Cb's sells acc. pump diaphragms, they are ok
Get genuine weber needle and seats if yours need replacement.
The way I handle the o-rings is I have an O-ring assortment, and figure out what size is needed.
If your acc pump squirters are drilled too large, ones from ICT can be used.
What other part do you need? |
