Starbucket Samba Member
Posted: Sun May 30, 2021 7:29 am Post subject: Re: Removing door panel |
rbsurfguy wrote: |
Abigdumkid wrote: |
Starbucket wrote: |
OK got that how about the door opener? |
There should be a small screw behind the interior door handle. You can see it better if you pull the handle to open the door... |
If you have the chrome trim piece around the door release handle, there may be a plastic 'cup' just behind the pull handle, wedge that out, you will see the small screw behind the handle which holds the chrome trim, remove that, remove chrome piece, pry door panel off. There are several little tabs around the perimeter of the panel held in place at holes in the door.
Jeff
OK thanks I'll see if I can pry that piece off. Just being over careful as parts are hard to find so I ask first. Thanks for the info. all. |
rbsurfguy Samba Member
Joined: August 10, 2008 Posts: 1757 Location: Fairfax, Northern Virginia Formerly Huntington Beach, SoCal
Posted: Sun May 30, 2021 5:53 am Post subject: Re: Removing door panel |
Abigdumkid wrote: |
Starbucket wrote: |
Jeff _________________ 1971 Ghia convertible (Body off rebuild)
2019 VW Atlas 4Motion
2012 Passat-Sold
See my build on The Samba at:
Jeff's 71 Vert Restoration/Reassembly http://www.thesamba.com/vw/forum/viewtopic.php?t=6...highlight= |
Abigdumkid Samba Member
Joined: November 17, 2017 Posts: 74 Location: Minnesota
Posted: Sat May 29, 2021 8:14 pm Post subject: Re: Removing door panel |
Starbucket wrote: |
There should be a small screw behind the interior door handle. You can see it better if you pull the handle to open the door... _________________ 74 Bahia red Ghia coupe. Built Jan 24th 1974, left on Jan 31st 1974. Initial destination Columbus/USA. |
c21darrel Samba Member
Posted: Sat May 29, 2021 5:08 pm Post subject: Re: Removing door panel |
Marcdeb Samba Member
Posted: Sat May 29, 2021 3:42 pm Post subject: Re: Removing door panel |
The plastic will lift away from a metal frame that lies beneath it. Use a small flat tip screwdriver covered with tape, to pry away either side of the base. The plastic cover pops up pretty easily uncovering a screw in the center of the metal base.
_________________ Marc
71 Karmann Ghia Cabrio
Previously Owned:
2011 VW EOS Hard Top Conv
2008 Saab 9-3 2.0T Conv
2003 Saab 9-3 SE Conv
2001 Saab 9-3 Conv
1998 BMW 3 Series Conv
1997 Saab 900 Conv
1997 Mazda Miata
71 Ghia Vert Restoration: https://www.thesamba.com/vw/forum/viewtopic.php?t=726710&postorder=asc |
Posted: Sat May 29, 2021 1:35 pm Post subject: Removing door panel |
How do you remove the plastic covers on window crank and door latch to access the screws so door panel can be removed on a 70 coupe? Manual say's pry off but where do you pry? Thanks |
