aerohound Samba Member
Joined: May 30, 2021 Posts: 1 Location: Virginia (VA)
Posted: Sun May 30, 2021 1:25 pm Post subject: Turn signal lever |
I have a 1967 Squareback and a mechanic friend managed to break off the turn signal lever. It has a dimmer switch built in and two wires. Got one from Spain which did not fit. The contacts and cancelling mechanism were wrong. Any suggestions? |
sjbartnik Samba Member
Joined: September 01, 2011 Posts: 5998 Location: Brooklyn
Posted: Sun May 30, 2021 2:02 pm Post subject: Re: Turn signal lever |
There are two different manufacturers of the turn signal switch. SWF is one of them and I forget what the other is, but they don’t interchange. So look at your old one and find the manufacturer stamp then buy a replacement of the same manufacturer, and prepare to pay up (or rather to make your clumsy friend pay up). _________________ 1965 Volkswagen 1500 Variant S
2000 Kawasaki W650 |
Erik G Samba Member
Joined: October 16, 2002 Posts: 13280 Location: Tejas!
Posted: Sun May 30, 2021 6:05 pm Post subject: Re: Turn signal lever |
Yep. Just be glad it's not a type34
There are used ones in the classifieds. Good luck! |
Randall Samba Member
Joined: October 03, 2004 Posts: 1403 Location: Orange County, Alta California, El Norte
Posted: Fri Jun 11, 2021 7:47 pm Post subject: Re: Turn signal lever |
aerohound wrote: |
I have a 1967 Squareback and a mechanic friend managed to break off the turn signal lever.... Any suggestions? |
I sympathize with you. The same situation happened to me over 30 years ago on my Type 3. Like in your case, a mechanic reached in through the open window while I was sitting in the driver's seat and turned my turn signal on, breaking the lever. He "fixed" it in short order by inserting a metal rod in the cavity of the arm and applying what was probably an epoxy over the lever's broken ends. The epoxy was black like the lever.
I thought about making him pay for a new lever but even as long ago as the early '90s a new lever, or even one from a junkyard, would have been hard to come by and probably not worth the effort. So being the nice guy I am I let it slide. It's not like my VW has ever looked like a show car.
I remember being at an auto show for the new 1969 models and sitting behind the wheel of an American car that had a broken turn signal lever. Stuff like that happens but we rarely hear about it. |
ataraxia Samba Member
Joined: March 19, 2010 Posts: 4504 Location: Illinois
Posted: Fri Jun 11, 2021 7:55 pm Post subject: Re: Turn signal lever |
sjbartnik wrote: |
There are two different manufacturers of the turn signal switch. SWF is one of them and I forget what the other is, but they don’t interchange. So look at your old one and find the manufacturer stamp then buy a replacement of the same manufacturer, and prepare to pay up (or rather to make your clumsy friend pay up). |
SWF and Koln (aka "circle K")
The SWF is more common and parts are easier to find - they're MFG specific because the designs are just different enough to not interchange. |
